02-12-2013, 11:25 AM
#33106 |
Lacks Freetime
Oddometer: 4,913
Kenda 270's
I may be getting these tires soon and making the WRR into a part time commuter bike. The front listing for these tires on RMATV are 2.75, 3.00, & 3.25 X 21". Stock tire size is 80/100-21. Rim is a 1.6 X 21".
Which front tire size to get??
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
#33107 | |
Oddometer: 416
Dave P. S. Oh, and the gear I wear is pretty heavy too, maybe 10-15 pounds (Rukka jacket, BMW city pants, Gaerne boots, and my Shoei). P.p.s. what about break in? The bike now has 500 miles exactly, and the owner gave it to me with a fresh oil change. I have around 700 miles to get home. Should I ride the piss out of it or baby it? Should I get the oil changed again on the way home? UtahFox screwed with this post 02-12-2013 at 11:37 AM |
02-12-2013, 11:49 AM
#33108 |
armchair asshole
Oddometer: 2,539
I'd just ride it normally and not worry about changing the oil on the way home.
02-12-2013, 11:50 AM
#33109 |
Oddometer: 321
Congrats! Sounds like a great break in ride.
2012 WR250R 2007 SV650 1984 XL350R 2002 CR80R |
02-12-2013, 12:22 PM
#33110 | |
Riding is my passion
As for the front tire size, I think the 3.00 should be fine. I believe that is the direct cross over from the 80/100-21.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
02-12-2013, 12:31 PM
#33111 |
Oddometer: 1,947
>"Is there any way to display a tach, or do I need to install an add on computer for that?"
Not sure what you'd need a tach for on a thumper... heck, just ride it. If you hit the red line the engine will cut out, pretty soon you will find out where the power is in the rpm range. That said, if you go into the diag mode to set the CO level, it will display a tach... but only until you turn the key off, then the tach goes away. I rode with mine on for a bit though and found out heck, the engine is making a lot of rpm! >"Thanks! The spoke wrench gauge is a good idea." I think the spoke wrench is likely wrong if your sprockets are not the stock size. I have my son sit on the bike and check the chain for clearance in the mid range (swing arm compressed to level - max distance). I use that to determine the settings, just tight in the mid range. I am running 14x50 sprockets and the guide is lasting, probably need to replace it in 8 to 10 thou miles.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
02-12-2013, 12:39 PM
#33112 | |
Lacks Freetime
Oddometer: 4,913
![]() I'll look into the Shinko's. How are they in the sand, if you know??
02-12-2013, 02:14 PM
#33113 |
Oddometer: 2,364
Dave, would not worry on oil change on way home. The rear spring is pretty stiff, stock & I would set at 4 inches for the weight. Also make sure it has at least a 13 tooth front sprocket & for your ride a 14 might even be better. WR 250F sprockets will fit as well. Your Seat Concepts seat will be a big plus on your ride. Have a great ride.
02-12-2013, 02:39 PM
#33114 | |
Offroad, the Kenda 270's & Shinko 244's pretty much handle all off road terrain the same if not a slight edge to the Shinko's since their lugs are larger and more substantial.
02-12-2013, 05:04 PM
#33115 | |
Lacks Freetime
Oddometer: 4,913
02-12-2013, 05:32 PM
#33116 |
Oddometer: 987
02-12-2013, 06:26 PM
#33117 |
Oddometer: 343
The rear shock on this bike is such a 'shocker' I don't know what to do about it.... I live in Australia and can't easily send it off to the guy in the USA for repairs. Does anyone know what the problem with it is that needs fixing? When I come off speed bumps or whatnot the bike bounces at the rear and feels really unsafe. It's even worse when I'm 2-up.
If I know what the problem is perhaps I could order the parts online then save a bit of money at the suspension shop. Alternatively is there an Ohlins option that anyone knows about? |
02-12-2013, 07:15 PM
#33118 | |
Random Hero
Oddometer: 1,608
I've owned my WRR for about a month now, and between working non stop, building a house, and our 6 month old son, I haven't had too many opportunities to ride it. It managed to put in 200+ miles under me on Sunday exploring around the great state of Ohio with Alansz400.....a few highlights: ![]() ![]() I don't know why i didn't buy one of these things a long time ago...
Never turn your back on Fear. It should always be in front of you, like a thing that might have to be killed. |
02-13-2013, 12:00 AM
#33119 | |
Wannabe Far-Rider
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
02-13-2013, 12:09 AM
#33120 |
Wannabe Far-Rider
I've recieved a PM about this, and its gotten me wondering...
How long do you think the WR250R/X motor should last before needing an overhaul? Mine's sitting at just under 43,000 miles, and looks like it needs a top end (might just be a piston, rings, and valve adjustment, might require head work) and frankly I always figured I'd have about 40-50k miles before it needed work so its in the correct range. If yours makes it to 45,000, would you be disappointed? Ok with it? Happy it made it that long (crawdaddy )?
