Old 03-26-2013, 09:06 PM   #34216
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,729
Stock oil is about 5 weight, IIRC.
z@ch is offline   Reply With Quote
Old 03-27-2013, 04:24 AM   #34217
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 975
Originally Posted by AdvRich View Post
Pics now and again is always good!
Well i don't generally stop unless i pee!
... Should be some opportunities tomorrow on a ride from kenilworth to widgee and back on the dirt. Google earth that for memories :-)
Reeksy is offline   Reply With Quote
Old 03-27-2013, 05:13 AM   #34218
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 155
That's true.
If you see the need to soften the front fork for low bucks, you can:
1) Go to a fork fluid of less than 5 wt., like a 3 or 2.5 (they are out there).
2) Simply lower the oil level, as this increases the amount of air trapped up above the oil inside the fork.
This is known as the "air gap" or "air spring" or "air spring effect".
Air spring?
When the fork compresses, the air also is compressed, and if there is less oil and more air in there, the larger volume of air will compress more easily.
This is quite noticable, and is why it is a BIG factor when a suspension guy dials-in your suspension.
The Yamaha Service Manual will give specs for what the minimum allowable amount of fork fluid is.
3) A combination of the above.
Important:
If you do anything to the fork involving the fork fluid (I even do it if simply pulling the spring out), be sure to bleed the air out of it and measure the fluid level as shown in the Service Manual.
YZEtc is online now   Reply With Quote
Old 03-27-2013, 05:59 AM   #34219
shep546
shep546's Avatar
Oddometer: 215
Does anyone have a similar setup as me that recommend good fmf settings?
Uni air filter
AIS removed
Powercore 4 (stock header)
I have not modded the flapper or airbox.
Thanks.
shep546 is offline   Reply With Quote
Old 03-27-2013, 07:11 AM   #34220
satchmo3
satchmo3's Avatar
Oddometer: 88
Hello All,
I am going to look at a 2008 WR250R on sat.
The bike has 7000 mi on it, an fmf pipe, and previous rider is about 260lbs.
He claims to have ridden the bike off road a lot and it has been dropped.
Any suggestions on what and where to look for possible issues?
Will be the first one I've looked at. He wants 3500 for it.
Thanks in advance.
satchmo3 is offline   Reply With Quote
Old 03-27-2013, 07:29 AM   #34221
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by satchmo3 View Post
Hello All,
Thanks in advance.
I was bored and stirred the pot yesterday....................... but this is relevant.
If the po ran the bike with the intake and exhaust opened up and no programmer it will have been running lean which is hard on the valves and top of the piston. If it does have a programmer you will have no idea if his settings were correct. Bad settings can hurt a motor too.
7000 miles is plenty of time for damage to occur.
I would say that is fair spring price for a clean stock 2008. The miles, mods, and honest assessment that the bike has been ridden pretty hard off road makes it worth $500 to $750 less.
Morning everyone!!
KansasBob is offline   Reply With Quote
Old 03-27-2013, 07:29 AM   #34222
what broke now
Petroleum Brother
Oddometer: 1,342
Hello All,
Thanks in advance.
If you are worried about the "dropped" part just look for broken and bent external parts like you would on any bike. Crashing the wr doesn't harm it worse than any other bike, they are pretty tough. Plastics are likely scraped up, etc, but easily replaced if it matters. 7 k miles is not much. How it runs and rides is the best test.
what broke now is offline   Reply With Quote
Old 03-27-2013, 07:31 AM   #34223
viper770
viper770's Avatar
Oddometer: 575
my advice is buy it befor i do i like to have a second one lol
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 03-27-2013, 07:32 AM   #34224
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,907
Hello All,
Thanks in advance.
7K miles is nothing on this bike. Mine is at 22K and has been ridden hard on and off road and dropped several times and I've had zero issues. These bikes aremeant to be ridden off road (and dropped from time-to-time).
I'd think $3,500 is a very good price if there are no major issues, especially if the PO has already added the usual farkles like hand guards, bash plate, pipe, AIS and EXUP removal and opened up air box. New ones are almost twice that price and this mileage is just getting broken in.
I'd say check for any oil leaks and check the rubber chain slider on the underside of the swing arm. This is a known issue and if not caught in time the chain can wear through the slider and into the metal on the underside of the swing arm. If nothing else could be a price haggling point.
The only other items I can think to check are the steering head bearings for notching and/or wear or play and the fork seals. Some have reported wiring issues at the tail light from the wires being rubbed through but I've not seen this on mine.
In fact, I've not had one mechanical issue with mine and would say it's the one of the most bulletproof and reliable bikes I've ever owned.
Good luck!
GSBS is offline   Reply With Quote
Old 03-27-2013, 07:52 AM   #34225
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,347
mornin'! ;)
Hello All,
I am going to look at a 2008 WR250R on sat...
...a visual inspection and a 10 minute ride should tell you all you need to know.
$3500 is a good deal.
Not to screw with Bob again but, I'd bet at 7K even with poor fuel settings there'd be much real damage if any.
These are super hearty motors. Even if there was any deterioration, a do it yourself valve job would be relatively cheap.
Take it thru the gears, rev it like it should be.
You'll know if it's a turd or not.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 03-27-2013, 08:00 AM   #34226
what broke now
Petroleum Brother
Oddometer: 1,342
Originally Posted by KansasBob View Post
"... honest assessment that the bike has been ridden pretty hard off road ..."
"pretty hard" was not stated.
Old 03-27-2013, 08:04 AM   #34227
KansasBob
KansasBob's Avatar
Oddometer: 515
It's all good!
Wear hearing protection!
Old 03-27-2013, 08:15 AM   #34228
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,959
LOL....it is a 250 four stroke...it is only gonna be so loud.
Try doing a track day and pitting across from a guy with a Duc 999, and trying to tune it was no exhaust cans on...now that is obnoxiously loud.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 03-27-2013, 08:58 AM   #34229
AZ TOM
Oddometer: 3,864
Hello All,
Thanks in advance.
$3,500 is pretty much the going price now days. Anything less & I would be skeptical of the bike unless the owner was desperate!
AZ TOM is offline   Reply With Quote
Old 03-27-2013, 09:26 AM   #34230
aj_day
Oddometer: 20
Hello All,
Thanks in advance.
I am sure our marketplace is very different than yours (Still 12in of snow on the ground, 10 degrees F just 2-3 days ago). I just purchased a 2012 WR250R two weeks ago for $4200 from a private seller on craigslist. It was slightly dirty, but otherwise in perfect shape with 4600 miles on it. Stock condition with handguards, Yamaha factory rack, and a quick release topcase. No other mods. Still has factory warranty until June. Seller posted his ad on Friday morning, I bought it Saturday morning. He said he had 3 more people scheduled to look at it on Saturday.
Shortly after I purchased mine, I saw a 2008 WR250R in Minneapolis on craigslist for $3,000. I think I remember that it had a skid plate and handguards, otherwise stock with @ 10,000 miles on it. I did not really scrutinize the ad or look at it in person because I had already bought one. I did notice that it sold immediately. The ad was posted in the morning, and it was gone in the afternoon.
aj_day is offline   Reply With Quote
Times are GMT -7.   It's 11:23 AM.
