Old 11-19-2009, 07:22 PM   #196
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
My first guess is a lean idle condition. This causes a "hanging idle" which means the bike won't settle down to idle properly. Try setting the idle mixture screw so it's way too rich and readjust the idle. If the problem improves then you need a larger idle jet. This could also be caused by a cracked or leaking intake manifold boot.
The only part that doesn't make since is you say it only happens when the bike's moving. I'm kind of lost there. Try the lean idle thing first.
Pablo83 is offline   Reply With Quote
Old 11-19-2009, 07:58 PM   #197
2wheelsgone
Oddometer: 179
Will do. I appreciate the advise. I'm supposed to be off work tomorrow so me and some friends can do about 100 miles off road. I may be working on my bike instead. I will sleep on it and maybe something will come to me by morning. I will post back when I fix this problem.
2007 Road Glide
1995 R1100GS
1991 XR250R (plated)
1979 XT500
2wheelsgone is offline   Reply With Quote
Old 11-20-2009, 11:14 PM   #198
pabloxt500
Oddometer: 88
accessories
hi all,
i just joined and i'm really getting excited to go riding on my $460 gem. it needs alot of work but i'm always up for it.
can anyone point me in the direction of a few things.
i'm trying to find side bags and a differnet (larger)tank.
ps. i still can't upload photos :(
Bikes in hand:
1978 Yamaha SR500 #119!
1977 Yamaha XT500
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
1970 Honda CT90
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1978 Yamaha SR500- I miss it so much.
1981 Yamaha Seca 550
pabloxt500 is offline   Reply With Quote
Old 11-21-2009, 06:44 AM   #199
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
http://www.advrider.com/forums/showthread.php?t=919
Old 11-21-2009, 07:22 PM   #200
MZRider
Neo-Luddite
Oddometer: 721
hi all,
I bought a '77 XT500 w/660 original miles about two months ago for $400 and spent another $250 to make it roadworthy. Have been having a ball with it, now have nearly 1500 miles on it.
I haven't done extensive searching, but did find this 3.5 gal. tank at Clarke Mfg.: http://www.clarkemfg.com/cart/index....roducts_id=261
I plan to make my own mounting brackets and use a pair of these as saddlebags: http://www.northerntool.com/webapp/w...3124_200153124
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 11-21-2009, 08:21 PM   #201
DonB
Oddometer: 6
New to the site
Hey everyone. I'm new to the site so please forgive me if I'm not following correct protocol. I have a 2005 XT 660 R that I am interested in selling. It was purchased in Holland brand new and came back to the US along with furniture in a sea container. (thanks USMC) It is legally now titled in the US. It is in excellent shape and has 13,890 Kilometers.
Any interest out there???
DonB is offline   Reply With Quote
Old 12-03-2009, 01:26 PM   #202
pabloxt500
Oddometer: 88
Marzocchi rebuild
I have a found that the Marzocchi's on my XT should be rebuilt.
can anyone recommend a place?
Bikes in hand:
1977 Yamaha XT500
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
1970 Honda CT90
Sold off:
1992 Yamaha FZR600
Old 12-03-2009, 03:50 PM   #203
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
If you have one, I recommend your garage. If not, your dining room table.
Old 12-03-2009, 03:59 PM   #204
pabloxt500
Oddometer: 88
would it be a straight forward rebuild? i'd do it myself if i had all the parts.
Bikes in hand:
1977 Yamaha XT500
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
1970 Honda CT90
Sold off:
1992 Yamaha FZR600
Old 12-03-2009, 04:15 PM   #205
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
Well, what are you rebuilding and what's the problem with it? Forks are easy to rebuild.
Shocks aren't bad either, but most manufacturers don't publish rebuild instructions for shocks and often don't sell rebuild parts either, so that can be a bit more tricky.
Old 12-03-2009, 04:24 PM   #206
pabloxt500
Oddometer: 88
i guess i should have said they're the rear shocks. forks i've done, but not shocks.
Bikes in hand:
1977 Yamaha XT500
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
1970 Honda CT90
Sold off:
1992 Yamaha FZR600
Old 12-03-2009, 06:01 PM   #207
riceless
Let's Ride!
riceless's Avatar
Oddometer: 3,267
Here's my '77 back in '78. Somebody stole it. Really a great bike!
riceless is offline   Reply With Quote
Old 12-03-2009, 07:50 PM   #208
johnclaude
Oddometer: 15
Starting Troubles
Hey guys,
My recently acquired 78 XT500 beast doesn't want to start anymore. Being new to the whole motorcycling thing I am pretty clueless as to what to do. I charged the battery, so that when the key is turned to the right the taillight is on (even after removing the key). Turning the key to the left and kicking is getting me nowhere as is turning the key to right and kicking (just for good measure). Any suggestions as to what to do next? Thanks guys.
johnclaude is offline   Reply With Quote
Old 12-03-2009, 08:08 PM   #209
2wheelsgone
Oddometer: 179
Hello, I would go through the usual routine of: take out the spark plug. Then put the plug back in the boot and lay it against the cylinder head to ground it. Turn the key to the right and kick the bike and make sure you have a big, fat, blue spark. Make sure the plug is not sooty and fouled as well. If the plug looks good and you have spark, put the plug back in. Make sure you have fuel in the bike and you have the gas turned on. Kick the bike over. My opinion is if it don't start in 5 or 6 kicks, stop trying because something is not right. Then go to the points. Make sure they are clean at the point where they contact each other. Make sure when the gap is at it widest point, the gap is .014. This sounds elementary but your post said you are new to motorcycling. You need fuel, spark and compression to make an engine run. There could be other things to check later like timing and valve adjustment. If it has been running lately and suddenly just won't start its either the lack of fuel, the points or a fouled plug.
Hope this helps.
Steve
2007 Road Glide
1995 R1100GS
1979 XT500
Old 12-03-2009, 08:30 PM   #210
johnclaude
Oddometer: 15
Hope this helps.
Steve
Thanks for the reply Steve. I will try the plug suggestion to rule out the spark part of the equation tomorrow. It was running a couple of days ago, the guy who I bought the bike from said he had adjusted the valves and timing before selling it to me. Just downloaded a manual so now I will have something to go off of. Thanks again!
Times are GMT -7.   It's 06:05 PM.
