Old 03-12-2013, 06:42 PM   #33736
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by johnlt View Post
with over 2000 pages in this thread, it is difficult for a "newbie" to find key items. Is there any index of basic mods/adds to the OEM bike? Thanks
Here's what you want...
http://advrider.com/forums/showthread.php?t=538181
UtahFox is offline   Reply With Quote
Old 03-12-2013, 06:45 PM   #33737
bogboy
bogboy's Avatar
Oddometer: 58
Originally Posted by Oh2RideMore View Post
Finally broke down and bought a bigger tank. What are you guys doing for a gas cap? Does an enduro bag fit on tank?
I just installed the IMS 4.7 a few days ago. I ordered a red Billet aluminum cap with it. Looks good to me. Wolfman enduro tank bag fits on no problem.
bogboy is offline   Reply With Quote
Old 03-12-2013, 06:46 PM   #33738
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,540
Valve clearances
I just checked the valve clearances on my 08 WR with 4000 miles on it. The spec listed earlier in this thread is 0.23mm-0.30mm for exhaust and 0.13mm-0.20mm for intake. If my math is correct, that's 0.009"-0.012" and 0.005"-0.008". Mine measured at 0.009" and 0.010" on the exhaust and 0.006" on both intake valves.
So, should I rest easy knowing that my valves are in spec, or should I adjust that 0.009" exhaust valve?
Thoughts?
cjbiker screwed with this post 03-12-2013 at 06:56 PM
cjbiker is online now   Reply With Quote
Old 03-12-2013, 07:30 PM   #33739
jgormley
jgormley's Avatar
Oddometer: 750
Anyone using the Cyclone Sport Shield?
http://www.maier-mfg.com/catalog/cyc...shield-78-bars
Just looking for feedback on how well it works on a wrr?
Adjustability and stability..
They don't have a forgiving return policy...
My YouTube
jgormley is offline   Reply With Quote
Old 03-12-2013, 08:06 PM   #33740
Longboardr
Longboardr's Avatar
Oddometer: 143
Thoughts?
Fwiw the valves get tighter as they wear.
Longboardr is offline   Reply With Quote
Old 03-12-2013, 08:21 PM   #33741
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,540
Right, hence my thoughts on opening up the exhaust valve that's right at the limit.
Old 03-12-2013, 10:31 PM   #33742
sieg
sieg's Avatar
Oddometer: 2,785
Originally Posted by RockinTheRVA View Post
Hey guys,
I'm looking at a 2012 WR250R with ~400 miles on it. It has been down on the right side, with what looks to be only cosmetic damage to the fenders/exhaust cover. I don't see any damage to the engine casing, etc. He did replace the bars because of a small bend he said.
He is asking $4700.
Would you pay that? If not, what would you try to work him down to? Thanks so much for your input, I'm new to the market for these.
KBB trade in says $3800, Retail $5500.
Private party price should be halfway between retail and trade, so he's right in line, if you subtract the damage.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 03-13-2013, 04:59 AM   #33743
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
Thoughts?
Myself, on the last two bikes I've been riding, my valve clearances were also closer toward the low side of the allowed specification.
Still within the allowed range, though, much like yours.
This was measured after a season of riding.
I didn't get worried about it, but simply kept tabs on it...once a year.
When I measured again a year later, they were at the same measurements.
Point:
For all you know, that's how the bike rolled off the assembly line.
In fact, I'd bet on it.
Personally, I wouldn't bother messing with it since it's within the accepted range.
I would just record the measurements you got and compare to the next clearance check, which I would do one a year for typical casual-and-for-fun riding.
If you still have uneasy doubts about your bike, check them again in a couple of months of use.
If you have serious doubts that are a legit concern, make an adjustment and end it.
YZEtc is offline   Reply With Quote
Old 03-13-2013, 06:02 AM   #33744
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,540
Point:
Hmm, the thought of stripping the bike down and wrestling that valve cover off again any time soon makes me want to cry. I was hoping for a "check it an forget it for the next 22,000 miles" answer.
Old 03-13-2013, 06:36 AM   #33745
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
It sounds as if you're leaning toward the likelyhood that the bike rolled off the assembly line with larger clearances, and within 4,000 miles, they have tightened-up.
Unless you abuse the shit out of the bike and/or inhaled lots of dirt through the air filter, I doubt that's the case, or else all other WR-250R/X riders would have non-running engines.
So, what are the choices?
Either button it up and keep riding, or make an adjustment.
Either way, regardless of what model bike it is, I'd check this at least once a year because that makes me feel better about it.
Old 03-13-2013, 06:47 AM   #33746
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,540
That's been my experience with other bikes, that they get set to X from the factory (hopefully somewhere near the middle of the spec), and by the first valve check at 600-1000 miles, a couple are just below the lower limit. I adjust them, and then 3000 miles later, they typically haven't moved.
The WR is unusual with it's 26,600 mile valve check intervals, so my typical way of thinking may not apply? The only reason I'm debating this is that it's still two months until the trails here are open, and I've got the bike torn down in the shop and am waiting on a bunch of other parts. If it was summer, I'd button it up and ride it. It's interesting to think that according to Yamaha, 0.009" is OK, and if I was a dealer mechanic doing the work on a customer's WR with 26,600 miles on it, I'd see that it's still in spec and button it up to be checked again at 53,200 miles.
Old 03-13-2013, 07:29 AM   #33747
Krabill
Krabill's Avatar
Oddometer: 4,825
I'm with YZEtc on this one. There is a spec and you are within it. I wouldn't touch 'em if it was my bike. Button it up and ride
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 03-13-2013, 07:44 AM   #33748
ggemelos
ggemelos's Avatar
Oddometer: 127
Originally Posted by UtahFox View Post
I sure wouldn't mind a locking cap for one, though I haven't found any. There's an Acerbis universal cap that's reported to work 'ok', with the threads being off a bit.
Safari has a locking gas cap you can buy for their tanks. I believe it is made by Acerbis, but they say it fits all Safari tanks. I just took delivery of my Safari tank and locking gas cap. Planning on installing them this weekend.
Preparation for big trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 03-13-2013, 07:47 AM   #33749
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,123
maier screens
the screen I had on my xr650l from maier was not so great, due mostly to the mounting hardware. No angle adjustment on the arms where they attach to the screen... I'd go a different route
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 screwed with this post 03-13-2013 at 07:52 AM
byron555 is offline   Reply With Quote
Old 03-13-2013, 07:56 AM   #33750
jgormley
jgormley's Avatar
Oddometer: 750
Is this the maier shield with different mounting hardware?
My YouTube
Times are GMT -7.   It's 06:24 AM.
