Old 03-02-2013, 01:51 PM   #33511
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 529
Originally Posted by henrymartin View Post
14/52 sprocket combo installed today, and now my chain guard and chain guide interfere with the sprocket/chain. Raising the guard is easy, but what about the chain guide? Do you just run the wheel slightly to the rear with a longer chain, or how did you deal with the chain guide and the large, 52 sprocket?
One more think, please. The rear spacers are different size. Which one goes to what side? I reinstalled it the way it was when the bike arrived, but it doesn't seem right. The shorter one is on the caliper side, the longer one on the sprocket side.
Hey HM,
Did you get the email?
As to your first question??
Second question YES
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 03-02-2013, 01:56 PM   #33512
ba_
ba_'s Avatar
Oddometer: 2,719
Originally Posted by pfy50 View Post
BA,
That's just the cost of doing business, it's less than a quart of fuel and the pickups won't get every last drop so don't worry about it. My Safari does the same thing.
It just seemed like it took a bit to get the vacuum pump pulling fuel from the wings...
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 03-02-2013, 02:11 PM   #33513
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 529
Originally Posted by ba_ View Post
I went thru that whole sequence of pulling it apart 6 times, before I figured out that Mikuni had assembled my vacuum pump backwards. Once fixed it would pull 3.6-3.7 gal out of the tank but that little residual was always still left behind
Old 03-02-2013, 02:20 PM   #33514
ba_
ba_'s Avatar
Oddometer: 2,719
Yikes.
Was your pump working at all? What do you mean backwards?
Old 03-02-2013, 02:45 PM   #33515
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 529
Yikes.
Yes, it worked after I reversed the plates. If you look at the pump you have fuel flow directional arrows cast in on the pump. 2 for the pickups and one to go out toward the fuel pump. The arrows pointed in on pickups and pointed in on the output to the fuel pump. And since my fantastic brain told me THAT DON'T LOOK RIGHT I switched it around so the arrow pointed out at the fuel pump side
Old 03-02-2013, 02:53 PM   #33516
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,711
I've noticed that when you pour a small amount of gas in (not from a gas pump) AND the tank is almost empty AND the bike is leaned over on the sidestand, there's a tendency for the gas to run into only the left wing. When than happens, there's not enough gas sucked up into the pump to run the engine...you need to have gas in both wings when you're down to the last drops of gas. Maybe that's what happened in your test?
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is online now   Reply With Quote
Old 03-02-2013, 03:02 PM   #33517
ba_
ba_'s Avatar
Oddometer: 2,719
I do see fuel in both fuel lines from the wings and fuel being pumped by the vacuum pump into the reservoir so I think I'm good
I only put in about 3/4 of a gallon so far. I'll go fill it all the way up now that I know there are no leaks
Old 03-02-2013, 03:30 PM   #33518
10Cup
10Cup's Avatar
Oddometer: 2,610
BA,
Here is what I did to solve that problem, I can get every last ounce regardless if one wing is empty or not. 10Cup Safari Mod
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 03-02-2013, 03:50 PM   #33519
ba_
ba_'s Avatar
Oddometer: 2,719
I'm aware of your mod. I'm definitely not brave enough to attempt it.
Going back to the stock Safari setup --
1) if one wing is empty will it run as if it is out of fuel?
2) once both fuel lines are fully submerged again is everything back to normal?
And lastly, an unrelated question
3) Does your Safari tank have a little play in it? Nothing is rubbing on mine like it was for hf but if I push on one of the wings there is a little play back and forth
Old 03-02-2013, 04:59 PM   #33520
HardWorkingDog
Harvey Mushman
Oddometer: 1,711
3) Does your Safari tank have a little play in it? Nothing is rubbing on mine like it was for hf but if I push on one of the wings there is a little play back and forth...
Not 10Cup, but since I'm running a stock Safari setup I'll butt in--
Yes
Yes
and Yes--the tank mounts are rubber mounted with plenty of "give."
"Coffee first..."
Old 03-02-2013, 05:32 PM   #33521
johnnyadventurepants
johnnyadventurepants's Avatar
Oddometer: 492
There's been a little talk here about the Trak Master 120. Here's a pic of mine I just spooned on. I think it fits just fine.
I specifically chose this tire in this size because of how tall it is. I think 27.1 inches if I remember right. Add the tall seat and my X/R finally fits me!
2008 WR250X/R
johnnyadventurepants is offline   Reply With Quote
Old 03-02-2013, 05:36 PM   #33522
shep546
shep546's Avatar
Oddometer: 215
Thanks for the pics man but how is the swing arm clearance??
shep546 is offline   Reply With Quote
Old 03-02-2013, 05:37 PM   #33523
10Cup
10Cup's Avatar
Oddometer: 2,610
Like Hardworkingdog said, yes, once the vacuum pump gets any air it can't pump any more.
I also found that during the last 1/2 Gal. I could not get enough fuel to run down the interstate at 70mph. I have a short stretch I get on at the end of most rides. After the mod no problem with that either. Keep in mind I could run 45-50 but that was it.
Yes, the vacuum pump is self priming, so not problem once you get fuel in both wings.
Yes, and that is good. I had one of the first tanks in the US and I did have to put a 1/4" aluminum plate under the rear mount so that it fit better and matched the angle of the seat. It has been a bullet proof tanks and even when hit by a 12 point buck with resulting crash protected my radiator. Me not so much.
Old 03-02-2013, 05:46 PM   #33524
ba_
ba_'s Avatar
Oddometer: 2,719
Yes
Yes
Old 03-02-2013, 05:48 PM   #33525
ba_
ba_'s Avatar
Oddometer: 2,719
Thanks and sorry to hear about the deer
Times are GMT -7.   It's 12:30 AM.
