Old 12-23-2012, 04:19 AM   #31996
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Originally Posted by alansz400 View Post
That cover comes off real easy. I took mine off when my site glass was pushed in. Heres what it looks like with the cover off. I reused the gasket and havent had any oil leaks. I wounder if somthing came loose inside the motor and got wedge between the gear and the case?
jrou111,
You might want to replace that gasket anyway If that was caused by some type of impact. The gasket could have a crush zone @ that location and may leak i
f reused. IMHO
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 12-23-2012, 04:26 AM   #31997
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Hey alansz400 do you remember what diameter the site glass or the plug you used for that incident? I wanted to get a rubber plug from the hardware store to keep in my emergency kit if that happens when I'm out traveling.
[QUOTE
[/QUOTE]
Old 12-23-2012, 06:06 AM   #31998
alansz400
alansz400's Avatar
Oddometer: 984
[/QUOTE]
Not sure what size the glass is.
If I had to do it again I would have called for a truck to come pick me up. If that sight glass would have pluged off the oil passage or got stuck in a gear it would have been real bad. The other problem was I didnt know how much oil was in the motor.
alansz400 is offline   Reply With Quote
Old 12-23-2012, 06:47 AM   #31999
RedBallRun
Oddometer: 30
Urgent help needed!
Hi there,
I've a big trip coming up in 2 weeks and being as organised as ever I've realised that I need two new seal guards to protect the front of my swing arms! Tricky in the festive season to find anyone open and then to get the parts out here to darkest Kenya. It might have to be DHL.
So does anyone have a couple of these lying around? Unlikely I know. Alternatively anyone a bright idea how I might fabricate something locally to protect the swing arm? Perhaps securing a strip of steel plate?
Any advice or ideas welcomed!
In the meantime Christmas greetings from Kenya.
All the best
John
RedBallRun is offline   Reply With Quote
Old 12-23-2012, 09:31 AM   #32000
what broke now
Petroleum Brother
Oddometer: 1,429
Originally Posted by RedBallRun View Post
Hi there,
All the best
John
A cleverly cut piece of tire sidewall [ that stuff is tough ] wired or ziptied on?
what broke now is offline   Reply With Quote
Old 12-23-2012, 01:14 PM   #32001
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,963
I use a wine cork in my parts bag, it is a tad oversize but can be whittled down as needed if the sight glass goes. I started doing that after Alan's incident.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 12-23-2012, 06:25 PM   #32002
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Just wondered if you had a estimate diameter so I could get the right size stopper. I only would be using it for extreme emergency, like up in the hinterlands of Canada or Alaska when getting out is your only choice as no tow truck would be affordable even if it could respond. In which case I would plug the hole dump the rest of the oil in a container to see how much was lost then replenish the difference. I do carry a little extra oil for emergencies.(Needed it the last trip north as my engine oil plug came loose).
Or lay the bike over on its left side pull the cover, grab the site glass and epoxy it back in.
ps. Do you remember the original post date or post # of the site glass problem or have a copy of the other picture of the cover with the site glass missing. If yes can you pm me?TNX
TNX for the suggestion I'll probably carry a cork if the rubber stopper idea doesn't work out. I'll get approximate size from measuring the exterior site glass window and alansz400's picture above.
pfy50 screwed with this post 12-23-2012 at 06:49 PM
Old 12-23-2012, 08:40 PM   #32003
ghollaba
Backroads
ghollaba's Avatar
Oddometer: 60
Riders around Tulsa?
Back on a WR250R and feels GREAT.
Any other riders around Tulsa area to meet and get suggestions from?
Stock bike, reading thread to try and get up to speed.
Kinda concerned on either hitting rev limitor or something just not feeling right...
Planning trip to Big Bend in March.... YEESSSS
ghollaba is offline   Reply With Quote
Old 12-23-2012, 09:00 PM   #32004
Strog
Geek on two wheels
Strog's Avatar
Oddometer: 415
Come check out the Oklahoma ADV Riders BS thread. There's several in the Tulsa area and some ride WR250R too.
http://advrider.com/forums/showthread.php?t=420208
Dale S.
Strog is offline   Reply With Quote
Old 12-24-2012, 07:44 AM   #32005
freetors
Oddometer: 952
I'm in the owasso area
freetors is offline   Reply With Quote
Old 12-24-2012, 08:40 AM   #32006
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,246
Not so Merry Christmas....(bikewise)
WR is toast AGAIN ~1500 miles after 290 kit install .......so much for the new firmware from FMF bringing their programmer up to par for the 290 kit?? ......MtnTrails warned me to go with the PCIII but FMF assured me that their new firmware could service the 290 jug/piston......the shop is tearing it down now.......we'll see what they find......
I'm thinking it may be time to leave this WR250R experiment behind and return to my Orange roots with a fuel injected 350 EXC....I've really enjoyed the WR, but blowing up two engines has soured my taste buds.....
Looks like I'll be on The Smoker (300 XCW) the next couple of months.....which isn't so bad
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 12-24-2012, 08:48 AM   #32007
mpatch
Oddometer: 1,032
Not to be a dick but if youre gonna spend the $$ on a big bore kit why not spend an extra couple hundred and get it properly dyno tuned and not have to worry about it?
mpatch is offline   Reply With Quote
Old 12-24-2012, 08:53 AM   #32008
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,246
No offense taken......asking myself the same question......I "cheaped out" up front and it's biting me in the ass now.....penny wise pound foolish (stupid)......
That said, I don't yet have confirmation as to what's causing the lack of compression/~88% blowby on leakdown......maybe I'll get lucky and it's just a bent/stuck valve.....doubtful.....
Old 12-24-2012, 09:21 AM   #32009
ecarnell
ecarnell's Avatar
Oddometer: 394
Sorry about your luck.
Thank you though for re affirming that's its best to keep mine stock!
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is offline   Reply With Quote
Old 12-24-2012, 11:27 AM   #32010
Gany
Oddometer: 356
Sorry to hear your troubles. What was your verdict on the 290 prior to kaboom? Worth the money or would only do it again because you had to?
Gany is offline   Reply With Quote
Times are GMT -7.   It's 01:39 AM.
