Old 04-06-2012, 08:13 AM   #27931
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by blown7.3lps View Post
crawdaddy:
would i have to change out my handle bars on either the scotts or GPR kits? they both look like the same new price of $495 for a full kit. on the GPR site i only see an option for fat bars.
I'm not sure but my hunch is "yes".......which is fine......the stock bars/mirrors are crap.......they belong on a Schwinn Stingray
I put on a Tusk Chub Bar for ~$40.....beefier/higher bend: http://www.rockymountainatvmc.com/p/...7/-/19027/Tusk
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 04-06-2012, 10:11 AM   #27932
what broke now
Petroleum Brother
Oddometer: 1,379
Originally Posted by 10Cup View Post
Gundy, just an educated guess but it is most likely the fuel pump. Never heard of a bad injector or throttle body but several have had fuel pumps go out or just loose necessary pressure. I replaced mine when it got hard to start and totally cured it.
For some perspective on this pump thing, over on the Husaberg 70 deg. thread, somebody just posted up they're on pump #3 on a 2010 450. We're not doing too bad with the wr.
what broke now is online now   Reply With Quote
Old 04-06-2012, 12:11 PM   #27933
boogn1sh
Motorcycle crash-tester
boogn1sh's Avatar
Oddometer: 363
Originally Posted by DougZ73 View Post
That is not how you hit a tree..this is how you hit a tree.
Obviously, you're not a golfer...
http://adventuresubaru.com
boogn1sh is offline   Reply With Quote
Old 04-06-2012, 01:04 PM   #27934
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by Crawdaddy View Post
Welp, the exercise in frustration continues.......bike will bump start, then once warmed up will fire right up with magic button every time....... but it won't cold start.....
Not the spark plug though I thought for sure that would be the issue once I extracted the old plug......it was fugly
Not the coil (checked out at 1.5 w/in spec)
Not the side stand switch
Not the air cleaner
How hard is it to get at the throttle body/injectors?......wasn't clear to me?
Geez, maybe it is the valves........but woudnt it be hard to start EVERYTIME if valves were the issue?
Shop just called and said they did a leak down test and I'm loosing 90%......could be stuck valves?......could be bad valve seats/rings/piston?.......they want to check valves but are already talking about a possible rebuild if the valves aren't the issue.......seems odd to me?........once bumped the bike runs fine and once warmed up the bike starts easily off the magic button and runs fine with no apparent loss of power?
Yamaha shop speculates that once warmed up the leakage gaps are sealed which is why it runs fine AFTER the morning bump......bike has ~13K miles on it.....
Old 04-06-2012, 01:20 PM   #27935
bhd1223
bhd1223's Avatar
Oddometer: 294
Sounds like it may be the time to add a big bore if you choose to rebuild. I'd shy away from doing or having any work done until the actual problem is found though.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 04-06-2012, 01:24 PM   #27936
what broke now
Petroleum Brother
Oddometer: 1,379
hard to see in your picture, but is that plug coked up, oily, or just black on the electrodes? Good running engines show light gray to light brown on the center insulator, with no black fluffy stuff on the electrodes. Was it starting to use oil?
Old 04-06-2012, 01:27 PM   #27937
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
I hear you, I started reviewing High Five's Big Bore thread (again): http://advrider.com/forums/showthread.php?t=621532
BUT, I'm a rider NOT a mechanic.......I don't profess to have the skill set/patience/tools to do the job myself.......crap, that's a LOT of $$$ I don't have ("2" of my daughters are engaged to be married w/in the next 12 months)
They'll dig into the bike again next Wed......on vacation until then.....hoping it's just the valves......
Old 04-06-2012, 01:53 PM   #27938
bigdon
Oddometer: 2,589
Crawdaddy
My DR 650 acted the same way after I had a high compression piston put on. It would not start when cold unless I jumped it with the truck. They started throwing parts( my money) at the bike. New battery, new starter, etc.
It seemed that I had a weak battery and the new one was also bad. It cost me a small fortune to get bike to start reliably. Once they finally figured out the new battery was weak it would start every time.
The bad part, I rode the bike about five miles from the house and burned a hole in the piston.
We got the head all cleaned up , put new valves in it, and the old piston. I sold it to a Bud that put about 15,000 miles on it and he sold it to another Bud. It's got about 45,000 miles on it now, and still running strong.
Be sure it has a good strong battery on it.
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is online now   Reply With Quote
Old 04-06-2012, 02:29 PM   #27939
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
I tossed the old plug but it seems to me that it was tan around the edges and black, but not oily, on the electrode......never noticed any usage of oil above and beyond......changed it every 3K and left it at that.....plenty in there on last change.....
Old 04-06-2012, 04:09 PM   #27940
Mikef5000
Oddometer: 2,030
Blew my first fork seal (2008 with 6k miles). Is there a preferred brand for replacement? The OEM's have a pretty poor reputation (don't know if it's the seal's fault or the fork design), are any of the aftermarkets known to be better? Seems to be quite a few brands available:
  • All Balls
  • Bike Master
  • Technical Touch
  • Race Tech
  • MSR
  • Tusk
  • Pro X
  • Pivot Works
  • K & L
  • Bikers Choice
A picture of the shenanigans leading up to my first blown seal
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 04-06-2012, 05:18 PM   #27941
Hetzel88
cycles is a mean toy
Oddometer: 170
Check the valve clearances first. A tight valve could be your only problem.
Hetzel88 is offline   Reply With Quote
Old 04-06-2012, 06:01 PM   #27942
debaisley
debaisley's Avatar
Oddometer: 1,426
I always use Tusk seals on all my bikes. for 12$ you cant go wrong. I replaced the stock WR ones with tusks and they have been good for 2 years now , I also use them on all my YZs which get put through some serious abuse.
debaisley is offline   Reply With Quote
Old 04-06-2012, 06:06 PM   #27943
AZ TOM
Oddometer: 3,934
Racetech seals. Well made.
AZ TOM is offline   Reply With Quote
Old 04-06-2012, 06:26 PM   #27944
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,025
I go with Tusk and AllBallsracing products...so far so good.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 04-06-2012, 07:41 PM   #27945
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,322
Just brought our second wrr home today. This one is the evil twin to my mini bike.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Times are GMT -7.   It's 12:47 PM.
