Old 04-23-2013, 01:01 PM   #34966
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,052
Originally Posted by WeazyBuddha View Post
Yours seems to have started as an X so what you did is what I'd do.
However, I'm starting with an R, and its weaker brakes. So, I am wondering if anybody with an R has laced X components to their DS wheels and then gotten a second set of wheels for SM also with X components.
As a new WR owner, thanks for the patience as I slowly start to get the hang of things on this thread and on my WR knowledge.
Perhaps the R brakes are fine doing SM duty and any marginal gain from the X components may not be worth the trouble.
Do you know for a fact that the R has weaker brakes?? As far as I understood, the X just runs a bigger rotor, therefore, it(caliper) is mounted further out on the fork tube, achievable with an adapter bracket. I had always thought the calipers and pads were the same, albeit with different first three digits in the part number, due to Yamaha's numbering system, and those first three digits referencing the bike the parts are for.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 04-23-2013, 01:22 PM   #34967
mpatch
Oddometer: 987
physics would say bigger rotor = more stopping power given everything else being equal
mpatch is offline   Reply With Quote
Old 04-23-2013, 01:28 PM   #34968
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,052
yes, I am with you on that....somewhat. But, the bigger rotor on the X vs the R is more for, less brake fade, due to the chances of the X using its front brake more than the R, in its typical riding environment. The calipers and pads, sans mounting location, should be identical, as far as function. If I am correct, surface area of pad, does not care how big the rotor itself is.
Bigger caliper, bigger pad and bigger rotor, would make for "better" braking, IMHO.
Old 04-23-2013, 01:28 PM   #34969
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,350
I've never had a problem stopping the R. Normally you lose wheel traction before you come to a full stop me have to let off the brake anyways.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is online now   Reply With Quote
Old 04-23-2013, 01:38 PM   #34970
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,199
WRr's and Tunnels
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 04-23-2013, 01:39 PM   #34971
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 760
Originally Posted by BlueLghtning View Post
I'm getting to where I'd rather run a Shinko 244 rear and maybe something a bit more aggressive on the front like a MT21 or TrackMaster II front. That makes a nice combo when you need the traction and still decent life.
Don't do it. The TM II front tire sucks. The MT21 front would be way better. I really like the Scorpion Pro of the MT16 fronts.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 04-23-2013, 01:49 PM   #34972
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,892
No
Sounds like I'm splitting hairs and the R hubs/rotor/brake components laced to SM wheels would be fine.
I did shoot an email to Wheeling Supply.
After I resolve the wheels question it'll be on to the exhaust/ECU/tuning dilemma.
Wish I could do a Jay Leno, ask that the bike be setup and let me know when ready.
A drunk driver killed someone I love
WeazyBuddha is online now   Reply With Quote
Old 04-23-2013, 01:54 PM   #34973
Gryphon12
Gryphon12's Avatar
Oddometer: 1,333
I havent investigated the hubs on the stock wheels for the R and the X, but I wouldn't be at all surprised if they are identical.
The front brake calipers are the same, as are the stock pads. The only difference is a larger diameter rotor and a different caliper mounting bracket. The master cylinders appear to the identical (again, in contrast to others like the TE/SMS 630).
Yes, increased leverage results in the X having greater stopping power on the front wheel. In reading thousands of posts on these threads, it is uniformly considered a BAD thing in the dirt. The X brake locks the front wheel too easily for most (aggressive) riders. Also, and more important to some, the larger diameter X rotor places the caliper at increased risk of damage in a slide or crash - it is harder to protect.
The consensus it that the R brake is perfectly adequate, and more than adequate in the dirt. On the street, with X wheels and tires, with more rubber contacting the ground, the R brakes feel weak to some. This appears to be strongly correlated with their past history (street vs. dirt) and their expectations for performance, rather than linked to any real performance inadequacy.
As a counterpoint, several contributors here run knobbie tires on X wheels (I'm thinking of one in particular on a WR250X because he has a short inseam and likes the lower ride height on the X but wants full suspension travel). They have never reported that the X front brake is "too strong" in their dirt riding, but I didn't get the sense that they were aggressive riders.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 04-23-2013, 01:57 PM   #34974
WeazyBuddha
Oddometer: 4,892
Makes complete sense. Thank you, kind sir.
Edit for follow-up question: Do the X and R rotors swap out? If I buy used X wheels can I just put an R rotor on them for easy swapping?
Old 04-23-2013, 02:34 PM   #34975
Wingnut037
Two Sheds
Wingnut037's Avatar
Oddometer: 284
I believe the rotor and brake components are a bit better on the X vs. R.
With that in mind, has anybody laced DS wheels to the X hubs to benefit from the better brakes?
I'm tempted to lace R hubs to SM wheels to be able to switch back and forth quickly but am wondering if there is anything to gain from doing it as I describe above, DS wheels on X components.
I run a full 'r' setup on my 'x' in dirt mode and my wife's dirt setup is with warp9 wheels with the x rotor. For ease I suggest using an r hub for the am setup. Your brakes are sufficient unless you get in a track type situation where fade can come into play.
Wingnut037 is online now   Reply With Quote
Old 04-23-2013, 02:35 PM   #34976
Red Sand
Red Sand's Avatar
Oddometer: 299
First of all, mega-thanks to all who posted comments and suggestions about tires - extremely helpful!
Originally Posted by Gryphon12 View Post
Yep. Use a bigger rear sprocket and the same length chain and the center-to-center hub distance will change slightly. A bigger sprocket will force the rear hub very slightly forward with the same length chain. Two-tenths of an inch isn't much - it's the same swing arm, but different rear sprocket.
So, if I understand this correctly, I can replace my OEM rear sprocket with one that's 3 teeth more without having to either break or get a new chain and the only difference with the 3-tooth-larger rear sprocket will be the rear axle moving forward ~5mm?
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 04-23-2013, 02:47 PM   #34977
KansasBob
KansasBob's Avatar
Oddometer: 515
I put on a 44, one tooth up, and that was as far as the chain could go.
KansasBob is offline   Reply With Quote
Old 04-23-2013, 06:50 PM   #34978
ghollaba
Backroads
ghollaba's Avatar
Oddometer: 60
Lower Brake Pedal?
Loving the WR but need to lower the brake pedal. Google found several options but want to hear from the pros here..
What do you suggest?
ghollaba is offline   Reply With Quote
Old 04-23-2013, 08:03 PM   #34979
mpatch
Oddometer: 987
Use the factory adjustment on the master?
Old 04-23-2013, 11:02 PM   #34980
indypup
indypup's Avatar
Oddometer: 3,761
Originally Posted by theMISSIONARY View Post
WRr's and Tunnels
Cool pic! ;)
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Times are GMT -7.   It's 06:54 PM.
