Old 04-01-2008, 02:50 PM   #31
JStrom
JStrom's Avatar
Oddometer: 505
Ned, can you elaborate on Point 7? I've never heard of spraying everything with WD-40 (but that ain't saying much)
thanks
04 BMW 1150 GS
JStrom is offline   Reply With Quote
Old 04-01-2008, 05:37 PM   #32
TimberlineAdventure
Maine Thumpah
TimberlineAdventure's Avatar
Oddometer: 380
thanks
I actually have something that works better in my opinion... It is called Corosion Bloc, it is a marine electrical board protectant & I have been using it for years. You can spray it on everything: plastic, decals, metal, electrical equipment, etc.... I have used if for wax for years on a car and it protects like you can not imagine, and is less greasy than WD40. You can get it at places like Boat US. I dont mean to cloud your advice Ned, you seem like the master of all maintenance...
Timberline Enduro Club, MAINE
Husqvarna '08 TE-610 Front Fork Thread Only
http://rickramsey.net/TE610mods.htm
TimberlineAdventure is offline   Reply With Quote
Old 04-02-2008, 08:26 AM   #33
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,502
Put a dab of silicone electrical grease the inside of your spark plug cap rubber.
The fender washer on the end of the throttle tube is a great idea. Might I suggest a nylon washer? (lighter, less rattling)
I differ on my prefernce for cable lube. I use a light silicone oil or TriFlow with a power luber every spring. I take this opportunity to inspect the ends of the cable for any kinks or fraying. The cables usually break at the upper end near the lever. At the first sign of wear, replace the cable.
If you have a worn clutch cable, and you are Hyper-Anal-Retentive (moi), keep the old cable & zip-tie it along the new one. You now have a functional spare in place.
Tire tip: Run only the ultra heavy duty tubes. Yeah, it's a little heavier, but you'll save yourself a lot of time repairing pinch flats on the trail. By safely enabling lower tire pressure, you'll also have much better control in the rocks. Replace tubes when they start showing excessive chaffing, or excessive corrosion around the valve stem nut. A smear of anti-sneeze around the valve stem nut will slow the galvanic corrosion caused by contact with the aluminum rim.
For my trail bikes, I'm guessing that the hours of run time are close to the hours of wrench time. It pays off.
Ned, lemme know if you're still interested in coming up for a shock party. No, not that kind of party. We'll keep Wuds away.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle screwed with this post 04-02-2008 at 08:32 AM
HellSickle is offline   Reply With Quote
Old 04-04-2008, 01:42 PM   #34
mongox
ARRRRGH!!!
mongox's Avatar
Oddometer: 2,520
Originally Posted by HellSickle
, A smear of anti-sneeze around the valve stem nut will slow the galvanic corrosion caused by contact with the aluminum rim.
The nut should actually be loosened up a bit (at least a 1/4 to 3/8s of an inch) and allow slack if running low air pressure. If you tighten it up, when the tube slips (especially the front under hard downhill breaking even with rim locks), it will shear the valve stem off of the tube. If it has slack, the stem aligns more with direction of pull and there is more elasticity preventing the shearing.
"First, God made idiots" Mark Twain
"Those who dance are considered insane by those who can't hear the music" unknown
mongox is offline   Reply With Quote
Old 04-04-2008, 06:32 PM   #35
neduro OP
Addict
neduro's Avatar
Oddometer: 12,002
Sure, it's a good cleaning agent/ solvent that won't hurt anything, it makes it easy to wipe dirt off, and if you're doing other maintenance (like a valve adjust) whatever junk you didn't get off with your thorough cleaning will stick to the WD-40 and not fall in your engine. Hopefully.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 04-04-2008, 09:43 PM   #36
309
Special Purpose
309's Avatar
Oddometer: 5,469
309 is offline   Reply With Quote
Old 04-05-2008, 05:38 AM   #37
Flaco
Zombie Holocaust
Flaco's Avatar
Oddometer: 2,324
Thanks, Ned.
Flaco is offline   Reply With Quote
Old 04-05-2008, 06:03 AM   #38
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
Most, if not all, moden cables come with a built in teflon liner and are designed to be run dry.
Any kind of lube just attracts and retains dirt/dust/grit, which prematurely wears the teflon liner.
If you're after smoother throttle action, you could try running graphite powder between the handlebar and throttle tube.
Choose Life. Choose a job. Choose a career. Choose a family.
Choose a fucking big television.
Choose sitting on that couch watching mind-numbing, spirit-crushing game shows,
stuffing fucking junk food into your mouth.
Choose rotting away at the end of it all, pishing your last in a miserable home,
nothing more than an embarrasment to the selfish, fucked up brats you spawned to replace yourself.
Choose your future. Choose life.
I chose not to choose life, I chose something else instead.
AntWare is offline   Reply With Quote
Old 04-05-2008, 07:54 PM   #39
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
Thanks for the FYI Antware, I didn't know that about cables.
And Ned, there are some places where WD-40 is not good...
meat popsicle is offline   Reply With Quote
Old 04-08-2008, 04:34 PM   #40
Incredulous
Peanut Gallery
Oddometer: 570
Originally Posted by neduro
6)
Now is also a good time to install new tires, if you've been putting it off. I know those knobs have 1/8" of hardened, rounded old rubber left, but believe me, it'll work a lot better with the full 3/8" and sharp edges to boot. KLR guys, you listening?
I am so guilty of this.
Incredulous is online now   Reply With Quote
Old 04-09-2008, 10:40 PM   #41
John2453
Wage Slave
Oddometer: 94
You da man, Ned
John
John2453 is offline   Reply With Quote
Old 04-10-2008, 02:05 AM   #42
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,748
Thanx, Ned!
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 04-10-2008, 05:29 PM   #43
Disquisitive Dave
Not so wise fool
Disquisitive Dave's Avatar
Oddometer: 457
Get your bearings and seals from an industrial bearing supply place, unless you like paying 5x the normal cost.
Any suggestions on "industrial bearing supply" houses to use? How do you talk to these people? Is there some way to translate motorcycle part numbers to their part numbers?
Disquisitive \Dis*quis"i*tive\, a.
Relating to disquisition; fond of discussion or
investigation; examining; inquisitive.
[1913 Webster]
Disquisitive Dave is offline   Reply With Quote
Old 04-10-2008, 09:41 PM   #44
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,839
+1 for anti seize esp. swing arm axel adjusters.... pull all the way out. I had about a gallon in mine once.
wrk2surf is offline   Reply With Quote
Old 04-11-2008, 01:14 AM   #45
EvilClown
EvilClown's Avatar
Oddometer: 16,748
Don't know about supply houses in your area but most can go off numbers on the bearings themselves or dimensions.
The yellow pages and Vernier calipers are your friends.
~Augustine of Hippo
Times are GMT -7.   It's 09:36 PM.
