Old 03-02-2013, 05:39 AM   #33496
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
Originally Posted by indypup View Post
I couldn't turn around on the trail (and didn't want to) and had no way of getting past this tree while on a very very steep mountain side so I decided to go underneath the tree. ;)
Corona 10" folding puning saw. I carry one of these everywhere... about $20 at an ACE Hardware. Packs small, lightweight. You can actually cut a tree this size or a little larger, though it might require a notch cut. Has gotten me out of the woods on at least a half-dozen occasions.
GSBS is offline   Reply With Quote
Old 03-02-2013, 07:41 AM   #33497
shep546
shep546's Avatar
Oddometer: 215
Originally Posted by z@ch View Post
Having run the 120 and 100 trackmaster, I vastly preferred the 100.
Bike turns easier on the trail and you lose less power to the weight and larger diameter.
Turns out the 100/100-18's are $11 cheaper and the dealership is gonna let me return them
shep546 is offline   Reply With Quote
Old 03-02-2013, 08:06 AM   #33498
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by avgas View Post
Alright, I think I've gone and done something stupid. I decided to cut down the whale tail a bit.. you know, so I'd be cool. Anyway, I managed to cut a wire bundle (yellow and a black wires) while I was sawing blindly away. The bundle is the one that comes out of the tail light, and then goes along the back of the tail light to the right side of the bike. As far as I can tell that bundle didn't go anywhere, but that doesn't make sense (certainly doesn't go anywhere now...). I've lost the brake light (normal tail light still works), bike still starts, blinkers still work, headlight doesn't turn on until after it's running (I can't remember if it was always like that). All the fuses seem OK. I guess it's possible that I lost the brake light awhile ago and just haven't noticed.
I might have to post pictures tomorrow, but I'm hoping someone can point me in the right direction without them.
I'm pretty sure that one is for the license plate light, and if your new tail light has one (mine does) then yellow/black won't be used. YMMV.
UtahFox is offline   Reply With Quote
Old 03-02-2013, 08:55 AM   #33499
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,749
I see a better way of getting around that log.... get some speed, load the suspension and......fly off that natural ramp right there !!
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 03-02-2013, 09:44 AM   #33500
Fitty
Shopping cart rider
Fitty's Avatar
Oddometer: 203
And it only took 3'21" to get under the tree.........oh, wait.
Fitty is offline   Reply With Quote
Old 03-02-2013, 10:15 AM   #33501
ba_
ba_'s Avatar
Oddometer: 2,829
Safari tank question
I just finished the install of the Safari tank and poured about 3/4 gallon of fuel to start the engine and make sure there were no leaks. Some of this fuel went directly in the fuel pump reservoir and some of this fuel went into the wings.
The bike ran fine until the fuel that was in the reservoir ran out. It appears that the vacuum pump is not pulling fuel from either wing.
I checked to make sure that the vacuum line to the tank has suction and it does.
What should I look at next?
There is about 2-3" of fuel sitting at the bottom of each wing.
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
FS: DID Chain & front/rear JT sprockets WR250R
ba_ is online now   Reply With Quote
Old 03-02-2013, 11:51 AM   #33502
indypup
indypup's Avatar
Oddometer: 3,764
Maybe the video doesn't portray how steep the side of the mountain is and how you would have been in a valley about 100 feet below if you moved even 1 ft to the right.
The camera is level most of the time so when you see those angles...they are real. The angle of the tree across the trail is actually less than the slope of the side of the mountain.
I should have done a wrap around shot with the camera so you can get an idea of how steep the mountain was...
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup screwed with this post 03-02-2013 at 12:52 PM
indypup is offline   Reply With Quote
Old 03-02-2013, 11:58 AM   #33503
indypup
indypup's Avatar
Oddometer: 3,764
+1 I carry a saw with me now...
Old 03-02-2013, 12:08 PM   #33504
TwilightZone
Oddometer: 3,200
>"Turns out the 100/100-18's are $11 cheaper and the dealership is gonna let me return them "
They are pretty small... you'll see when you get them on the rims.
The WR260R comes with 120 size tires.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 03-02-2013, 12:14 PM   #33505
ba_
ba_'s Avatar
Oddometer: 2,829
I pulled one of the fuel lines out of the tank and closed off the end with my finger. Fuel started moving up the other end and dumped on the fuel pump.
I then reassembled that side and put it back in its place.
Now fuel appears to be coming up both sides and filling the reservoir.
I should be good correct?
Old 03-02-2013, 12:44 PM   #33506
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,715
14/52 sprocket combo installed today, and now my chain guard and chain guide interfere with the sprocket/chain. Raising the guard is easy, but what about the chain guide? Do you just run the wheel slightly to the rear with a longer chain, or how did you deal with the chain guide and the large, 52 sprocket?
One more think, please. The rear spacers are different size. Which one goes to what side? I reinstalled it the way it was when the bike arrived, but it doesn't seem right. The shorter one is on the caliper side, the longer one on the sprocket side.
henrymartin is offline   Reply With Quote
Old 03-02-2013, 12:47 PM   #33507
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 591
BA,
That's just the cost of doing business, it's less than a quart of fuel and the pickups won't get every last drop so don't worry about it. My Safari does the same thing.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 03-02-2013, 12:51 PM   #33508
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 591
Hey HM,
Did you get the email?
As to your first question??
Second question YES
Old 03-02-2013, 12:56 PM   #33509
ba_
ba_'s Avatar
Oddometer: 2,829
Originally Posted by pfy50 View Post
BA,
It just seemed like it took a bit to get the vacuum pump pulling fuel from the wings...
Old 03-02-2013, 01:11 PM   #33510
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 591
I went thru that whole sequence of pulling it apart 6 times, before I figured out that Mikuni had assembled my vacuum pump backwards. Once fixed it would pull 3.6-3.7 gal out of the tank but that little residual was always still left behind
Times are GMT -7.   It's 04:48 PM.
