Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 03-27-2008, 07:50 PM   #1
nofate
what blackflies?
nofate's Avatar
Oddometer: 1,993
grease guns
I am getting pretty frustrated using hand pump grease guns. Just when you get under a machine to grease some difficult to reach fitting the gun looses its prime and you gotta pull the plunger back, unscrew the cap and smear a big gob of grease from another cartridge into the small void that caused the gun not to pump anymore.
Am I doing something wrong in the loading of the cartridges or in using the gun? I've tried different brands of grease and even bought a new Lincoln grease gun, but the problem crops up on almost every cartridge I use. Is this just how these grease guns work or can I do something different to prevent this from happening. Thanks for your advice.
Rick
Chapleau, ON
KLR650 A15
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is online now   Reply With Quote
Old 03-27-2008, 07:59 PM   #2
Trl Rdr
Road Flare
Trl Rdr's Avatar
Oddometer: 547
Did you load the cartridge properly? http://plews-edelmann.com/downloads/...older=brochure and use the blead valve to remove excess air?
XR600r & XR650r Plated, (plate fell off at west-fest 08, Fixed, Ready for 2010) endangered species in Nebraska
GL1800 Orange Traded for GL18HPM9 Titanium
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Get a SmugMug account and save $5.00 use coupon: 1.JtGFPec3ugQ
Trl Rdr is online now   Reply With Quote
Old 03-27-2008, 08:12 PM   #3
nofate
what blackflies?
nofate's Avatar
Oddometer: 1,993
Thanks for the informative link. My problem is definitely air in the cap area, but when I try to loosen the cap enough to get rid of the void the cap usually comes off and the cartridge pops out and makes a big mess. I'll just have to practice this technique some more I guess. I feel a bit silly asking about what should be a basic proceedure, but it has caused me some frustration.
Rick
Chapleau, ON
KLR650 A15
Old 03-27-2008, 08:18 PM   #4
Trl Rdr
Road Flare
Trl Rdr's Avatar
Oddometer: 547
I was trying to locate a picture for the lincoln grease gun. Does it have a bleed valve? it may look like a big grease zirk with a ball in the center. You should not have to unscrew the head & make a big mess.
Old 03-27-2008, 09:54 PM   #5
GreaseMonkey
Pre-Shrunk and Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 2,854
It sounds like the plunger is not pushing up like it should, that is the only way you can get air in there, or else you may have some hardened grease in it somewhere.
If you can disassemble the head and clean it, try that otherwise remve the head, wipe clean as best you can, then let it soak in a coffee can of gas for a few days. I had a gun once that had a check ball hang up due to hardened grease and it would do the same thing. After about 4 years I got tired of it and took it apart and cleaned it, which solved the problem forev e and ever. Took about 20 minutes to do.
It's a fine line between a hobby and a mental illness.
GreaseMonkey is offline   Reply With Quote
Old 03-28-2008, 04:45 AM   #6
KLboxeR
Back in the game again
KLboxeR's Avatar
Oddometer: 2,634
Make sure the plunger rubber is installed correctly for cartridge type feeding. If it's upside, down in the position for bulk feeding it won't work properly.
When you install a new cartridge, wipe a film around the inside of the cardbord tube at the bottom. Only turn the cartridge housing on to the head by a couple of turns, then let the plunger snap closed. Finally, screw the housing in the rest of the way. That should give you an initial prime.
Clean the rubber plunger often.
If it's cold out, find a way to pre warm the grease like leaving the gun on the floor of a truck by the heater.
Store the tubes with the peel off tops, down. For some reason this seems to help.
I use either the Lincoln pistol grip or Ingersoll-Rand pistol grip guns, they seem to work the best. Only get the best models available.
Shell grease seems to work really well for me. It feeds nice and is very high quality.
If you do alot of greasing, invest in the Lincoln cordless gun. It's a very nice tool that saves a ton of time.
Chris
KLboxeR is offline   Reply With Quote
Old 03-28-2008, 05:02 AM   #7
KLboxeR
KLboxeR's Avatar
Oddometer: 2,634
Forgot to add:
Change or clean the hose end often. They will go bad and cause flow restriction that the gun can't overcome, causing you to lose prime.
Chris
Old 03-28-2008, 05:25 AM   #8
steven1955
Oddometer: 129
How old is your grease?
I don't use a whole lot of grease out of my grease un, so the grease in my grease gun was several years old. My gun stopped pumping. When I took it apart I noticed that the grease had separated into an oil and very thick solid which was hard to break apart even by hand. This was an expensive Castrol systhetic grease.
New grease gun cartridge, used the new grease to clear the old grease out of the hose. Problem solved.
steven1955 is offline   Reply With Quote
Old 03-28-2008, 07:53 PM   #9
TonyT
Oddometer: 211
Thanks Trl Rdr
Grease guns have been a source of frustration for me for years. Your link has cleared up a lot.
I have noticed that my grease gun seems to leak "oil" and a fair amount of it over time. I don't need to do a lot of greasing, so the gun lies there for months at a time. I use Canadian Tire Motomaster brand usually, maybe not the best quality and quick to decompose???
Cheers,
Tony
Director-General, French Fry Grand Prix.
Is it still an adventure if there are lots of pretty ladies and a limitless supply of free beer?
TonyT is offline   Reply With Quote
Old 03-28-2008, 08:27 PM   #10
BikePilot
BikePilot's Avatar
Location: Back in Cambridge MA for a final year of school.
Oddometer: 7,112
Some grease guns are really lame quality while others work great. I was an auto mechanic during college and we had one old manual gun at the shop that was probably older than I am and never missed a beat. All the newer manual ones we tried constantly had the issue with trapped air. We had a pnumatic gun that worked pretty well. I don't recall who made it, but I think it was sold by the Mac tools guy (but wasn't an actual Mac).
TL1000S for the road
CR250R for the dirt
DR250SE for a bit of both
DR350SE because I (err, make that my wife) liked the 250 so much
Summer 2009 Ride Report. Oshkosh, Rockies, Motocross, UT, NV, CA, Baja and a little surfing.
http://advrider.com/forums/showthrea...1#post10889861
Summer 2008 ride report. Pikes Peak, Tail of the Dragon, Badlands and lots of dirt riding
http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 03-28-2008, 08:35 PM   #11
wheatwhacker
Legless in San Francisco
wheatwhacker's Avatar
Oddometer: 1,459
Send a message via Yahoo to wheatwhacker
Install cartridge.
Push in plunger.
Unscrew the top till its got a few threads left, careful not to let it fly off. You will hear the air coming out. Tighten up the head again, few pumps and your off.
I now use a battery operated one and it works a treat.
2003 KLR 705
2007 KLR 650 (for sale)
1999 Africa twin
2006 KTM 950
2006 DRZ 400
2008 V strom 1000
wheatwhacker is offline   Reply With Quote
vB code is On
Times are GMT -7.   It's 09:01 AM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
