Old 02-09-2013, 04:41 PM   #33031
AZ TOM
Oddometer: 4,000
Originally Posted by UtahFox View Post
So I'm going to look at my prospective WRR on Monday. It's a 2011 with 375 miles on it. It has some scratches on it from a low speed fall(s), otherwise it's like new. Are there any things I should look for before pulling the proverbial trigger?
Correctly signed title
AZ TOM is offline   Reply With Quote
Old 02-09-2013, 04:54 PM   #33032
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,632
Originally Posted by Sewerat View Post
I have not had an issue with my pump 30k kms on bike about 20k of that has been with an ims 3gal tank. But I did have a failure with a 2007 versys fuel pump. Died and left me stranded in a parking lot. Same deal just shy of $400
Also had a Kawasaki 650 (2006 ninja 650R) pump fail leaving me stuck in a parking lot about 5 miles from my house. The rare occurrence of pump failures for those bikes seem to have a common trait of the owners running the tank low, often. I certainly did.
swimmer is offline   Reply With Quote
Old 02-09-2013, 05:10 PM   #33033
what broke now
Petroleum Brother
Oddometer: 1,394
@ Duanew1:
Originally Posted by duanew1 View Post
I put a Shinko SR241 on the rear of my WR and I like it. I have another bike with an MT43 on it. The SR241 is at least an inch shorter over all than the MT43 so there is an option. Plus they are pretty cheap. I might could get some pics later if you want them.
Are you running the 3.50 or 4.00 width on that? How's it run on the hiway?
Thanks.
what broke now is offline   Reply With Quote
Old 02-09-2013, 09:47 PM   #33034
skierd
Wannabe Far-Rider
Oddometer: 2,938
How to do a compression test
Decided that before I really truly decide to keep her or not, I better see how the old girl's motor's doing. To that end, its time to do a compression check to see how well the last 43,000 miles have treated her.
Step 1 - start the motor and let everything warm up
step 2 - take the seat, side panels, front wing panels, and gas tank off
step 3 - remove spark plug
step 4 - realize that the compression tester you bought doesn't have a 10mm thread adapter, you know the one you need to do the test
step 5 - Run to every hardware store, auto parts store, and motorcycle dealership in town looking for an adapter, in vain
step 6 - Admit defeat, buy the gauge kit that's 2x as expensive as the one you first bought a few days ago, and return home
step 7 - put the old plug back in, coil back on, and gas tank back on. Start motor again to warm it up again.
step 8 - Pull it all apart again.
step 9 - Thread in the compression tester... and... and...
She's not quite dead, but she's hurting very badly. Best dry compression it could muster is 75psi. Added some oil down the bore, and it spiked to just over 100psi. Spec is 121psi, low of 105, high of 135.
Its not entirely unexpected, as before I put her up for winter she felt a little down on power and had been dirtying the oil faster than normal. I was hoping it was just clutch wear causing the oil to go bad, and that the power thing was just my imagination, but the reality is the motor's old and tired. Glad I found it out not, before I spent a bunch of money on the suspension, but still..
Not sure what to do at this point. Right now, I'm just sad.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 02-09-2013, 09:56 PM   #33035
what broke now
Petroleum Brother
Oddometer: 1,394
Super tight valve clearances might keep them off the seat enough to leak.
That was my old fuel pump you bought, btw, the one I replaced it with took a nap out in the boonies. Can't win...
Old 02-09-2013, 09:58 PM   #33036
skierd
Wannabe Far-Rider
Oddometer: 2,938
If it comes down to it, do you want it back?
2008 Yamaha WR250X
Old 02-09-2013, 10:10 PM   #33037
Buzzbomber
Not Dr. Who...
Buzzbomber's Avatar
Oddometer: 1,268
Why?
Buzzbomber is offline   Reply With Quote
Old 02-09-2013, 10:30 PM   #33038
what broke now
Petroleum Brother
Oddometer: 1,394
Nah, If you sell the bike just say you know the pump has been tested extensively and works fine...
Old 02-09-2013, 11:38 PM   #33039
skierd
Wannabe Far-Rider
Oddometer: 2,938
Originally Posted by Buzzbomber View Post
Why?
Because I'm not sure what to do with it at this point?
I don't know if I can just throw a new piston and rings in it, or if I have to have the cylinder cleaned up too, then have the valve seats (at least) cleaned up, and roll on, or if its going to require a lot more than that. This would be my first top end replacement on any motor I've ever done.
*edit* spent most of the night not relaxing, and researching. Seems you can get by just cleaning up the cylinder since its Nikasil to deglaze it, and go from there. New piston, rings, pins, gaskets, etc ordered, along with a bunch of other stuff. Looks like this minor winter refresh is going major...
2008 Yamaha WR250X
skierd screwed with this post 02-10-2013 at 04:00 AM
Old 02-10-2013, 04:53 AM   #33040
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,410
Best way (best set up)
for removing all the junk off the rear fender sub-frame. Just helping my brother to get this bike more DS ready. Would like to remove the turn signals, brake light and plate holder ass. I do need to keep it road legal just would like to find a great kit to "fix" this great little bike. Any help would be great as i dont know much about this bike.
thanx
We have removed the stock exhaust and the exhaust valve are there any mods to remove the crap all over the air box on this bike?
ebrew screwed with this post 02-10-2013 at 05:02 AM
ebrew is offline   Reply With Quote
Old 02-10-2013, 05:14 AM   #33041
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 759
Originally Posted by what broke now View Post
@ Duanew1:
Thanks.
I am using the 4.0 on the rear. I really have not done that many highwway miles with it as I have not been riding that much lately. It did feel fine when I did though. I have it set up like you would a MT43 with rim locks and about 12psi. It took a bit to get used to the feel of them but they do have great traction. It is a very soft tire and very easy to mount.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 02-10-2013, 06:58 AM   #33042
10Cup
10Cup's Avatar
Oddometer: 2,641
If you decide to have the cylinder brought back up to spec. I have used Millennium technologies in the past they are very good and not too expensive. Send them your piston/cylinder and what you want for clearance and it will come back spot on like brand new.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 02-10-2013, 08:57 AM   #33043
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 704
Athena
IBA #33260
cablebandit is offline   Reply With Quote
Old 02-10-2013, 09:41 AM   #33044
Buzzbomber
Not Dr. Who...
Buzzbomber's Avatar
Oddometer: 1,268
I mis-read the original post somehow......serves me right for being up still at 1 am.
Old 02-10-2013, 09:43 AM   #33045
KansasBob
KansasBob's Avatar
Oddometer: 515
I did some quick math.......... 40K miles at an average overall speed of 40 mph, with and average rpm of 8k........... works out to around a half a BILLION cycles of the piston. Amazing really. If you count each pass up and down the rings have followed the length of the bore a full Billion times.
Looking at it another way............. The stroke x 2 = .35170604 feet, so it only takes about 15012.5 revolutions of the crank for the piston to travel a mile in the bore......... so in 40,000 miles, on the bike, the piston travels approximately 33,300 miles down the bore.
KansasBob screwed with this post 02-10-2013 at 11:24 AM
KansasBob is offline   Reply With Quote
Times are GMT -7.   It's 10:50 PM.
