Old 04-13-2013, 05:23 PM   #34681
ecarnell
ecarnell's Avatar
Oddometer: 394
Originally Posted by GSBS View Post
22mm box wrench in WR-R tool kit (and my boot)
Actually, I wasn't as prepared as usual because I forgot to put the two inner tubes in the saddle bag that I usually carry. But luckily the pinch flat was patchable and I did have a patch kit (Slime - from Walmart - the orange and black ones).
As long as you "tighten" the rear nut with the same tool - you'll be easily be able to remove on the trail.
Front can be removed by just the 10mm pinch bolts - also in the kit.
Need some irons, pump and patches at a minimum!
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is offline   Reply With Quote
Old 04-13-2013, 05:31 PM   #34682
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by MiamiMotorcyclist View Post
That really is a cool stand. Hate how mine just drops. Not a big deal but kind of crude in comparison.
Just think how much better it would be if you sent that shock in and had it tweeked to make it just perfect!!!
KansasBob is offline   Reply With Quote
Old 04-13-2013, 05:40 PM   #34683
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by shep546 View Post
Wow... you guys ride very prepared... if I ever got a flat on the trail I'd be screwed...
What tools do you carry, more specifically what do you carry that can break the torque on your axle nut?
Standard equipment on any "off the pavement ride" ...........
Factory tool kit
3 tire irons
front tube
rear tube
patch kit
hand pump
co2 tire filler
tie wire
ty-raps
small bottle of soapy water
Stand to prop the bike on
valve stem core remover
valve stem installer
bead buddy
epoxy in the roll
pocket knife (multi tool)
baby vicegrips
piece of cloth to set the tire on
first aid kit.
duct tape
black electrical tape.
There's more, but that's a good start.
Old 04-13-2013, 05:58 PM   #34684
mpatch
Oddometer: 1,032
Can you actually put it back together by just the pinch bolts and keep the axle nut tight? Never tried it.
mpatch is offline   Reply With Quote
Old 04-13-2013, 06:12 PM   #34685
ba_
ba_'s Avatar
Oddometer: 2,785
countersunk bolts - rear sprocket
Where can I get the countersunk bolts for the rear sprocket? Thanks
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 04-13-2013, 06:14 PM   #34686
TedG540
TedG540's Avatar
Oddometer: 194
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
TedG540 is offline   Reply With Quote
Old 04-13-2013, 06:23 PM   #34687
ba_
ba_'s Avatar
Oddometer: 2,785
Originally Posted by TedG540 View Post
So it's the sprocket hardware from a YZ that I need?
Old 04-13-2013, 06:29 PM   #34688
TedG540
TedG540's Avatar
Oddometer: 194
Yes..I just went to the garage and verified these fit. If I'm wrong, someone will speak up.
Old 04-13-2013, 06:53 PM   #34689
scottmac
scottmac's Avatar
Oddometer: 1,783
Yup, YZ or WRF hardware for swapping rear sprockets.
scottmac is offline   Reply With Quote
Old 04-14-2013, 01:21 AM   #34690
ecarnell
ecarnell's Avatar
Oddometer: 394
If it meant leaving my bike in the bush/trail - yep it would surely get you home (assuming you fixed the flat). If you take a visual where the original position of the axle is on the non nut side - you should get it close enough putting it back together.
In this case you'd never remove the axle nut (obviously only works on the front).
2014 KTM 500 EXC
2011 KLR
Old 04-14-2013, 05:04 AM   #34691
Yaozer
Oddometer: 178
X kickstand length
Can someone with an X measure the length of an x kickstand? PLease let me know bc my kickstand was bent this weekend and I need a replacement asap.
Yaozer screwed with this post 04-14-2013 at 06:34 AM
Yaozer is offline   Reply With Quote
Old 04-14-2013, 05:28 AM   #34692
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,815
Have you done this? Can you explain how? I just had my front wheel off and can't envision how you could remove and reinstall it without removing the axle nut.
cjbiker is offline   Reply With Quote
Old 04-14-2013, 06:48 AM   #34693
mpatch
Oddometer: 1,032
It's not possible. Just some more bad info.
Old 04-14-2013, 07:09 AM   #34694
AZ TOM
Oddometer: 4,044
Common sense prevails again
AZ TOM is offline   Reply With Quote
Old 04-14-2013, 07:56 AM   #34695
sturgeon
sturgeon's Avatar
Oddometer: 943
Dang! And here I thought I was gonna see a new variation on those steel ring puzzles
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Times are GMT -7.   It's 04:02 AM.
