Old 03-26-2008, 03:10 PM   #1
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
Replacement Battery TE-610
Thought I would start a thread on batteries so I can add it to the Index.
Post what battery you replaced the stock unit with and any other relavent info; cost, size difference...ect
Dan
Originally Posted by buffallodan
Got a part number?
Dan
Sure Dan, its a Yuasa YTX14-BS, MFG# M3RH4S.
Yuasa was recommended by many on Adv and I did not know until yesterday that it is an AGM
(absorbed glass mat) battery. Gonna use this one as my primary unit and warranty the OEM one as a spare.
Davevh
I used the Yuasa YTX12-BS ordered from:
http://www.derbycycles.com/cgi-bin/e...=Yuasa&count=1
It cranks better than stock and is the same size.
buffallodan screwed with this post 03-26-2008 at 03:16 PM
buffallodan is offline   Reply With Quote
Old 03-26-2008, 03:14 PM   #2
mcinfantry
who... me?
mcinfantry's Avatar
Oddometer: 436
i run Odyssey PC310 because its sealed, smaller and a better battery. its so much smaller you can put the tool kit and several other items on top of it and still fit the seat!
$130
preaching personal responsibility since 1991
1942 Dodge WC-53
2008 Husky TE610
mcinfantry is offline   Reply With Quote
Old 03-26-2008, 03:21 PM   #3
buffallodan OP
Oddometer: 1,709
$130
The Yuasa is a sealed battery. You add the acid and then put on the adhesive coated caps.
A few have reported the battery tray cracking and indeed mine has as well. I plan on getting it welded and reinforced. I wanted the same cranking amps and plan on using the Tube Tool Box mounted low.I kinda regret not getting the Odyssey though...
Dan
Old 03-26-2008, 03:48 PM   #4
mcinfantry
who... me?
mcinfantry's Avatar
Oddometer: 436
Dan
i dont remember weight, and the day i picked the bike up, i swapped batteries in the showroom and gave the original to my dealer. the pc130 was a lot lighter by feel in my hand
1942 Dodge WC-53
2008 Husky TE610
Old 03-20-2009, 09:09 PM   #5
NothingClever
Dirt Winger
NothingClever's Avatar
Oddometer: 1,097
I bought a PC310 and regret it.
I wish I had bought a Braille like I did for my KTM 950 Adv.
That battery can crank whereas the Odyssey is anemic and rarely registers over 12.3v despite frequent riding.
Flying the Austrian Adventure Airlines at 3ft AGL
And a little Swedish rocket from Varese, Italy has me a mile high
NothingClever is offline   Reply With Quote
Old 04-28-2010, 01:01 PM   #6
feenx520
Oddometer: 15
Braille battery for the 610
Which braille battery? I need to get a new one.
feenx520 is offline   Reply With Quote
Old 05-25-2010, 09:18 AM   #7
Danke
Oddometer: 3
This is what I hooked up in my SM610. The stock battery, a Yuasa YTZ 7S, & a RC51 battery to compare.
You can see from the pictures this was 07 and the little battery is still going strong, it's always cranked the bike over better than the stocker. As an aside after 3 years on the shelf the Varta is still alive, I had to toss it in the garden tractor this spring for a day.
A bit of foam to fill the space.
Ready to button up.
Danke is offline   Reply With Quote
Old 05-25-2010, 10:23 AM   #8
greenlizard
adventure lite
greenlizard's Avatar
Oddometer: 131
PC310. About $150 mail order. Lighter than stock. Hope this leads to no battery tray cracks; we'll see. Also cranks the engine just fine and, now that I have some miles on the bike, will start it while in gear (if hot).
greenlizard is offline   Reply With Quote
Old 04-17-2011, 02:40 PM   #9
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,150
Came across this in the TE thread index.
I just bought an '07 TE610 with 4,300 miles on it, and during a ride in southern NM the oem Varta gave up the ghost.
Checked out a few of the mentioned replacements, and ended up going with the Yuasa YTZ14S.
Same footprint as the YTX14BS, but around an inch shorter - giving me room to put some stout foam underneath.
Battery tray still in good shape, btw.
IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 10-06-2011, 09:49 PM   #10
djborden
Oddometer: 147
Any more feedback on a great replacement battery for the 610? price isn't much of a factor. Weight and longevity is though.
David
djborden is offline   Reply With Quote
Old 10-07-2011, 04:10 AM   #11
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,150
David
The Yuasa YTZ and YTX are both good replacements. The YTZ is "factory activated" (comes charged) and ready to drop in. The YTX - dealer adds chemicals and charges, you drop in. The YTZ can be installed at any angle.
The '11 TE 630 comes with the Yuasa YTX, btw.
Old 10-07-2011, 05:58 AM   #12
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,670
I put in a Yuasa this spring, to replace the ailing Varta. Went with the 14 series rather than the 7, just to have that extra oomph for multiple starts over short periods. It works great.
Old 10-08-2011, 01:04 PM   #13
deepcdiver
Nobody Special
deepcdiver's Avatar
Oddometer: 790
battery...
I put in an Odyssey 310, had no complaints, the bike could sit for months b
nd then crank and crank and crank. Also the cracks in the battery tray stopped growing.
Just picked up a TE630 and am likely to get the Shorei or Ballistic Litium LiP04 unit....
Pain is just weakness leaving your body
deepcdiver is offline   Reply With Quote
Old 10-08-2011, 05:24 PM   #14
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
While I have a XRL not the TE610...
I bought my battery from http://www.batteriesplus.com/manufac...Batteries.aspx the warranty is two years and the cost was affordable.
Bbasso is offline   Reply With Quote
Old 10-08-2011, 10:02 PM   #15
djborden
Oddometer: 147
Thanks for the replys! I to am looking at the lithium iron batts. Anyone have experience with them? Any issues in mild cold? 30f or higher?
they are expensive, but worth it due to weight savings...
David
Times are GMT -7.   It's 04:04 AM.
