06-01-2011, 08:56 PM
#22111 |
Oddometer: 201
rear sprocket removal?
planning on mounting a new 47T rear sprocket tomorrow night... anything special about removing the stock sprocket and adding the new? is it as easy as unbolting, putting on the new and bolting it back up and tightening to proper torque? should i be using new bolts or can i re-use?
06-01-2011, 09:14 PM
#22112 | |
Drunken Squirrel
Oddometer: 2,587
I would advise using new lock nuts when re-assembling... most lock nuts are one time use only (not as effective after you install and remove them once). You can use the same bolts if you have been careful during removal. I used blue loctite and new lock nuts when I changed my sprocket... I am about to change it again soon so I will see how well that held up.
Check out my F800GS Ride Reports: Colorado (F800GS and 640ADV) Sep 2010 Riding to Colorado Solo! June 2011 3000 miles New Mexico and Texas! Arkansas Nov 2009 | Arkansas June 2010 | Arkansas Oct 2010 |
06-02-2011, 06:53 AM
#22113 | |
Oddometer: 201
heres a pic of the sprocket : ![]() also, the chain is covered in this sticky compound. does that need to be cleaned off with chain cleaner and properly lubed, or is it safe to be on the chain during normal riding? (sorry for my ignorance, this is my first chain/sprocket swap!) |
06-02-2011, 07:07 AM
#22114 | |
Let's Ride
Oddometer: 876
Also, I don't clean off the chain lube right away, but just add to it. Others may vary. Nice picture BTW. |
06-02-2011, 07:15 AM
#22115 |
Oddometer: 2,060
MT 43 before and after.
Before ![]() After 970 miles high speed highway, gravel roads, and four wheeler roads. ![]() I think it did OK. Ran 22 psi on highway and 10psi dirt and gravel. Ran loaded with camping gear!
ADV Relay Rider 08 (The Texas Connection) Ride Pooie Ride ![]() Don't stop riding until you get to the crash , you might save it! |
06-02-2011, 07:34 AM
#22116 | |
Harvey Mushman
Oddometer: 1,322
I always clean off that sticky stuff with kerosene and a toothbrush and start fresh with some good chain lube. Don't really know what that stuff is but it sure is a dirt magnet. Good luck!
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" |
06-02-2011, 07:51 AM
#22117 |
Navigate 2 Adventure
Oddometer: 2,106
You have ~2K miles left on that tire.......careful with that 22PSI on the highway though......center knobs may separate/rip at that pressure....
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com Crawdaddy screwed with this post 06-02-2011 at 08:33 AM |
06-02-2011, 07:57 AM
#22118 |
Oddometer: 2,060
What do you recommend on the Highway? The tire got pretty hot on the highway at low pressure!
06-02-2011, 08:34 AM
#22119 |
Oddometer: 2,106
I wouldn't take'em over 15.....lower pressure hasn't been an issue for me.....
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
06-02-2011, 09:06 AM
#22120 |
Oddometer: 59
So can someone please educate me on why the stock tires are called "Deathwings"?
What are the go to tire options for short folk who are not doing hard core trails? Thanks Vince Sent from my DROIDX using Tapatalk
08 WR250R 1st bike! What is newer than a newb? Whatever you call it that's me. Never ridden, but my life list was getting too short so here I am looking for advice, and whatever comes my way! |
06-02-2011, 09:13 AM
#22121 | |
Oddometer: 1,327
The front washes out on anything loose and the rear doesn't hook up. They are actually pretty good on dry pavement(not sure about wet) and hard pack dirt. Everything else...not so much. |
06-02-2011, 09:17 AM
#22122 | |
Lacks Freetime
Oddometer: 4,920
The Dunlop D606 is a good all around tire..jack of all trades tire, master of none. I like 90/10 tires for the riding I do, and use either Kenda Track Master II's or Pirelli XCMH's. Both are great in the slippery type stuff I mentioned above, and have good predictabilty.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
06-02-2011, 09:24 AM
#22123 | |
Harvey Mushman
Oddometer: 1,322
It's an unwarranted meme that people have latched onto when they find a 50/50 tire like the Trailwing isn't as good as a D756 knobby in mud, or a Michelin Pilot Sport on pavement. I've actually found it to be a very good 50/50 tire, exactly what it was designed for. I've ridden it in mud, sand, gravel, rocks and pavement and has performed decently everywhere, with the understanding that it's a compromise tire. Last weekend I rode 160 miles of all pavement, mostly narrow twisty single lane roads and I managed to get all the way to the edge on the front tire (no "chicken strip" ) but still had a ways to go on the rear...I'll replace it with a more dirt-oriented tire, but that's because I ride it 90/10 dirt to pavement.
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" HardWorkingDog screwed with this post 06-02-2011 at 09:33 AM |
06-02-2011, 09:31 AM
#22124 |
Lacks Freetime
Oddometer: 4,920
I know some people like them, but they do not get a bad wrap from out of thin air. It comes from people having a bad experience with them. I had full intentions on leaving mine on, and not buying new tires right away, as seeing that I just bought a whole new bike.
That one ride, that I went on, before I took them off, was enough for me to decide they were hazardous. I slid out, and went to the ground, a couple times on that ride...on trails I ride every weekend. The tire did not do what I wanted or needed it to do. That is why I took mine off, and not because of anything I read on the internet. I decided to check the durometer of the compound. Sure enough, it was 10 duro higher than the Kenda or Pirelli's. Harder compound, less grip. Plain and simple.
06-02-2011, 09:38 AM
#22125 | |
Oddometer: 1,478
