Old 03-01-2013, 05:16 PM   #33481
Fitty
Shopping cart rider
Fitty's Avatar
Oddometer: 203
Originally Posted by sturgeon View Post
I'm confused. Why not just use the proper tool to remove them?
Dyslexics untie!
Which is??
Fitty is offline   Reply With Quote
Old 03-01-2013, 05:46 PM   #33482
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,876
There isnt a tool. When the factory installs the bolts the head shears off, like stripping a bolt on purpose.
Get a center punch, and pop it right in the middle, then drill it out with a bit just a little smaller than the head. They're pretty soft.
Dyslexics untie!
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 03-01-2013, 05:51 PM   #33483
sturgeon
sturgeon's Avatar
Oddometer: 935
Originally Posted by Fitty View Post
Which is??
Well, if they are what I think they are, it's basically an Allen wrench with a hole drilled into the tip to accommodate the pin in the socket in the end of the bolt. Aka tamper-proof or security hex socket. There are also torx versions.
Dyslexics untie!
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 03-01-2013, 05:51 PM   #33484
Fitty
Shopping cart rider
Fitty's Avatar
Oddometer: 203
I used to take them out with a center punch. Place it on the side of the head, start hitting the punch as you move it down at an angle until you're applying force in the loosening direction while hitting it. Didn't have to get the drill out, but the drill is easier.
Old 03-01-2013, 05:58 PM   #33485
Buzzbomber
Not Dr. Who...
Buzzbomber's Avatar
Oddometer: 1,268
Dyslexics untie!
These are a different animal altogether. What you see in the picture is not the head of the bolt as fastened to the bike, as that part sheared off. The bolt extends past the "head" that you see to the actual drive head, with a weak spot where the bolt breaks off when a specified torque value is exerted on it - dig?
Buzzbomber is offline   Reply With Quote
Old 03-01-2013, 06:08 PM   #33486
sturgeon
sturgeon's Avatar
Oddometer: 935
Yes, I know what those are too. From the OP's description it sounded like a removable security Allen bolt with dirt in it, not these permanent ones. Obviously it's not what I thought it was.
Dyslexics untie!
Dyslexics Untie!
Old 03-01-2013, 07:34 PM   #33487
UtahFox
UtahFox's Avatar
Oddometer: 446
Thanks for the help all. The bike is all in pieces now, but I think tomorrow I should be able to get it buttoned up. I will have done all the air intake mods & removed the charcoal canister, new plastics, new gas tank, handlebars/guards/mirrors. Who knows, maybe I'll be able to get out and ride it soon :)
UtahFox is offline   Reply With Quote
Old 03-01-2013, 11:40 PM   #33488
avgas
amateur
avgas's Avatar
Oddometer: 81
Alright, I think I've gone and done something stupid. I decided to cut down the whale tail a bit.. you know, so I'd be cool. Anyway, I managed to cut a wire bundle (yellow and a black wires) while I was sawing blindly away. The bundle is the one that comes out of the tail light, and then goes along the back of the tail light to the right side of the bike. As far as I can tell that bundle didn't go anywhere, but that doesn't make sense (certainly doesn't go anywhere now...). I've lost the brake light (normal tail light still works), bike still starts, blinkers still work, headlight doesn't turn on until after it's running (I can't remember if it was always like that). All the fuses seem OK. I guess it's possible that I lost the brake light awhile ago and just haven't noticed.
I might have to post pictures tomorrow, but I'm hoping someone can point me in the right direction without them.
2012 Yamaha WR250R
avgas is offline   Reply With Quote
Old 03-02-2013, 12:27 AM   #33489
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,761
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 03-02-2013, 12:50 AM   #33490
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,412
Dude, was there NO way around?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 03-02-2013, 12:51 AM   #33491
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,761
I couldn't turn around on the trail (and didn't want to) and had no way of getting past this tree while on a very very steep mountain side so I decided to go underneath the tree. ;)
Old 03-02-2013, 12:53 AM   #33492
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,412
I reckon next time bring a chainsaw and get it out of your way once and for all?
Old 03-02-2013, 12:55 AM   #33493
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,761
+1 I carry a saw with me now...
Old 03-02-2013, 02:29 AM   #33494
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 164
Looks like nice dirt, anyway.
Where was it at?
YZEtc is offline   Reply With Quote
Old 03-02-2013, 02:53 AM   #33495
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,761
Where was it at?
Colorado. I forget the trail number...I'll have to dig it up. ;)
Times are GMT -7.   It's 11:15 PM.
