Old 02-27-2013, 09:33 AM   #33406
jon_l
jon_l's Avatar
Oddometer: 3,465
Originally Posted by Thousand Suns View Post
WR250 at Windrock or Coal Creek. East Tennessee rocks.
http://www.youtube.com/channel/UC0uvILil4nxyxH1sqTsjrhg?feature=mhee
Nice riding you got there! My bro lives in Knoxville. If my bike and I ever both get there together, I'm have to check it out.
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 02-27-2013, 10:28 AM   #33407
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,715
Originally Posted by TwilightZone View Post
>"I'm having hard time finding wheel bearings. The front was easy - I got German made SKF locally at $11 a pop. "
Can you supply the SKF part numbers for the front bearings ???
The SKF is 17x40mm bearing with double rubber seal. SKF explorer 6203 2RSJEM is what I have in hand. The explorers are okay - lasted two years on my BMW with stock grease. (it sees water, mud, etc). These ones, I'll take apart, wash all the grease out with solvent, and repack them with Maxima waterproof. Lets see how long they last.
Originally Posted by pfy50 View Post
I think Allballs Racing IS the Chinese junk he is talking about. There is a discussion over on Thumpertalk about them and some of the companies that use them under their brand name like MOOSE RAC,MSR, PARTS UNLIMITED.
Maybe. Unfortunately, being in a pinch and unable to find quality bearing in the right size (I live near Timken, and they don't have one), I had to get Moose Racing set until I find a better one. Not paying Yami $60 for the Koyo that is shut at 5k miles.
I found that SKF makes one, but special order in my area. I keep looking and will update once I find a good, EU or USA made product.
With the SKF explorers, the same part number can be made in Germany or Argentina or...
henrymartin is offline   Reply With Quote
Old 02-27-2013, 11:26 AM   #33408
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,911
Are you replacing the axle seals as well? If so, where are you getting them? I always wonder when people talk about buying bearings at auto parts stores or bearing houses where they're getting the replacement seals from, or if they are even replacing them.
cjbiker is online now   Reply With Quote
Old 02-27-2013, 11:45 AM   #33409
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,965
That SKF is available from Amazon.
http://www.amazon.com/SKF-Bearing-Pr.../dp/B0071ARTEM
Are saying you want to avoid the SKF? I understand about wanting to avoid the no-name chinese bearings but a brand like SKF or Timken, etc... I think the country of origin means a little less in terms of quality.
swimmer is online now   Reply With Quote
Old 02-27-2013, 12:24 PM   #33410
shep546
shep546's Avatar
Oddometer: 215
What skid plates are you guys running? How is the richochet?
shep546 is offline   Reply With Quote
Old 02-27-2013, 12:26 PM   #33411
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 394
Thumb
Is what I have and works well for me.
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 02-27-2013, 12:45 PM   #33412
AZ TOM
Oddometer: 4,152
Flatland is the best coeverage.
AZ TOM is offline   Reply With Quote
Old 02-27-2013, 12:51 PM   #33413
henrymartin
Mr. Tourguide
Oddometer: 3,715
If they are good, I keep the seals. If not, most autoparts stores sell seals as well.
I am saying SKF over anything else if available. Just my personal experience.
Timken is even better, IMHO but hard to find for our applications.
Update: I spent an interesting 30 minutes on the phone with a SKF tech guy who spoke in terms I did not understand (regarding forces, et cetera). The 62/22 (22x50x14mm) is available, but not in Explorer quality. part numbers are 6222-2rs1 or 62222rsj (rs1 is an unknown seal, rsj is a rubber seal pressed in steel cage). Those are industrial bearings, and he ran some numbers. At 200RPM of wheel spin and radial force of 450 lbs, with some axial force, that bearing is rated at 17000 hrs of use before the bearing grooves the cage, with stock lube rated at 40000 hrs. I have not tried or tested this bearing myself.
The 60/22 (22x44x12mm) is available by special order only and the part number is BB1-4724 . Minimum order and lead times will apply. So I was told.
Old 02-27-2013, 02:08 PM   #33414
indypup
indypup's Avatar
Oddometer: 3,764
Just got around to editing this video a few days ago. ;) It's just another one of me beating the crap out of my WRR.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 02-27-2013, 02:25 PM   #33415
AZ TOM
Oddometer: 4,152
Brutal I'm exhausted
Old 02-27-2013, 02:40 PM   #33416
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,161
Fun day. But didn't anyone tell you guys it was raining? And flash floods?
Shawnee Bill is offline   Reply With Quote
Old 02-27-2013, 02:55 PM   #33417
oic0
Oddometer: 22
I never thought to use my WR as a boat either, but apparently according to this video it can be done
oic0 is offline   Reply With Quote
Old 02-27-2013, 04:53 PM   #33418
johninlv
Oddometer: 39
Wheel Bearings Part Numbers
I'm having hard time finding wheel bearings. The front was easy - I got German made SKF locally at $11 a pop. The rear wheel is impossible to find in four major car part stores and an industrial supply store. The 22mmID and 44mm OD is available, but no one has the 22mm ID 50mmOD bearing.
I don't want to buy Chinese made piece online, and I'm sure not paying $60 for the Yami part
So, where do you all find your bearings?
WR Bearings -
Fronts: 40x12x17 (seals 40x7x 22 or 23?). Bearings called 6203-2RD same on both sides (30-4004 seals).
Rears: 50x14x22 and 44x12x22 (seals: 50x30x7 and 30x44x5).
Bearings called 60/22-2RD-OE6 and62/22-2RD-QE6 (30-5003 and 30-4403 seals)
SKF:
Rear1 SKF 62/222RS1 Sealed Deep Groove Ball Bearing 22x50x14mm 11
Rear2 60/222RS Budget Rubber Sealed Deep Groove Ball Bearing 22x44x12mm 5.60
Yamaha no.s:
Fronts: 93306-20348-00 and 93106-23002-00 (seal)
Rears: 93306-27206-00 50 and 93306-07202-00 26 (bearings)
93106-30001-00 and 93106-30045-00 (seals)
From an Adv Rider in GB
2004 Yamaha xt225, 2008 Wr250R Works in Progress
johninlv is offline   Reply With Quote
Old 02-27-2013, 08:30 PM   #33419
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 591
HM
I found these
http://pivotworks.com/ProductInfo.aspx?item_id=1558 Seem inexpensive I sent an email to see where they get their bearings, but no reply yet. They do say they are ABEC3 and come with a lifetime replacement guarantee.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-28-2013, 02:46 AM   #33420
rsteiger
Bob
rsteiger's Avatar
Oddometer: 235
I have the Richochet and my friend is running the Flatland one.
When I look at the two side by side the Flatland has better protection especially around the water pump. I have made the decision to replace my Richochet with either the Flatland or Moose Racing plastic skid plate.
Just beware that when you bolt on one of the Al skid plates you are going to wonder what is wrong with your motor the first time you start it up. The Al resonates pretty well. Some of the guys will coat the bottom of the skid plate with spray on bed liner from a can. Based on my experience with my KTM that seems to work pretty well.
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
rsteiger is offline   Reply With Quote
Times are GMT -7.   It's 04:38 PM.
