Old 12-01-2011, 04:55 AM   #25846
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
FMF Quiet Core Insert...
I have the FMF Power Core 4 slip-on on my WR-R and have been well pleased with the performance boost. The thing is loud though!
This "Quiet Core Insert" by FMF that is supposed to tame down the noise, but I've also read reviews from users complaining of engine overheating with the quiet core.
I'd be very interested to hear from anyone with experience with this insert on a WR?
GSBS is offline   Reply With Quote
Old 12-01-2011, 05:28 AM   #25847
big-t
Oddometer: 490
"Cranks but doesn't fire" seems most appropriate.......glad the bike is so easy to bump start......then, after a short bit of riding, it'll crank over all day without issue.......
Every once in a while we get a car towed in with a no start/hard start condition like you describe and often the only problem is the throttle body needs the cleaned ....freaking amazing that a little bit of grunge around the flapper valve can cause that much of a problem
Might be worth checking...
big-t is offline   Reply With Quote
Old 12-01-2011, 06:00 AM   #25848
Krabill
Krabill's Avatar
Oddometer: 4,895
Originally Posted by HighFive View Post
2011 FE390
I can see a trip to rancho highfive in my near future
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 12-01-2011, 07:02 AM   #25849
rydnseek
rydnseek's Avatar
Oddometer: 5,888
Originally Posted by Crawdaddy View Post
Ok, so my bike was getting harder and harder to start.......figured the stock battery was on it's last legs and changed it out.......same deal with new battery so that wasn't the issue...
Here's where it gets weird, once I get the initial bump start out of the way the magic button performs effortlessly the rest of the day......let it sit overnight......repeat process - bump initially then use the button reliably the rest of the day.
Stator?
Hey Tom & Scotty - I bought a small vacation home in Bullhead City......looking forward to rides between Bullhead and Sedona/Prescott.....I was over there all of last week.......plenty of nice/desert single track to be found....
Sounds like a battery, to me. It slowly drains.. won't hold a charge, but when running, will charge up for short term sits.
Congrats on the Az home buy! We've got another riding buddy, Tim, who lives there. There are a lot of great rides all around there.. good riding area! You'll want to get high fast in the summer, but for most of the year you can get in a lot of great riding.
rydnseek is offline   Reply With Quote
Old 12-01-2011, 07:18 AM   #25850
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,271
Oops!
Rē has another stablemate. Como se dise'.....Threesome?
I gave up hope that Chadx would add one of these to his Montana Mountain Rentals. Had to take matters into my own hands.
2011 FE390
So....what's it like?
Naaaaahhh.....you don't want to know.
HF
I thought you were buying a Tenere about this time last year. Whatever happened to that potential purchase?
Congrat's on the Berg BTW.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 12-01-2011, 07:27 AM   #25851
k1973
k1973's Avatar
Oddometer: 100
Oops!
2011 FE390
So where did you pick that up at? I ask because that picture looks an aweful lot like TJ's Cycle here in Austin.
Anyway, nice ride. I've been debating between the WR250, FE390, or another KTM.
-k
2007 Triumph Speed Triple
2010 KTM 990 SM-T
k1973 is offline   Reply With Quote
Old 12-01-2011, 08:02 AM   #25852
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 615
voltmeter?
Get a voltmeter from www.advmonster.com inmate Sanjoh in Vendors too. If you we're watching it every once & a while you'd know if the battery or stator are starting to go by checking the reading before you start & while running. I'm guessing throttle body cleaning/adj too but please post your results.
"Four wheels move the body,
Two wheels move the soul." http://ridingacross.com/
Three move you & the dog!
Cromoth is offline   Reply With Quote
Old 12-01-2011, 08:16 AM   #25853
coresports
coresports
coresports's Avatar
Oddometer: 329
winter outside....wr inside! not sure if this is why i am single or because i am single, either way i figure this is a much better place to work on it than the garage, haha
coresports is offline   Reply With Quote
Old 12-01-2011, 08:18 AM   #25854
Ed@Ford
Oddometer: 1,681
[QUOTE=rydnseek;17419442]Sounds like a battery, to me. It slowly drains.. won't hold a charge, but when running, will charge up for short term sits.
Try this: Give it a key on....listen for fuel pump to run a second or so...key off...repeat three time....after 3 times, then hit the starter.My guess is your fuel pump is not prepressurizing the system properly. When cars do that the problem is an "anti drainback valve" that is rotted, fallen off or dirt in it. Happened a LOT on early 80's Fords. You could buy that part but it was a devil to replace, as you had to drop the tank and pull out the submersible fuel pump. The suggested trick pretty much solved (covered up) the problem. I'll guarantee that part is NOT available or replaceable on the yamaha. Also, if yours is a 2008 model, it may be a sign that your fuel pump is going bad. If you look at the documents on that '08 fuel pump issue, you'll find ALL '08s have the crap pump.
Ed@Ford is offline   Reply With Quote
Old 12-01-2011, 09:15 AM   #25855
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,275
That's what I thought to........but I ran into the same issue with a brand new battery.....
Please send me an email and copy Tim.......I'll look him up next time I'm out there......
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is online now   Reply With Quote
Old 12-01-2011, 09:18 AM   #25856
bigdon
Oddometer: 2,681
Be sure and make sure your new battery is good.
I spent tons of money on a DR 650 because of a new battery that was not good!
Pissed me off big time!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is online now   Reply With Quote
Old 12-01-2011, 09:19 AM   #25857
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,275
[QUOTE=Ed@Ford;17419946]
Thanks, I'll try that.......it is an 08 model......been steady as a rock for ~13K miles......
If it was the fuel pump wouldnt it consistently operate that way? Seems like it must be something with the starter motor/stator because it fires immediately with the magic button on subsequent starts after the initial wake up bump......
Old 12-01-2011, 09:21 AM   #25858
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,275
Originally Posted by OSU View Post
what is the weather like down there in AZ around December I want to get out of the cold weather here in Oregon for Christmas break haha.
High 70's mid day......
Old 12-01-2011, 09:26 AM   #25859
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,275
I'll try the throttle body cleaning........that would be a welcome relief if it was something that minor......
I guess I need to remember to fall/crash.......to the left
Old 12-01-2011, 09:32 AM   #25860
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,275
2011 FE390 So....what's it like? Naaaaahhh.....you don't want to know. HF
VERY nice.....congrats......
Perhaps "my" WR is starting to act up because it's jealous of it's new stable mate
09 300 XCW.....with AZ. street plate.
Times are GMT -7.   It's 11:24 AM.
