Old 02-23-2013, 06:46 AM   #33331
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,125
Originally Posted by bash3r View Post
I did all the calcs at first.. then said forget it.. am I doing this or not!! But do spend wisely, it's *only* a motorcycle
That's what I tell myself too. Am I doing this or not...
I never regret it either.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-23-2013, 07:50 AM   #33332
viper770
viper770's Avatar
Oddometer: 575
Thumb
well everyone has defferent riding styles and needs so same set up will not work for everybody
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 02-23-2013, 08:18 AM   #33333
KansasBob
KansasBob's Avatar
Oddometer: 515
Does anyone know why Yamaha filled the needle bearings in the rear suspension linkage "rocker" with plastic material rather than grease? It's the first time I've seen it done that way.
The only thing I can think of.... is that there isn't very much travel in those bearings? It doesn't make sense to me, because there isn't any room for lubricant, and if water makes it's way in I would think they would be prone to rust more quickly?
KansasBob is offline   Reply With Quote
Old 02-23-2013, 08:50 AM   #33334
viper770
viper770's Avatar
Oddometer: 575
did you go ahead and fill it with grease?
2012 YAMAHA WR250R
Old 02-23-2013, 09:28 AM   #33335
UtahFox
UtahFox's Avatar
Oddometer: 446
My problem is I need it set up for ALL styles :)
UtahFox is offline   Reply With Quote
Old 02-23-2013, 09:46 AM   #33336
SkidMarx
SkidMarx's Avatar
Oddometer: 1,969
It's a porous plastic that holds and releases the lubricant as needed. Best if you leave it there, but not the end of the world if you dug it out and replaced with a good grease.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 02-23-2013, 09:52 AM   #33337
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
This type of needle bearing is used on a lot of later-model Yamaha motorcycles at the rear suspension.
Probably because the bearing functions just fine with that number of rollers spaced apart via the needle cage.
Less rollers spaced with a cage are lighter and have less friction.
The plastic-like material is lighter than a steel cage.
You can't pack it with a large amount of grease, but it'll hold grease that will keep the bearing alive just fine as long as you do what needs to be done periodically no matter what bearing is used:
Take it apart for a cleaning and greasing, inspecting the bearing, collars, and seals.
Also important to clean and grease the bolt that goes through the whole works.
YZEtc is offline   Reply With Quote
Old 02-23-2013, 09:54 AM   #33338
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
I've read about guys digging at it thinking it was "hardened grease".
Old 02-23-2013, 10:02 AM   #33339
SkidMarx
SkidMarx's Avatar
Oddometer: 1,969
Me too. It's in this thread waaaay back. That's why I pointed out that it isn't the end of the world if it's done. Grease works fine too.
'90 XT350
'08 WR250R
GLDS
Old 02-23-2013, 10:28 AM   #33340
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
So that means there's still a race holding the needles even if the plastic is removed?
Never removed mine.
Old 02-23-2013, 11:30 AM   #33341
rjnutt
Desert tortoise
rjnutt's Avatar
Oddometer: 241
Never removed mine.
No, the plastic/silicon holds the needle bearings....do not remove it.
rjnutt is offline   Reply With Quote
Old 02-23-2013, 11:44 AM   #33342
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
All of that plastic stuff in the linkage bearings came out on day 1. I just assumed it was a showroom/assembly product only, as I could see no way to either fully clean the bearings or fully pack them with out those little sticks coming out.
DaymienRules is offline   Reply With Quote
Old 02-23-2013, 11:50 AM   #33343
KansasBob
KansasBob's Avatar
Oddometer: 515
I thought about it for a while............ and since I'm sure I know more than the engineers of some of the most reliable equipment on the planet......... I dug the stuff out! I offer the 2008 rubber damped chain skipping rear sprocket as proof that no one is perfect!
I can tell you this, the "filler" doesn't hold the needles apart at all. When I greased the race, and stacked the needles back in, it was completely full. The needles were tight together, as I would have expected.
Now the bearings that were in the "Link" didn't have the stuff in them. They came apart and went back together as usual. Swing arm bearings were in a cage.
Everything was really in pretty good shape, and could have probably gone another season, but since it was apart, and the snow's a foot deep I did them all. I don't do a whole bunch of deep water crossings, and the only thing that showed any problem was the bolt through the bearing in the middle of the swing arm. It had rusted a little, and had to be tapped out with a punch and hammer. Just light tapping was all.
It's all back together now, so I just stopped for a cup of coffee, and printed torque spec page from the manual. Back to work.
Old 02-23-2013, 11:59 AM   #33344
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 529
Bearings
Is this maybe a good time to ask who sells a good set of bearings for the rear linkage, shock bearing and swingarm bearings that may be better than Yam. OEM? I've heard some bad things about ALL BALLS/MOOSE RACING/MSR/Chinese garbage bearings over in thumper talk, any other Brands? I have a need to redo all of them before my trip this summer.
ps. What's recommended to clean the old bearings prior to regreasing if they are not replaced?
I later found this link that explains quit a bit about that "plastic stuff" http://www.thumperfaq.com/swingarm.htm
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 02-23-2013 at 12:11 PM
pfy50 is offline   Reply With Quote
Old 02-23-2013, 12:04 PM   #33345
viper770
viper770's Avatar
Oddometer: 575
well i have more bad news for you kansasbob we are suposed to get another 8 inches of snow tomorow but i got my klr650 back with the new progressive shock the bike does so much better now so im playing in the snow alittle bit with the klr but i think its going to be a few days befor i get my wr250r back out :(
2012 YAMAHA WR250R
Times are GMT -7.   It's 03:48 PM.
