Old 03-20-2008, 02:07 PM   #16
GB
Mod Squad
GB's Avatar
Oddometer: 56,576
Thanks Ned!! Excellent setup resource
Old 03-20-2008, 06:38 PM   #17
Weirdo
Welcome to you're "DOOM"
Weirdo's Avatar
Oddometer: 4,460
You are a class act Neduro.
That is good stuff.
Weirdo is offline   Reply With Quote
Old 03-21-2008, 12:16 PM   #18
neduro OP
Addict
neduro's Avatar
Oddometer: 11,967
Shows what you know...
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 03-22-2008, 09:18 PM   #19
Redline
Redline's Avatar
Oddometer: 313
Originally Posted by neduro
Some advice on tensioning the steering head upon reassembly- my rule is that it should be as tight as it can be, that the forks still fall to one side from center with no wheel. This isn't real scientific, but it's worked for me, so that's what you get.
First of all, thanks for the great post! I just want to make sure I read this right. If you tension your steering head bearings with the front wheel off, the forks should still fall to one side with no assistance? If I go that loose on my 640A it gets very unstable at freeway speeds. I have to tighten it so that, with the wheel on, it just barely bumps the steering lock after a tiny push of the wheel to one side.
Going off your description, I'm thinking mine might be overtightened (though there's no "wandering" like you'd get from overtightened steering head bearings). If that's the case, I wonder what's causing the headshake? I've loosened and realigned the front end, as well as repacked the bearings recently.
Redline is offline   Reply With Quote
Old 03-23-2008, 09:56 AM   #20
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
Thanks Ned, this is all great advice. I have seen many adventures FUBAR'd by poor bike prep. If you want to be cheap, ride alone - your riding buddies don't like to watch you fix your bike in faraway places. Trust me.
Another thing to consider is a new battery. A four year old battery is a lousy thing to carry into Baja, especially if you have no kick starter. I replace them yearly on my road less traveled bikes, and they are relatively cheap HERE.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 03-23-2008, 02:40 PM   #21
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,959
Originally Posted by Eurobiker
Deserves a Sticky
the guy needs his own forum.
thanks ned!
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 03-24-2008, 12:02 PM   #22
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,170
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-24-2008, 01:54 PM   #23
Colorado Uli
Motociclista Non Elegante
Colorado Uli's Avatar
Oddometer: 2,563
It's a Beemer, it don't need no stinkin maintenance.
+1 on the swingarm/shock linkage bearings. Greased mine up real well last year in April and found them rusted solid and grinding into powder in August during a ride.
Not all greases are compatible. Check a compatibility chart before packing any bearings and write down what kind of grease you used.
Something, something, something ... in latin.
"Now with more SE then ever!"
Das KTM520
2004 KTM 625 SXC - Sick. Getting better
Colorado Uli is offline   Reply With Quote
Old 03-24-2008, 02:21 PM   #24
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Not only have you penned much of your own wisdom into this, Ned, but you've linked some of the best how-to's on the site into one handy thread. Thanks!
Subscribing into my own "hall of wisdom" folder...
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 03-25-2008, 06:39 AM   #25
jjustj
cum petris et choris
jjustj's Avatar
Oddometer: 5,537
great info, thanks NED
whenim doing an all over bike check i also use white out to mark position of quite a few fasteners. Then i can quickly check to see if bolts have loosened on last ride, kinda like a pre ride check list.! Now if it'll warm up enough for me to do alli need to do on the bike!
Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime. Mark Twain
RIDE STEALTH,
http://www.advrider.com/forums/showthread.php?t=348508
http://www.advrider.com/forums/showthread.php?t=489958 Sunday worship, a strap-on, and Does this water taste funny?
jjustj is offline   Reply With Quote
Old 03-25-2008, 10:11 AM   #26
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
Ahem, may I?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-25-2008, 06:41 PM   #27
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Good DIY Nedster... should be beneficial for lots of folks.
You know what happens when you do stuff like this... don'tcha?
Plastic side up and all that shiz.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-26-2008, 12:04 AM   #28
Dirty Harry
Coffee Addict
Dirty Harry's Avatar
Oddometer: 373
Replace fuses and Dielectric the connection points.
Check air pressure? you might have covered that...
If your headlight bulb and blinkers (If you even have them) are getting old, replace.
Ohh, clean you spark arrestor
good work!
DH
2001 EX500 -sold
2003 FXD -sold
1970 CB350 -in resto
2001 DR650 -sold
2005 DR650 -
DR's do it in the dirt...
Dirty Harry is offline   Reply With Quote
Old 03-26-2008, 10:03 AM   #29
Hambone950
Mas Naranjas Por Favor!
Hambone950's Avatar
Oddometer: 676
Move to Texas
Ride all winter, maintain as you go....
Seriously good thread mate.
Will follow religeously as I exhume my VOR for visiting riders to watch me on my 530...
Hambone
Hambone950 is offline   Reply With Quote
Old 04-01-2008, 10:05 AM   #30
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,920
5) Controls: I could write a book on this topic.
You know people round here would buy it............... I know damn well I need to prep better........
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Times are GMT -7.   It's 02:38 PM.
