Old 03-23-2013, 06:34 PM   #34066
scottmac
scottmac's Avatar
Oddometer: 1,613
Originally Posted by Red Sand View Post
I'm ready to order a skid plate and hand guards.
I've seen the options but I have no idea what has stood the test of riding.
Any suggestions will be most appreciated.
The Highway Dirt Bikes hand guards are excellent. Lot's of
options available to you if you want to run heated grips
or have a power plug down the road.
They're made in the USA as well.
scottmac is offline   Reply With Quote
Old 03-23-2013, 06:54 PM   #34067
Red Sand
Red Sand's Avatar
Oddometer: 297
Thanks everyone - very helpful
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 03-23-2013, 07:00 PM   #34068
rickcj7
rickcj7's Avatar
Oddometer: 494
I have Cycra on the WRR and just installed HDB on the Husky, the HDB are 2x as strong as Cycra but only $30-40 more.
Husqvarna TE630
WR250R sold
FE450E sold
XT, NX, KLX, KLR, DR all long gone.
rickcj7 is offline   Reply With Quote
Old 03-23-2013, 07:05 PM   #34069
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,317
Ok I'll pull them off and put them in the press.
Here's how it sits now.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 03-23-2013, 07:52 PM   #34070
sturgeon
sturgeon's Avatar
Oddometer: 932
All that for HDB hand guards? I don't remember it being that much work :)
Dyslexics untie!
Dyslexics Untie!
sturgeon is online now   Reply With Quote
Old 03-23-2013, 09:30 PM   #34071
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,317
It's been a rough winter. Gotta get it ready for RR2013
1999 Buell X1
2008 Husky TC510
Old 03-24-2013, 07:44 AM   #34072
mattias se
1975mandel
Oddometer: 24
my driving of wr250r
here are some movies when I run my yamaha wr250r
on olicka places
https://www.youtube.com/user/75mande...s?query=wr250r
mattias se is offline   Reply With Quote
Old 03-24-2013, 07:46 AM   #34073
shep546
shep546's Avatar
Oddometer: 215
Anyone have instructions for flatland skid plate install?
shep546 is offline   Reply With Quote
Old 03-24-2013, 07:48 AM   #34074
shep546
shep546's Avatar
Oddometer: 215
on olicka places
Nice vids man!
Old 03-24-2013, 09:48 AM   #34075
aj_day
Oddometer: 20
stock height questions
I purchased a used 2012 WR250R last weekend, mostly for my wife to ride. She is 5'3" with 30" inseam. The previous owner was a large man, and said that he had "raised" the bike using the ride height adjustment built into the rear shock. It was my understanding that they come from the factory adjusted up to the max?
Anyway, I pulled the lower shock linkage and lowered the ride height to the max (http://www.thumpertalk.com/topic/536972-lowered-wr250r/). I also purchased a yamalink and installed it, which should lower the bike another inch. I lowered the front end (raised the forks 5/8in) to compensate. It is my understanding that the stock seat height is 36.6, with the factory ride height adjustment I should be able to get 35.7, and the yamalink should get me down to 34.7. My seat height measures 36in now, with these adjustments made. Is it possible that the previous owner made some other adjustment to raise the rear of the bike? With my untrained eye I do not see anything aftermarket in that area?
Can someone else with the factory ride height lowered and a yamalink installed measure their seat height for me so I can compare?
My wife has lots of street bike experience, but is new to DS and dirt bikes. At this point, she can not even touch the ground on both sides with her tiptoes, and she has to lean so far to one side that she can not get the bike off the kickstand without tipping over. The theoretical 1.2" that I should be getting with these adjustments would make a big difference. Is there anything that I could have done wrong in the install?
I know I can get 1 more inch with a lower seat, but I mocked it up with scraps of wood and foam, and this is still not enough.
aj_day screwed with this post 03-24-2013 at 09:55 AM
aj_day is offline   Reply With Quote
Old 03-24-2013, 09:55 AM   #34076
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,563
swimmer is online now   Reply With Quote
Old 03-24-2013, 10:07 AM   #34077
KansasBob
KansasBob's Avatar
Oddometer: 515
The rear spring may be set pretty tight for a larger rider. Soften it up as much as it will go, and the sag will help her some.
My bike with the factory adjustment bottomed out on the low side, the spring almost all the way soft, and the front forks pushed up till they almost touch the bars. It measures just a touch over 35 inches to the lowest part of the seat.
KansasBob is offline   Reply With Quote
Old 03-24-2013, 10:09 AM   #34078
UtahFox
UtahFox's Avatar
Oddometer: 446
What kind of tires does it have on it?
UtahFox is offline   Reply With Quote
Old 03-24-2013, 10:45 AM   #34079
oldtrucks
oldtrucks's Avatar
Oddometer: 286
Have you adjusted the preload and sag on the rear shock?
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is offline   Reply With Quote
Old 03-24-2013, 10:46 AM   #34080
rickcj7
rickcj7's Avatar
Oddometer: 494
I have mine lowered as much as possible and can get the balls of my feet on both sides with 32" inseam.
She'd be more comfortable on a smaller bike.
Husqvarna TE630
WR250R sold
FE450E sold
Times are GMT -7.   It's 04:15 PM.
