Old 02-12-2013, 07:24 AM   #33091
30Bones
30Bones's Avatar
Oddometer: 4,648
Originally Posted by SkidMarx View Post
I run a 12 or 13.
Was running the 13 when I got the damage. Stock chain was not that old, but It got kinky when I let the maintenance slip. Kinks will eat that slider faster than anything.
Unsure if you have read BigDogs mods, but he is not a fan of the smaller front sprockets and has a good theory behind it. He runs a 14 now and changes gearing on the rear. http://www.bigdogadventures.com/WR250R.htm
30Bones is offline   Reply With Quote
Old 02-12-2013, 07:29 AM   #33092
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,753
Originally Posted by 30Bones View Post
People with swingarm damage, what front sprocket are you running? 12 or 13?
I am running the stock 13 front with a 50 rear. Have never used a 12, and wouldn't.
Originally Posted by Mr. Fisherman View Post
I had a 13, switched to a 14 and came up with a chain adjust and check tech that has worked well so far.
And that chain adjust and check tech would be...?
In my case I think the damage was caused by
1. Chain/sprocket wear, leading to excessive slack.
2. Several weeks exposure to salt air, 1000's of miles of sand trails, and one spectacularly impassable mud pit that caused the rear wheel to completely lock due to mud packing around the swingarm, chain guide and front sprocket area. Grit and water got past the x-rings and eventually caused several links to kink up.
3. Riding with the above conditions with a full load of camping gear on extremely rutted/washed out dirt roads, where g-outs and 6" potholes are as common as cardon cacti.
The loose and kinked chain tends to wrap upward as it leaves the bottom of the front sprocket under acceleration, add in the upward movement of the rear wheel under a g-out which further pulls the chain toward the bottom of the swingarm...
I'm sure you can get swingarm damage in other situations--say a too tight chain--but it is very clear that the damage in my case was NOT caused by a tight chain. (i.e., much respect to BigDog, but my data simply doesn't jibe) I tightened up the chain slack, lubed the heck out of it, and got home with no more significant damage.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog screwed with this post 02-12-2013 at 07:43 AM
HardWorkingDog is offline   Reply With Quote
Old 02-12-2013, 07:40 AM   #33093
AZ TOM
Oddometer: 4,044
Utah Fox good luck on your trip. If you can set the shock sag to 4+ inches, should help with the height. Seat Concepts will be a big plus. I am here in Prescott AZ, if you have any issues along the way on your trip just give a shout & I will give any help I can. Good luck & ride safe.
AZ TOM is offline   Reply With Quote
Old 02-12-2013, 07:42 AM   #33094
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,753
In case anyone is in the market I got this email from rockymountainatvmc.com this morning about clearance prices on a battery.
To our valued customer: This email has been sent to let you know of a machine-specific clearance offer:
AGM No Maintenance Battery clearance items are now available in limited quantities for your 2009 YAMAHA WR250R at special clearance pricing!
Clearance price: $23.99
Reg Price: $54.99
Hurry! Clearance items move quickly and are limited to stock on hand.
http://www.rockymountainatvmc.com/p/...-Battery-CTZ7S
swimmer is online now   Reply With Quote
Old 02-12-2013, 07:50 AM   #33095
TwilightZone
Oddometer: 3,116
>"AGM No Maintenance Battery clearance items are now available in limited quantities for your 2009 YAMAHA WR250R at special clearance pricing! Clearance price: $23.99"
Hmm... the online reviews for this battery are not very good.
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 02-12-2013, 07:58 AM   #33096
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,753
I didn't look into it at all just passing it along. I bought a new battery about a month ago so it's of no interest to me.
Old 02-12-2013, 08:09 AM   #33097
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,790
Chain adjust tech
For those interested.
I dug it up from back there in the thread...
So my smart friend Luke came by to help me change my chain and sprockets.
I owe Bigdog a big thank you! 14 50 gearing is the shizzle! Shifting into 6th at 75 indicated and 6th gear pulls hard... me likey!
Check out the difference on the rear...
I had feared that my chain may have gotten into my swingarm and those fears were confirmed. I had planned ahead and bought one from a guy that was parting his bike out. Good thing...
Then Luke, the smart one... discovered that the factory spoke wrench was am amazing tool.
According to the TSB M2008-20 the chain slack should be 165 MM back from the front chain tensioner with 36 lbs of upward force on the chain and the slack between the chain and the swingarm should be between 8 and 13 mm. Well guess what... that magic spoke wrench at the narrow part is just about 11MM and at the wide part it is 16.09mm so if the narrow part of the tool doesn't touch and the widest part just does, you are good.
I always have this tool with me so these checks will be quick and repeatable from now on. Oh, and 165mm back from the front chain tensioner is just about inline with the mud flap as mentioned earlier.
Easy Peasy, repeatable and consistent. It takes the mystery out of this adjustment for me. Luke also showed me how to use a straight edge against the sprocket to align the chain. This was simple and I wasn't surprised to see a slight difference between my adjuster markings from side to side when we were done.
Thanks Luke for the help and the tutorial and Thanks Bigdog for the advice on the 14 50 gearing. I am stoked to get on my next adventure
The TSB says to do this with the bike on the side stand. I did mine with the rear tire in the air.
Mr. Fisherman is offline   Reply With Quote
Old 02-12-2013, 08:19 AM   #33098
30Bones
30Bones's Avatar
Oddometer: 4,648
I am digging your trailer setup Fisherman
Old 02-12-2013, 08:26 AM   #33099
HardWorkingDog
Harvey Mushman
Oddometer: 1,753
Thanks! The spoke wrench gauge is a good idea.
But...
"The TSB says to do this with the bike on the side stand. I did mine with the rear tire in the air."
That is a HUGE difference. I suppose there could be a strange coincidence where the relation of the chain/swingarm pivot/sprockets is the same in both cases, but I'm not willing to gamble on that one. Have you checked the slack with the bike on the side stand, in neutral? How does it compare to your slack with the bike on a center stand, rear wheel fully lowered?
"Coffee first..."
Old 02-12-2013, 09:50 AM   #33100
Mr. Fisherman
PROUD 2B Riff Raff!
Oddometer: 10,790
But...
Good catch... Yes, I do this with it on the side stand. By the way, in my case it was the same on the side stand as on the lift in the chock, but on my trips of course it is always on the side stand.
30bones, I really like the trailer for commuting and for long trips.
Old 02-12-2013, 11:13 AM   #33101
30Bones
30Bones's Avatar
Oddometer: 4,648
I love the idea of not spending all this $$ on bike specific racks/luggage. All that would need changing is the mount for whatever bike (I assume). Price it kind of high, but not too bad if you consider what a full line of wolfman or giant loop gear would run.
Old 02-12-2013, 11:25 AM   #33102
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,161
Kenda 270's
I may be getting these tires soon and making the WRR into a part time commuter bike. The front listing for these tires on RMATV are 2.75, 3.00, & 3.25 X 21". Stock tire size is 80/100-21. Rim is a 1.6 X 21".
Which front tire size to get??
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 02-12-2013, 11:25 AM   #33103
UtahFox
UtahFox's Avatar
Oddometer: 446
Thanks Tom. I did bring my toolkit, so hope to set that sag before I take off. I weigh about 150 and my bag will be kind of heavy; I'm going to have a 1 & 1/2 gallon Rotopax in there + about 10 pounds. Would that change the amount of sag I should set? I'm not going to do any dirt on the way home as I'm really not set for emergencies (flats) yet, just a tiny amount of touring since I'll be in the area.
Dave
P. S. Oh, and the gear I wear is pretty heavy too, maybe 10-15 pounds (Rukka jacket, BMW city pants, Gaerne boots, and my Shoei).
P.p.s. what about break in? The bike now has 500 miles exactly, and the owner gave it to me with a fresh oil change. I have around 700 miles to get home. Should I ride the piss out of it or baby it? Should I get the oil changed again on the way home?
UtahFox screwed with this post 02-12-2013 at 11:37 AM
UtahFox is offline   Reply With Quote
Old 02-12-2013, 11:49 AM   #33104
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,753
I'd just ride it normally and not worry about changing the oil on the way home.
Old 02-12-2013, 11:50 AM   #33105
burtonrider3889
Oddometer: 862
Here it is, my new WRR. Picked it up 120 miles from here, where I'm staying with my parents in Palm Springs. Heading back up to SLC in a week or so, via Death Valley and central Nevada and Utah. More pics later. Fun ride!
Congrats! Sounds like a great break in ride.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Times are GMT -7.   It's 01:54 AM.
