Old 01-21-2012, 01:37 PM   #26611
dhally
Hammerhead
dhally's Avatar
Oddometer: 2,272
Originally Posted by bhd1223 View Post
Eh, I've picked up the WR with my PMB rack with "just" the 4 bolts holding it and it's still straight and nothing broke. Do you really carry THAT much crap? I doubt you'll be experiencing much shear force on the bolts but I could be wrong. I mean, the suspension does work in an up-down motion, right? The way you show your items in that pictures having stuff over the edges will help prevent those side to side movements that would be most likely to damage the bolts. I think you've be find but don't take my word for it.
I'm not too worried about the vertical forces either. I guess the worst case would be falling over with the bags hung up on a tree or rock. I haven't even taken the fender off to see how the four bolts would attach. Maybe the bolts could be upsized.
I do want something more streamlined than the BBQ rack type, so it won't get in the way when trail riding without a rear bag.
WR250R
Sherco 300i
Tiger 800 - FOR SALE
dhally is offline   Reply With Quote
Old 01-21-2012, 01:42 PM   #26612
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,123
Originally Posted by leftystrat62 View Post
Taking a quick look underneath,it seems that a bolt may be used to go into the frame which looked to be threaded-is that the case-or does it require a nut & bolt?
Would anyone know what type of bolts are used underneath,and how long?
Mine bolts up front, but the back of the skid plate has ears that fit on the cross brace near the shock linkage. There are no rear bolts on mine.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-21-2012, 03:35 PM   #26613
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by DougZ73 View Post
M6 X 1.0, ~ 15-20 mm
mucho gracias senor
leftystrat62 is offline   Reply With Quote
Old 01-21-2012, 06:20 PM   #26614
johnnyadventurepants
johnnyadventurepants's Avatar
Oddometer: 492
Hey guys, need help. I can't get one of my seat bolts out. It is half way out and it won't come out any more no matter how many times I turn it. It kind of flops around a little so I'm thinking that the metal threaded insert in the plastic seat pan came loose. What can I do? Just cut the head off the bolt and go from there?
2008 WR250X/R
johnnyadventurepants is offline   Reply With Quote
Old 01-21-2012, 06:44 PM   #26615
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,226
Think you'll need to cut it. Watch the heat if you grind it.
Waiting for more info........ I'm sure this has happened before.......
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 01-21-2012, 06:52 PM   #26616
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 379
Question
Probably just has tension on it.
Try snapping small locking pliers onto, then turn counter clock wise and pull at the same time.
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 01-21-2012, 07:12 PM   #26617
bhd1223
bhd1223's Avatar
Oddometer: 294
Is the other one is out and the insert pulled out of the seat then you should be able to lift the seat off. Then you can deal with the bolt and insert. Check this before anything. If not cut the head off the bolt, pull seat off, twist out remaining part of bolt, and replace the bolt.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 01-21-2012, 07:47 PM   #26618
Oddometer: 492
Well I ended up cutting the head off and I got the seat off. I still can't get the other half of the bolt out! My gut tells me that all this bullshit is because the seat fit is so tight with the IMS tank on. I push forward on the seat while I try to get the bolts started and I might have angled the bolt? I can turn the bolt round and round with a small vise grip but I can't tell what's going on with the metal insert because I can't see anything.
2008 WR250X/R
Old 01-21-2012, 08:07 PM   #26619
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
(hopefully) a quick question for you guys..
I just bought an FMF Megabomb, Q4, and FMF programmer. I'm planning on gluing the airbox door open. Using the settings most folks recommend around here, do I need to worry about running lean/burning valves, or anything else bad? If so, how do I know if I'm doing it?
Read another way, is there a need for me to get the bike to a tuner, or can I set and forget, once I find some settings that perform well?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 01-21-2012, 08:26 PM   #26620
AZ TOM
Oddometer: 3,864
Find your settings that start & run well & ride,ride,ride
AZ TOM is offline   Reply With Quote
Old 01-21-2012, 09:47 PM   #26621
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,727
You'll be good to go. My Dyno runs with that combo indicated no danger of running too lean throughout the range. More of a problem with "too rich" particularly in the low rpm range. And the FMF unit does not provide a way to adjust fuel off idle & then some.
Let her buck!
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 01-22-2012, 09:04 AM   #26622
bigdon
Oddometer: 2,565
Originally Posted by dhally View Post
Are the racks with 4 bolts and spacers strong enough to carry a medium duffel over rough terrain at high speeds without bending the bolts? The OEM rack looks like it attaches more securely, but is it necessary?
Here's how I used to load the KTM, it would be nice if I could carry close to this much.
I have one of the 4 bolt racks on my WR. I have carried a 21# camping bag for probably 1,000 miles of dirt and gravel along the TART and the TAT with no problems! I hope I did not Jinx myself.
It has not all gone smoothly and the rack is still straight and tight!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 01-22-2012, 11:11 AM   #26623
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,347
...anyone out there have an OEM muffler shield they want to get rid of...cheap?
I might be offing my new Yosh RS2 pipe...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 01-22-2012, 11:46 AM   #26624
flatboarder
flatboarder's Avatar
Oddometer: 276
Cannot tell about any additional racks, but I am sure, if the KTM could, the WR250R can do as well. Those old KTM LC4 used to have rear frames that were rather weak, no matter whether it was the steel version or the aluminium. And if the rear frame would hold up, the rear frame mounting nuts (welded to the main frame) broke. I had two of those LC4 and there were issues with both of them, even without putting any big additional load on the rear frame. I am very confident, the WR with its durable and solid rear frame installation would take up a bigger load than those old LC4.
Phil
flatboarder is offline   Reply With Quote
Old 01-22-2012, 12:21 PM   #26625
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,957
Trade a stock heat shield for a Yoshi exhaust..I'll take that trade.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Times are GMT -7.   It's 09:36 AM.
