Old 04-25-2013, 12:15 PM   #35011
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,362
Just call up warp9 racing tell them you want sm wheels for an r and what colour you want and then you will have a complete set to swap over depending on your mood. Me I got another set of r wheels so I can have aggressive and not so aggressive tires already mounted. One set for my daily commute. One set for my weekend riding.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 04-25-2013, 01:02 PM   #35012
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,224
Originally Posted by skierd View Post
Depends on the weather, the type of trip, and the rider. Lots of dirt i'd say 250 max. Lots of pavement 500 max, but if you're in sight seeing mode probably closer to 350.
I've done one-day 500-mile trips on my Spyder and know I can't do that on the WRR (yet). Splitting the difference of your other two numbers, 300 miles sounds like a nice round number: 60 MPG = 5 hours in the saddle. Now to convice the wife to let me go on an overnight to Seneca Rocks, West Virginia for "training."
Originally Posted by Red Sand View Post
If you haven't installed a larger gas tank, I'd suggest doing so. I just tossed on an IMS 4.7 gallon tank - awesome mileage compared to what I was getting with the OEM.
I have the IMS 3.1. It's what the bike should have come with.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 04-25-2013, 01:50 PM   #35013
yaw
lost
yaw's Avatar
Oddometer: 76
Eh? Starter dampener
Rode across the border from Baja and my bike started sounding a little funny. Got to Death Valley and it was making a racket. Heard many theories including the main bearing from the Honda dealer in ridge crest. 08 with 22,000 trouble free miles... It ran fantastic but sounded horrible. Started as normal, no loss of power, no shifting issues... Ran like it always does.
Got home and pulled the engine. Took the head off and everything looks brand new inside. Oil was clean. timing chain looked great. Friend had a theory the starter dampener might be bad. We thought it rotated one way during starting and free rotated once the engine was running ( so the starter was disengaged). I took it to the Yamaha dealer to make sure I understood how it worked. They confirmed. Said mine was obviously broken since it didn't rotate. Yamaha rep was standing right there.
I went home to order and found out it was called the starter dampener and that there was another piece called the starter clutch. Went back to the Yamaha dealer and asked again to make sure. I asked how it worked and he basically described it the same. When the starter motor turns over the gear is engaged but as soon as the engine is running the gear slips (ie rotates freely without engaging the starter motor).
Ordered the new part. Arrived and does not rotate freely just like mine! Took it back to the dealer and the same guy was stumped. He then proceeded to tell me that 22,000 was a lot of miles for the wr250r...
So I'm likely going to be opening the lower end...
Sorry for the long story. Can someone explain what this dampener does?
Thanks! Marc
10 ktm 530 exc
08 yamaha wr250x
07 ktm 990s sold
67 bmw r69s sold
yaw is offline   Reply With Quote
Old 04-25-2013, 01:56 PM   #35014
AZ TOM
Oddometer: 4,044
Yaw, the guy that said 22,000 was a lot of miles probably thought it was an F & doesn't know the difference between the F & the R
AZ TOM is offline   Reply With Quote
Old 04-25-2013, 02:44 PM   #35015
CJ smith
Oddometer: 23
Originally Posted by ssregal39 View Post
if that is rust, then unlikely. it knocked the plating off. there are places that can rechrome the tubes or buy new/used.
Replacing means $300 for inner tube,+seal rebuild kit & oil+specialty tools. If anyone comes across a used fork for the wr250r please let me know. Until then I'll try sanding & filling in with epoxy.
CJ smith is offline   Reply With Quote
Old 04-25-2013, 03:38 PM   #35016
jon_l
jon_l's Avatar
Oddometer: 3,300
Originally Posted by ArmyJoe View Post
I've got less than 2500 miles on two wheels and I'm riding almost daily to build up my skills and stamina. I'd like to do a 1200 mile mixed-surface ride down to North Carloina (Deal's Gap) and back. How many miles or hours a day do you think is reasonable on a WRR? My route will use US Highways, but no Interstates.
Thanks,
Joe
Assuming you are also planning to have fun, much less than 500. Not sure what sort of roads you intend to ride. Smaller the better for me.
Assuming a moving average of 35 mph, 8 hours of riding is 280 miles. Adding time for occasional interesting detours, stops for coffee & toilet, a meal, fuel, that could be a pretty full day.
I hope you have a more comfy seat than OEM.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 04-25-2013, 03:50 PM   #35017
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,975
Thanks,
Joe
I just did a google map from Columbus to Deals Gap. Looks like if you slabbed it it'd be around 400 miles. Maybe 500 or more if you went backroads. Were I you I'd get the DeLorme Gazetteers for the states you'll be passing through and route on forest service roads where possible. You're looking at a two-day trip in any case, but doing some gravel along the way will make it more fun. If you figure 250 miles a day that's very doable. BTW, if you don't have an aftermarket saddle, a WallyWorld ATV seat pad will make a tolerable substitute. Just sayin'... Good luck!
GSBS is offline   Reply With Quote
Old 04-25-2013, 04:30 PM   #35018
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,813
I would smooth use a ceramic slip stone rather than sand paper.
cjbiker is offline   Reply With Quote
Old 04-25-2013, 05:29 PM   #35019
Rider_WV
Rider_WV's Avatar
Oddometer: 2,375
If you decide to head to wv let me know I'm always down for a weekend trip to the mountains! Lots of good campsites and plenty of riding of all types.
Rider_WV is online now   Reply With Quote
Old 04-25-2013, 06:16 PM   #35020
eemsreno
Oddometer: 982
good creek crossing
eemsreno is offline   Reply With Quote
Old 04-25-2013, 06:19 PM   #35021
Fitty
Shopping cart rider
Fitty's Avatar
Oddometer: 205
Thanks! Marc
This is the only engine failure I know of, so certainly not an epidemic. Part was updated in 2010. Just an FYI.
http://www.advrider.com/forums/showp...ostcount=26279
Fitty screwed with this post 04-25-2013 at 06:27 PM
Fitty is offline   Reply With Quote
Old 04-25-2013, 06:34 PM   #35022
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by eemsreno View Post
Looks pretty impressive if you crossed over those huge rocks/concrete...
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 04-25-2013, 07:36 PM   #35023
Bogus Jim
Oddometer: 110
Thanks! Marc
The starter damper does slip, but only under high torque loads. It's intended to prevent gear/starter damage when something locks up. The starter clutch, on the other hand, should spin very freely in one direction and lock in the other. If it's locking in both directions that could definitely cause a racket.
I just had my engine apart recently... also @ 22,000 miles, same as yours. The fact that your oil is clean would seem to indicate there is no major damage yet. Good luck, let us know what you find.
2012 800 XC
2009 WR250R
2008 250 XC-W
Bogus Jim is offline   Reply With Quote
Old 04-25-2013, 08:26 PM   #35024
indypup
indypup's Avatar
Oddometer: 3,764
Wow, that looks like a puzzle I would like to put together! Nice first post!
Old 04-25-2013, 08:45 PM   #35025
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,954
I was thinking the opposite
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Times are GMT -7.   It's 11:18 AM.
