Old 04-15-2013, 11:00 AM   #34726
Revvy
Okayest Adventurer
Revvy's Avatar
Oddometer: 40
Chain adjustment for non-standard suspension
I'm new here, and I've flipped through this thread, but haven't found what I'm looking for. I've seen a lot of 'how to' chain adjustments, but I'm not sure if my particular case is different:
I bought my WR250R with an aftermarket rear suspension set up (Revol out of Washington State) that is lower than factory. When I attempt to adjust my chain as per the instructions by pressing up on the chain to the bottom of the swing arm, the chain touches the swing arm guard. I feel like this would happen on a standard suspension bike, so it makes me feel like my chain is not correct.
Also, I have non-stock gearing (13/47). Wouldn't this change how the adjustment should be performed as well?
Not only am I new the to WR, I'm new to bikes in general. If someone could point me in the right direction on how to properly set this chain up, I'd really appreciate it.
Also, on my new chain, it looks like it has wear signs on the inside loop of the chain. Is that normal? The gold plating is wearing off on the side where it meets the gearing.
Revvy is offline   Reply With Quote
Old 04-15-2013, 11:33 AM   #34727
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,349
Check the underside of you swing arm at the front near the pivot point. That is where the wear always occurs on the guard(seal). As the suspension is compressed, the swing arm moves up to parallel with the ground, it is at that point that the chain is at its tightest position and wears the guard on the bottom, if you go beyond that point it begins to wear the top more, but it is very seldom that you would ever be long at this point. To me it sounds like your chain may be a little loose but generally with these bikes, loose is better to a point.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 04-15-2013, 11:42 AM   #34728
skierd
Wannabe Far-Rider
Oddometer: 2,938
More Cowbell - Mine's at 43,xxx miles and has never burned a drop of oil and doesn't smoke at all. It does feel a bit down on power, not sure if its just needing a valve adjustment or if its finally ready for a top end. Might get her back together and go for a ride this weekend.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 04-15-2013, 02:13 PM   #34729
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Red Sand View Post
And I'm just getting started . . . I already have a big bore kit, new bar & bar mount, rear sprocket, engine/FI computer, air filter, slip-on, tires, rack, panniers, and other items in the shopping carts . . . and this is already after spending $1200 on rider gear . . . I think it would have been cheaper to take up crack or something . . . so I wonder, does the spending have a terminus?
Depends on what you need the bike for, how much money you have to spend, and I've heard whether or not you're married. For me, my bike is my daily driver, my weekend getaway to the desert/mountains, and my long distance tourer. It has to do it all - consequently I've spent a lot.
Here's a pic of my dash, complete with hidden OEM ODO and my Trailtech Voyager. The Highway Dirtbike setup is new too. I have a small fuse panel on the way so I can get USB power on board and clean up my battery terminals, gearing and tires (of course) in the near future.
I have no problem with someone throwing money at this bike, just because it's little doesn't change the fact that I need it to do more than the guy who goes and rides OHV areas on the weekend. Do what you want - don't worry what other people think.
UtahFox is offline   Reply With Quote
Old 04-15-2013, 02:16 PM   #34730
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by BaronVonDarrin View Post
well I am 6 even and shes shorter than I am so maybe not. Would lowering it with a link help? I believe she is 5'8''.
Inseam matters more than height. I'm 31", I lowered the bike 1" and I'm on the balls of my feet, one foot flat if the other is on the footpad.
Old 04-15-2013, 02:23 PM   #34731
KustomizingKid
Oddometer: 678
Buddy just bought an 08 X and I get to ride it all week.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 04-15-2013, 03:46 PM   #34732
TwilightZone
Oddometer: 3,068
>"Ok, I have had a 08 WR250R for a few weeks now. I have had a lot of bikes in the past. I knew going into this that it didn’t have much power. I have 13/45 gearing. The speed-O is way off, like indeacated 80mph is 68mph on the GPS. Is this the norm? The bike has just over 6000 miles on it, probaly more like 5000 or so. So my big Qustion is, can I ride this bike all day at almost full trottle without blowing it up. And how long can I do this till it needs a rebuild? The motor and pipe is all stock. I don’t want to spend the money on a pipe and programmer for just a little more power. It dosent seem to me to be worth the money. Tell me what you think"
IMHO: Spend the money on the pipe, header and fuel programmer. It makes the bike perform differently... and I mean big differently. A 5 to 7 Hp gain on the stock 250 engine is pretty substantial. Rest of the performance gain is simply taking stuff off the bike and opening up the airbox.
>"The speed-O is way off, like indeacated 80mph is 68mph on the GPS. Is this the norm?"
Unfortunately...yes... but you can buy a 'speedo-healer' from 12 O'-Clock labs (or another vendor). This is something that Yamaha should have programmed into their ECU. Bummer!
Sticking with a 13 tooth front sprocket, 47 or 48 is the right size rear. (IMHO Stuff)
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 04-15-2013, 04:06 PM   #34733
UtahFox
UtahFox's Avatar
Oddometer: 446
I replaced my ODO completely with one that calculates speed & distance via a wheel sensor + GPS. Admittedly the more expensive solution, but I couldn't see spending $80 bux on the dongle and just get that one feature out of it. I plan on using my phone for city/hwy navigation, and maps for the backcountry.
Old 04-15-2013, 04:10 PM   #34734
jon_l
jon_l's Avatar
Oddometer: 3,207
But you left the OEM speedo connected, right? Doesn't the WRR/X need this to be there?
CBF1000 & PCX150
jon_l is online now   Reply With Quote
Old 04-15-2013, 04:12 PM   #34735
UtahFox
UtahFox's Avatar
Oddometer: 446
Yeah, it's mounted on the other side of the dash, you can see the ass end of it below the Voyager in the pic above. I'm going to cover that hole at some point. I'm only mounting a small USB port on the dash, so I have plenty of room and its buttoned down pretty good up there.
Old 04-15-2013, 05:52 PM   #34736
ba_
ba_'s Avatar
Oddometer: 2,755
What does wear at the back of the guard mean? That it's just doing its job?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 04-15-2013, 06:02 PM   #34737
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,731
Originally Posted by MeefZah View Post
I do. Offer away.
Thanks, I've got one on the way.
cjbiker is online now   Reply With Quote
Old 04-15-2013, 08:31 PM   #34738
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 330
Hey have stock handlebars mirrors and chain if anyone wants to make an offer. Also other assorted ais and other junk I took off my 12 wrr
EEKAMOUSE is online now   Reply With Quote
Old 04-15-2013, 09:16 PM   #34739
Subaru297
Oddometer: 116
That is a nice setup. I have the Lynx fairing on my ADV bike as well. I find it much nicer without the windshield on. Try removing it and going for a ride. Much smoother airstream over the helmet. Height dependent of course.
Actually with the windshield on no matter where i adjusted it the wind blasted me in the helmet causing lots of noise and turbulence. With it removed the wind hits my neck and shoulders which is much nicer for me.
Subaru297 is offline   Reply With Quote
Old 04-16-2013, 12:16 PM   #34740
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,483
290ism
...beauty, eh?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Times are GMT -7.   It's 05:51 AM.
