Old 04-23-2013, 08:38 AM   #4186
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Originally Posted by J.Johnson View Post
This came out of my engine drain plug hole. Crap!!! Houston, I got a problem. 7800 miles 378 hours.
Sent with mind control...
Update. So after pulling it apart. I ended up needing -case halves-clutch cover- cylinder-rod-piston -valves-oil pump- and some other misc. crap. But I have a new engine now:). Started breaking in the engine this week. Can't wait to ride the woods this weekend.
Sent with this high tech chingadera!
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 04-23-2013, 06:28 PM   #4187
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 639
Gearset
J.Johnson, what is up with the gearset in the pic? Why does it appear so brown? Did it cook? run low on oil.....never seen brown gears!
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 04-23-2013, 08:14 PM   #4188
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Originally Posted by Honkey Cat View Post
Installed some adv monster led 3300 lumen lights. 3 amps each. Wired it directly to the battery with 1 switch that turns both on and off. With a new battery fully charged it goes dead after riding bike around for an hournwith the led's on. Turn bike off and then try to immediatly try to start it nothing battery drained????
Here is my set up. Super cheap and no load on my battery. I don't know how stout the rectifier bridges are so i put in a back up. At idle the volage is 19 volt DC, off idle the max voltage was 21 volts DC. My LED light bar pulls 45 watts and can handle 9-30 volts DC. I don't know how well this set up would work with 2 LED lights.
(this is on my 300 however, stock stator)
Capt. Egregious is offline   Reply With Quote
Old 04-23-2013, 08:42 PM   #4189
J.Johnson
J.Johnson's Avatar
Oddometer: 85
The gear set is yard art. It is a race transaxle made from bad parts over the years. I have quite a few little creations around here.
Old 04-24-2013, 08:33 PM   #4190
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Yikes! All that after how many hours? That just looks pricey and very involved some how.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-26-2013, 07:26 AM   #4191
J.Johnson
J.Johnson's Avatar
Oddometer: 85
7800 miles and 378 hours. The seals had spun in the case halves. so thats why I needed the case halves. The eng. had been burning oil for a while and it had 40 % leak down.
Oh well now I have a new eng.
Old 04-26-2013, 04:40 PM   #4192
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,332
Finally...
got out today on the 530 after being Winter locked for 5 solid months...felt good and the bike ran great!
At the fish tug docks at Current River in Thunder Bay, ON Lake Superior in the back ground with the "Sleeping Giant" landmark over the top of the rear fender in the background
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 04-26-2013, 04:50 PM   #4193
braymond
Oddometer: 7
2011 530 EXC Repair Manual
Anyone have the 2011 530 EXC repair maunal in digital form want to share it with me? My CD of the manual is not working for some odd reason. Adobe Reader does not want to open up the files.
braymond is offline   Reply With Quote
Old 04-26-2013, 06:27 PM   #4194
Honkey Cat
Tailights Fade!
Oddometer: 1,120
Manual
Pm me your email and ill shoot it to ya.
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 04-26-2013, 08:53 PM   #4195
Navin
Navin's Avatar
Oddometer: 8,087
Help!
Anyone have a cylinder head gasket they could measure the ID of the bore ring on for me? I am bolting up a 570 jug and need to get gaskets, want to see if the stock 530 gasket will work. The marking on my cylinder and head looks like it is 105mm, which will be fine.
Navin is online now   Reply With Quote
Old 04-26-2013, 10:21 PM   #4196
resqd1
Oddometer: 236
Guys I have been looking but cant find this, if it is somewhere and can just point me to it thanks. I have the oem fan kit on my 09 and want to put in an override switch to turn it on when I want before the thermo kicks in if I know I am coming into a hot section of trail. Any write up out there on this?
resqd1 is offline   Reply With Quote
Old 04-27-2013, 06:13 AM   #4197
Navin
Navin's Avatar
Oddometer: 8,087
Nevermind, just got word back the stock gasket is fine.
Thanks.
Old 04-27-2013, 03:21 PM   #4198
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,548
You guys seen this headlight?
Enduro-Tech LED Hi/Low (4500/1800 lumen)
http://youtu.be/jWQkFKjN2LY
http://youtu.be/IlCYtaAadgY
Old 04-27-2013, 04:34 PM   #4199
resqd1
Oddometer: 236
light looks awesome, wonder if it is going to make it to the states
Old 04-27-2013, 04:37 PM   #4200
resqd1
Oddometer: 236
anyone have any pointers?
Times are GMT -7.   It's 07:08 AM.
