Old 04-29-2013, 01:54 PM   #35116
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by Subaru297 View Post
Pull the bolt out of the bottom of the shock and run the swingarm up through its complete range of motion. You will easily be able to tell where the chain is at its tightest point. Leave it a little loose at that point and you shouldn't have any problems.
This works on any bike with any gearing and hardly takes any longer than measuring chain slack.
I think the slider being eaten is from chains that are too tight as well. I have run mine too loose with stiff links and my slider is still fine.
Hmm, I go through sliders like crazy. I'm going to try your method! ;) My preload is at max too. Most of my riding is off-road. I weigh about 275# with gear too. :(
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 04-29-2013, 01:55 PM   #35117
Subaru297
Oddometer: 117
Let us know how it works for you. It is surprisingly quick and easy to do as long as you have a stand for your bike.
Subaru297 is offline   Reply With Quote
Old 04-29-2013, 01:56 PM   #35118
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,815
+1. This is the only way to be sure your chain tension is correct.
cjbiker is online now   Reply With Quote
Old 04-29-2013, 02:41 PM   #35119
UtahFox
UtahFox's Avatar
Oddometer: 446
In the middle of a week long tour, piecing it together from as many dirt roads as possible. At the southern end of the Smoky Mountain road I came along a camp site that compares with the best I've been to. The Smoky Mountain road was a blast, with a mix of sand and slickrock in which the bike performed flawlessly, its better than I am. I'll post a link with more photos when I get home.
Doubt there was anyone within ten miles of me in this pic, you can just see the road descending with Lake Powell in the backround.
UtahFox is offline   Reply With Quote
Old 04-29-2013, 03:09 PM   #35120
iWander
Adventure Geek
iWander's Avatar
Oddometer: 61
Wow, paradise!
iWander is offline   Reply With Quote
Old 04-29-2013, 03:18 PM   #35121
iWander
Adventure Geek
iWander's Avatar
Oddometer: 61
Originally Posted by MeefZah View Post
Jesus Christ, $450 for that???
That's 30% of the cost of my WRR, used.
After scouring the interweb, it appears the Extreme Race Light may not be DOT approved for use on the street. Friggin' cool light, but Wisconsin Troopers will likely fine you and make you trailer it home. If there's not a trace of blue to the tint, you might get lucky and skate past them....might.
Old 04-29-2013, 03:40 PM   #35122
Red Sand
Red Sand's Avatar
Oddometer: 300
Three questions:
#1 - Is it difficult to get the shock bolted up again?
#2 - It would seem like this procedure should only have to be done once - after setting the chain tension, put the bike on the stand, put it in first gear, measure the slack at "midway" and always keep this tension - true?
#3 - How important is it to adjust the chain when it's "warmed up" - is there a significant or noticeable difference in slack between a cold chain and a "just ridden" chain?
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 04-29-2013, 04:14 PM   #35123
TwilightZone
Oddometer: 3,123
>"I weigh about 275# with gear too. :( "
Yup... same problem here. I went to a 14t countershaft sprocket and there is almost no wear on the chain guard. Replace the chain guard at 7k for a trip to Death Valley, it was like new, so I hung it up for a spare.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 04-29-2013, 04:23 PM   #35124
jon_l
jon_l's Avatar
Oddometer: 3,309
Originally Posted by z@ch View Post
running too loose is just as risky as too tight. A bigger rear sprocket helps the most, IMO.
Or a bigger front, depending on who you ask.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 04-29-2013, 04:29 PM   #35125
jon_l
jon_l's Avatar
Oddometer: 3,309
Originally Posted by DougZ73 View Post
Shep, as awful is it may be to find, you may have to search through this thread to get the right answer.
You can read 'em all, but there isn't 1 definitive answer.
Check the chain slider often. Keep a replacement in your shop.
CBF1000 & PCX150
Old 04-29-2013, 04:30 PM   #35126
TwilightZone
Oddometer: 3,123
>"#1 - Is it difficult to get the shock bolted up again?"
Not if you have a center stand... so the bike can be supported in the middle, swingarm sags, pretty easy.
I haven't pulled the shock to adjust my chain... had my son climb on the bike (he's big), then I leaned on the back of the bike and felt the chain tension... that is with the swing arm nearly level. It took a bit to set the tension as tightening the axle bolt changes it!
Get off, tighten axle, shit the tension is wrong, loosen axle, son back on, and re-do it... (a couple times).
>#2 - It would seem like this procedure should only have to be done once - after setting the chain tension, put the bike on the stand, put it in first gear, measure the slack at "midway" and always keep this tension - true?"
IMHO: If you get the chain tension set properly, you can 'remember it', or pick some sort of tool, or fingers, or whatever to set it in the future.
>"#3 - How important is it to adjust the chain when it's "warmed up" - is there a significant or noticeable difference in slack between a cold chain and a "just ridden" chain? "
Dunno. I just set mine up at whatever temp it is outside.
Important stuff.
1) Chain properly tensioned and aligned.
2) Chain has no binding links.
3) If you're light... a 13 tooth sprocket is ok. Heavy like I am... 14 tooth.
Old 04-29-2013, 04:44 PM   #35127
KansasBob
KansasBob's Avatar
Oddometer: 515
  1. The dynamics of the chain and swing arm on the WRR suck.
  2. Adjusting the chain to the "perfect" point is troublesom.
  3. Even if you have it adjusted correcty, riding conditions on any kind of extended ride can result in seal guard failuar.
The best thing to do is have one or two on the shelf, and replace as necessary.
KansasBob screwed with this post 04-29-2013 at 05:08 PM
KansasBob is offline   Reply With Quote
Old 04-29-2013, 04:56 PM   #35128
what broke now
Petroleum Brother
Oddometer: 1,429
Originally Posted by KansasBob View Post
  1. The dynamics of the chain and swing arm on the WRR sucks.
Yeah, I say we set 'em all on fire and go orange
what broke now is offline   Reply With Quote
Old 04-29-2013, 05:10 PM   #35129
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by what broke now View Post
[/LIST] Yeah, I say we set 'em all on fire and go orange
Seal Guard replacement is Chump Change compared to the cost of buying, and operating Orange Machinery!!
Old 04-29-2013, 05:22 PM   #35130
what broke now
Petroleum Brother
Oddometer: 1,429
Just a joke, Bob. I own both, orange ain't that bad given what they do.
Times are GMT -7.   It's 10:50 AM.
