Old 04-07-2008, 05:46 PM   #16
ADK
____
Oddometer: 8,232
Roger DeCoster tested that back in the '70s on his works Suzuki.I wonder who originated the idea?
ADK is offline   Reply With Quote
Old 04-07-2008, 08:43 PM   #17
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,190
It wasn't bmw that came up with that one, but the racing team at the time. It's purpose was to eliminate brake dive and I guess it worked pretty well.
Old 04-08-2008, 04:50 AM   #18
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,269
The anti-dive was added partway through the season ('78 I think) so there are a few pictures of the same bike without it. Todd Shuster (fabricator for the B&S race team) made it. The cutaway stacks, though, are not original to the bike in '70s trim. None of the carbureted B&S race motors had stock inward-facing intakes, so that interference wasn't a problem.
Old 04-08-2008, 08:08 PM   #19
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
Butler&Smith 90S
The bike changed every time it was raced by B&S during the '76 season...stock brakes worked at Daytona but took a dump at the second race, Laconia....I'd have to ask Udo if he changed the carb/intake setup during the '76 season or if it was a change made in '77 by Johnny's BMW/Bakersfield......since the bike won one AMA National (Daytona) when fielded by B&S and one AMA National when entered by Johnny, modifications made afte B&S sold the bike to Johnny are historically valid......and BMW must feel the same as they have not returned the bike to its '76 Daytona-winning spec but rather have left it as it was when Johnny quit racing it and put it in the back of his showroom -- where I found it.......and the John Long bike made by Udo/Todd was way faster'n than the old B&S bikes.....it was made up of lessons learned on the B&S bikes....the long tubes on the anti-dive suspension are Cummins pushrods........Bruce
funhouse is offline   Reply With Quote
Old 04-08-2008, 11:33 PM   #20
RGregor OP
Oddometer: 465
Looking at the old pictures of the Daytona race I would say the intake setup of #83 is original.
Rudi
RGregor is offline   Reply With Quote
Old 04-09-2008, 09:23 AM   #21
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
Rudi
when i saw the bike at Riverside '76 it had the carbs sticking out straight, had so much compression that it had to be started on rollers and had long intake stacks........I sent all my historic record to BMW when they got the bike and I now have nothing left to refer to......bruce
Old 04-09-2008, 09:23 AM   #22
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
Rudi
Old 04-09-2008, 10:45 AM   #23
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
Too bad BMWNA pissed away the opportunuty to aquire Pridmore's F750 BMW.
xlcr is offline   Reply With Quote
Old 04-09-2008, 10:50 AM   #24
xlcr
xlcr's Avatar
Oddometer: 4,895
Never seen a BMW with Earles forks?
Old 04-09-2008, 01:56 PM   #25
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
Xlcr
Them's not Earles forks on the 90S race bike...........
Old 04-09-2008, 04:55 PM   #26
xlcr
xlcr's Avatar
Oddometer: 4,895
Never said they were. You asked where the idea originated. Unless you use a floating backing plate, Earles forks have inherent anti-dive geometry.
Old 04-09-2008, 08:35 PM   #27
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
I stand
corrected.....
Old 04-09-2008, 09:50 PM   #28
Wirespokes
Wirespokes's Avatar
Oddometer: 8,190
I was trying to figure out how they prevented dive! Thanks!
Old 04-12-2008, 10:54 PM   #29
RGregor OP
Oddometer: 465
This is an early photo of #83. Look at the carbs, the setup looks the same.
Old 04-12-2008, 11:13 PM   #30
RGregor OP
Oddometer: 465
Don't know if I understood this correctly.
My explanation: The backing plates where the calippers are mounted can be rotated around the axle. They are connected to the lower triple clamp via pushrods. When braking you have a momentum at the backing plate pushing the triple clamp upwards, working against the dive forces of braking that will lower the front. If the geometry of the levers is correct, the two forces could compensate each other.
Times are GMT -7.   It's 09:07 AM.
