02-23-2013, 11:04 AM
#33346 |
Oddometer: 235
well i have more bad news for you kansasbob we are suposed to get another 8 inches of snow tomorow but i got my klr650 back with the new progressive shock the bike does so much better now so im playing in the snow alittle bit with the klr but i think its going to be a few days befor i get my wr250r back out :(
2012 YAMAHA WR250R 2013 KAWASAKI KLR650 "Take the long way home" YOU GOT TO WATCH ---->http://vimeo.com/53311329 |
02-23-2013, 11:25 AM
#33347 |
Harvey Mushman
Oddometer: 1,326
The simplest way to get the best quality bearings is to order Yamaha OEM stuff. It is possible to find a good bearing house that can help you figure out equivalents--takes a lot of time though can save you $, but going 3rd party packaged route is gonna get you generally chinese stuff of unknown quality.
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" |
02-23-2013, 12:18 PM
#33348 | |
Oddometer: 1,325
All you have to do is look at your steering stem bearings to know that everyone at Yamaha must be deathly allergic to grease. ![]() Using the plastic stuff(there's a name for it but I can't remember what it is) likely saves many lives at Yamaha. It also takes a step and possible failure mode out of the manufacturing process which saves then some money. Not that they care about that. Good news is, They will never forget to grease those bearings, and everything I've read about the stuff is that it works really well. FWIW, I left the stuff in and still crammed as much grease as possible in there. |
02-23-2013, 01:10 PM
#33349 | |
In my Pajama pants
Oddometer: 681
One of the things the link above states that this is for reduced maintenance. I believe that this was a measure of insurance against the owners that will never do swingarm maintenance on the bike. I could not see a way to get any measurable amount of grease in there with the removal of the plastic stuff. I picked that stuff out with the bearings and cleaned everything up. Next I put a big glob of grease in the race and pushed the needles into it until they were all in place like you would a normal bearing. This should be much easier to clean out later.
Bikes I own 2008 Yamaha WR250R 1992 Yamaha XT225 duanew1 screwed with this post 02-24-2013 at 08:57 AM |
02-23-2013, 04:32 PM
#33350 |
Oddometer: 454
Quote: What's recommended to clean the old bearings prior to regreasing if they are not replaced?
I later found this link that explains quit a bit about that "plastic stuff" http://www.thumperfaq.com/swingarm.htm WOW! That is exactly the information I wanted. Permanent Lubricant..... OK If you say so. ![]() I'm comfortable with my decision to go old school, and pack her tight with water proof grease. I'm back together, and torqued now. 47 rear, new seal guard, (third one from new) and a new chain is on. New Gel battery, a little fuel, and actually started
KansasBob screwed with this post 02-23-2013 at 04:49 PM |
02-23-2013, 04:44 PM
#33351 | |
Oddometer: 454
02-23-2013, 08:13 PM
#33352 |
Oddometer: 1,950
Warp 9 Wheels...
Hmmm... so are they any good?
Dammit. I've dented my DID rim from running too low a pressure in the front tire. Looks like I'm either going to get an Excel rim and re-spoke or maybe a new Warp 9. Thoughts on the above ?
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
02-24-2013, 07:32 AM
#33353 |
armchair asshole
Oddometer: 2,558
For any of you So Cal guys I noticed there was an IMS 4.7 on the SD CL for $300. Apparently new. Wish it was closer to me.
02-24-2013, 08:19 AM
#33354 |
Oddometer: 96
Run it dented if it isn't too bad dents are gonna happen I would only replace after the rim is thoroughly shot.
02-24-2013, 09:31 AM
#33355 |
Oddometer: 1,950
<"Run it dented if it isn't too bad dents are gonna happen..."
Yeah, I am monitoring spoke tension in the dented areas. Trying to put the bike in good shape for some long runs this summer.
02-24-2013, 01:05 PM
#33356 |
bikes, booze, broads...
Oddometer: 8,311
...puttin' around the block
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
02-24-2013, 02:13 PM
#33357 |
amateur
Oddometer: 80
Hey rapid dog, what kind of nav tower do you have? Or if you built it yourself, could we see some more pictures?
2012 Yamaha WR250R |
02-24-2013, 02:59 PM
#33358 |
Oddometer: 160
X2. Interested to see pics also...
2010 WR250R 2011 KLR 2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59 |
02-24-2013, 05:47 PM
#33359 |
Oddometer: 422
What can be done to clean up the area under the seat in order to make more space? There seems to be so little room for new electrics. Anyone have any pics?
02-24-2013, 06:05 PM
#33360 |
Wannabe Far-Rider
Short of cutting off the top of the airbox and making a new floor/top, or wholesale rewiring the bike, not much. What are you trying to fit?
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
