Old 02-10-2010, 05:46 PM   #241
dirtdiver
Oddometer: 2,039
Thanks Neduro. I just took the bike out for the first time after my 2.6 hour oil change, the gearing change from stock, and a new needle set up. It runs a lot better than it did. I still wonder if it is geared too tall for my type of riding. I was going through some eroded creeks with sharp up hills after a quick down hill and a 2' wide creek. I wanted more of a tractor feel. I am going to let it be for a bit and see.
I am still taking it easy and not really honking on the throttle. The quick release skid plate certainly makes it nice to change the oil. So far so good.
Thanks to everyone on this thread. It was a big factor in my getting this bike.
steve
Originally Posted by neduro
Jetting will vary your mileage a lot, but a well-set up carb and reasonable throttle use will see anywhere between 30-45 mpg, in my experience. So, to be assured of 110 miles, you want to have 3.5 gallons, which might easily get you close to 200 if things are at the higher end of the scale.
Personally, I find that aggressive riding on lean high altitude jetting yields about 35-38mpg, and dual-sporty use gets into the 40's. Only soft conditions with a lot of wheelspin drop me below 30.
Hope that helps.
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 02-10-2010, 06:44 PM   #242
piercalif
Biciveloce
piercalif's Avatar
Oddometer: 413
Acerbis Tank
I have a 6.3 gallon tank from Acerbis, and trying to come up with a way to protect the front corners of the tank and the petcocks, maybe with some carbon sheets/Kevlar.... any ideas?
Piero
Carlsbad
piercalif is offline   Reply With Quote
Old 02-10-2010, 06:55 PM   #243
motomark39
I reckon so
motomark39's Avatar
Oddometer: 1,064
Would this help?
KTM hardparts
2014 KTM300xcwSixDays
motomark39 is offline   Reply With Quote
Old 02-10-2010, 10:53 PM   #244
tobys
OCD Hobbiest
tobys's Avatar
Oddometer: 321
Bluhduh
/quote: I am still taking it easy and not really honking on the throttle. The quick release skid plate certainly makes it nice to change the oil. So far so good.
steve /quote:
Steve - what skidplate do you have? I like the durability of my EE plate, but it's a pain to take off, and impossible to change the oil without removing it. Even the sightglass is hard to see...
tobys is offline   Reply With Quote
Old 02-10-2010, 11:28 PM   #245
piercalif
Biciveloce
piercalif's Avatar
Oddometer: 413
not sure if this will work
Originally Posted by motomark39
KTM hardparts
is that what u install on your tank?
Piero
Carlsbad
Old 02-11-2010, 06:54 AM   #246
dirtdiver
Oddometer: 2,039
With my bike I got a factory ready to race kit. Part of this kit was a KTM hard part, quick disconnect plastic skid plate. I am a bit leary but it seems robust and comes off with the twist of a thumbscrew. Reading through the threads it seems like others are saying that this skid plate holds up pretty well. Time will tell. steve
steve /quote:
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Old 02-11-2010, 09:34 AM   #247
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,505
been using those plates for years. They hold up very well.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 02-14-2010, 10:06 AM   #248
Ryman
Oddometer: 349
Here is some interesting insight on the oil burning problem.
http://ktmtalk.com/index.php?act=ST&f=160&t=376439
Ryman is offline   Reply With Quote
Old 02-14-2010, 12:26 PM   #249
neduro OP
Addict
neduro's Avatar
Oddometer: 12,022
Interesting- that's a good post!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 02-14-2010, 01:25 PM   #250
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Gents, I just got a 530 and I am thinking of a new tank to get more range as well as protect the radiator. i am suprised that so many people go with the 3 gallon or 3.4 gallon when the bike comes standard with a 2.4 gallon. It seems like a 3 gallon tank is barely worth it for the marginal increase. Am I missing something?
steve
my favorite general use tank is the clockworks 3.4 because it uses the factory shrouds and retains a fairly stock appearance and on a tank that uses shrouds i like the natural color because you can see fuel level.
personally i have an acerbis 6.3 gal tank because it is a great value usd $315.00 shipped with cap n petcock and alot of guys say it carries the fuel low so the extra weight is not bad. it is a bit wide but easily adjusted to and many guys are so happy with it they just leave it on all the time and only put the amount of fuel they will need. 100 ish mile ride put in 3.5-4.0 gals. long unknown rides top it off. mine will be here this week i got orange on this model...looks decent, clear enough to still see fuel level
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 02-20-2010, 12:09 AM   #251
bend27
by hook or by crook
Oddometer: 1,192
[quote=osteo]I'm the same on my 08' 450EXC. I first noticed it while only a few hundred km on it, so took it in and had a Leakdown Test performed. They found it was in the top 3% (3% leak), or in other words perfect - so not to worry - so I just pay attention to it and add a bit here and there as needed.
Excuse my ignorance but can you please explain how a Leakdown Test is done? Ben.
bend27 is offline   Reply With Quote
Old 02-20-2010, 02:18 AM   #252
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
sEXC 530
Here's a couple of pics of Todd Smiths, CPW Safari prepaired KTM 530 that took first place in the 09 Gascoyne Dash (desert race)
An interesting look with the low front gaurd and plenty of bling.
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 02-20-2010, 07:26 AM   #253
osteo
Motion is Life
osteo's Avatar
Oddometer: 1,856
[QUOTE=bend27]
Ben. I typed out a full reply and then before I hit reply I got cut off (I'm in an airport). Maybe someone else will reply before I do.
D
"If it is small enough to eat in a single meal, don't worry about it, hit it!. If it is too large to eat in one sitting, get the hell away from it!" Jack Splash commenting on animals on the trail.
Rally Connex Adventures
Off-Road Adventures
Make It Stick Media
Adventure Has No Destination
08' KTM 450 EXC - The Half Beast -
04' Yamaha TTR250 (for the wife)
osteo is offline   Reply With Quote
Old 02-20-2010, 08:05 AM   #254
CodyY
CodyY's Avatar
Oddometer: 9,505
Old 02-21-2010, 06:50 PM   #255
dirtdiver
Oddometer: 2,039
I want a steering stabilizer. I was thinking of a scotts. Does anyone know if I need new triple clamps or handle bars to make the bolt on work?
Is scotts the right choice?
steve
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver screwed with this post 02-22-2010 at 09:54 AM
Times are GMT -7.   It's 02:17 AM.
