Old 04-06-2013, 12:55 PM   #34516
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,836
Originally Posted by CJ smith View Post
I should have just left the WR on its stand in the basement, but its almost riding season and I got the tinkering bug...
So I dug out the spoke tool and began playing the musical wheel harp. A few spokes were a little off(some had a high tone and some a low tone when struck) without a fancy torquing device or the necessary knowledge, theres no telling for sure. I tightened a few(or loosened?) a 1/2 to 3/4 turn, listened, tried a few more, and then I got the strange feeling that I Have No Idea What I Am Doing. What do you say fellas, did I just ruin a set of perfectly good wheels or is this "adjustment" reversible by bringing it to a pro?
This is why I have said 1000 times (often in this thread), if it isn't broke, don't fix it.
Just leave it alone as long as it spins true and you can't physically feel any spokes loose... and by "physically feel" I mean grasping the spoke and wiggling it, if it moves, tighten it and if it doesn't, don't. You don't need to loosen up anything you just did or "bring it to a pro". Just stop fucking with shit that don't require fucking wit'.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 04-06-2013, 01:12 PM   #34517
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
You didn't ruin the wheel, it's not THAT precise. Put it on a stand to get the weight off of the wheel you're working on. Pick one spoke to start with, like the one just past the valve stem. Snug up that spoke, turning no more than a quarter of a turn., less if it is already tight. You'll get a feel for the correct torque pretty quickly, someone once told me to hold the wrench between two fingers like they're chopsticks. Then skip 2 spokes, and repeat on the third one. Go all the way around the wheel 3 times with this pattern, and each spoke should be about the same tension.
DaymienRules is offline   Reply With Quote
Old 04-06-2013, 01:29 PM   #34518
AZ TOM
Oddometer: 3,927
I must agree with you. Too much time on your hands Just polish it every day & leave the dang thing alone
AZ TOM is online now   Reply With Quote
Old 04-06-2013, 01:51 PM   #34519
CJ smith
Oddometer: 23
Good advice, thanks guys.
If theres a speed wobble when I finally get out on the bike at least I know where to start looking.
CJ smith is offline   Reply With Quote
Old 04-06-2013, 02:41 PM   #34520
sieg
sieg's Avatar
Oddometer: 2,813
good advice ^
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 04-06-2013, 03:32 PM   #34521
Red Sand
Red Sand's Avatar
Oddometer: 297
My first maintenance day with the WR!
  • Washed the machine
  • Cleaned the chain
  • Lubed the chain
  • Changed the oil & filter
I tossed in 1.5 quarts of BMW 10-40 oil I bought for my other motorcycle but never used . . . will the Yamaha engine spit out that rancid crap from Bavaria? . . . . . .
When I was at the dealer Friday picking up my oil filter and stuff, I walked over to the Honda 650 and looked at it. That was the other machine I was considering buying but I bought the WR instead. After looking at it, I am convinced I made the best choice. I'm sure the Honda 650 is great but I'm already getting into a lot of trouble with just 24 hp, or whatever.
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand screwed with this post 04-06-2013 at 05:11 PM
Red Sand is offline   Reply With Quote
Old 04-06-2013, 05:12 PM   #34522
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,718
Pissed the WRR won't start...
After close to 10,000 miles of flawless running, I gave the WRR a shower this afternoon.
Son asked if he could ride it to the post office, so I gave it a last spray of the hose, dried
off the seat and handed it over.
crank crank crank crank and no start
crank crank crank crank crank
nothing. Crap. I'd just got back from Death Valley, ran perfectly. Normally starts after about
2 cranks or less of the starter motor.
Damn. He took the XT225, and shouted back , well, at least you've got something
to work on!
crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank crank
nothing.
So I grab the towel that's sitting on the luggage rack, and yank it off in disgust
only to spot the bright orange FMF exhaust plug I always put in before I wash a bike.
Pulled out the plug, crank PURRRRRRRRRRRR.
The WRR is hard to kill, but an exhaust plug will do it every time.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 04-06-2013, 05:26 PM   #34523
KansasBob
KansasBob's Avatar
Oddometer: 515
Your wheel is fine. I laced my first wheel the other day and it was a full 1/2 inch off center when I was done. I kept working at it , and got it moved over the full 1/2 inch. in just a few min. You have to look at the end of the spoke as the end of a bolt.....then right to tight, and left to loosen.
KansasBob is offline   Reply With Quote
Old 04-06-2013, 05:36 PM   #34524
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 257
Even funnier when your doing that with a high compression kick start only YZ250.
Multiple times!
Doh....
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 04-06-2013, 05:42 PM   #34525
DaymienRules
Traffic target
Oddometer: 197
Multiple times!
Doh....
Same here. And I've watched as a friend did the same thing too. Its funny when it happens to someone else.
Old 04-06-2013, 05:49 PM   #34526
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,648
My KTM 200 will start with the exhaust plug in. Then I take off and wonder why the bike won't pull like it should
cjbiker is online now   Reply With Quote
Old 04-06-2013, 10:56 PM   #34527
sieg
sieg's Avatar
Oddometer: 2,813
Why plug the exhaust ???
Old 04-06-2013, 11:19 PM   #34528
DaymienRules
Traffic target
Oddometer: 197
It stops water and mud from flowing down into the exhaust when washing it.
Old 04-07-2013, 05:19 AM   #34529
dnsjo
dnsjo's Avatar
Oddometer: 27
Talking
Originally Posted by shep546 View Post
Do you know how much I should raise my front forks with the stock lowering adjustment? All the guides are for guys who threw the yama link in...
I dropped my forks a full 2 inches by adding a Tusk 30mm bar riser (Rocky Mtn ATV). I had dropped the rear at least that much with a Moose 1.75" knuckle and the stock lowering. So far I love the handling. The steering is quick, and there is nary a wobble in corners or at 60+ mph. I doubt I will ever bottom the front end. The bike has a Corbin seat and the original kickstand. Love it.
dnsjo is offline   Reply With Quote
Old 04-07-2013, 06:47 AM   #34530
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,196
  • Cleaned the chain
  • Lubed the chain
What kind of BMW oil did you put in? My beemers have all had dry clutches and the WR250R has a wet clutch, so the oil for the WR should be rated for use with a wet clutch. IIRC, there are anti-slip additives in the wet clutch oil that are not found in oil for cars or bikes with dry clutches.
I've owned several 650 dualsports and loved them, but while the extra power is great it comes at the price of many extra pounds. I really like how light and nimble the WR250R feels! It's got plenty of ooomph to get me going as fast as I want to go.
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Times are GMT -7.   It's 10:50 AM.
