Old 05-03-2013, 02:28 AM   #35236
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,053
Originally Posted by goroka View Post
Have been wondering for some time just how far you can take the chain before it breaks due to excessive wear . Couldnt find anything by a search of this forum. I have found that I usually use 2 x front sprockets to one rear sprocket to one chain.
Is there any way of judging the max wear with the chain on the bike.
Cheers
Hi Hamish
You can measure the 'stretch'. But I guess that's just the advised limit.
Renthal say this:
During use a chain will stretch (i.e. the pins will wear causing extension of the chain). To measure how much a chain has stretched, put the motorcycle in gear and rotate the rear wheel to tension the top strand of the chain. Measure accurately (ideally with a vernier) 16 links, counting both roller and pin links. If the length of the measured 16 links is greater than the maximum acceptable length given in the table below then the chain should no longer be used. These figures assume a 2% maximum allowable extension for non 'O'-ring chain and a 1% maximum extension for 'O'-ring chain.
520 chain
Original Chain Pitch
Maximum Acceptable Lengths
Non 'O'-ring chain
'O'-ring chain
5/8" / 15.875mm
10.2" / 259.0mm
10.1" / 256.5mm
This guy will even sell you a tool to measure it http://www.dirttricks.com/Chain-Wear.htm
... or do you mean something different
Reeksy is offline   Reply With Quote
Old 05-03-2013, 02:37 AM   #35237
goroka
Oddometer: 93
Chain wear
Originally Posted by Bogus Jim View Post
Measure the links with the chain tight.
WRR owner's manual recommends 0.003 inch per link wear limit, which is half of the 0.006 inch limit mentioned in the dirt tricks article.
Excellent - thanks for that. Will give that a go. I have a strong suspicion that that I am probably over the limit. I think it was the left overs of the rollers that I could hear rattling around on the last chain
Cheers
goroka is offline   Reply With Quote
Old 05-03-2013, 05:03 AM   #35238
CJ smith
Oddometer: 23
Thanks Scott & Jim for the video links.
I was thinking about doing both forks but it turns out $32 worth of Yamaha's 01 fork oil is just shy of enough to fill both forks. Definitely going the less expensive route next time around. I figure 1 liter should be enough to fill the one fork that needs it, and maybe top off the other fork just to be sure they are the same height.
Speaking of fork oil height, anyone know the spec for that off the top of their head?( I want to say its 105mm measured from the top of fork)
CJ smith is offline   Reply With Quote
Old 05-03-2013, 05:31 AM   #35239
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 759
Originally Posted by GSBS View Post
We should ride sometime! Are you going up for the Trials event at Sequatchie TN May 25-26?
Yes we should ride sometime. I saw the thread on Bamarides but I haven't given it much thought. It would be cool to watch though.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 05-03-2013, 05:33 AM   #35240
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,943
We went in 2008, the last year the World Championship caliber riders were there and it was, without question, the most amazing thing I've ever seen on two wheels.
GSBS is offline   Reply With Quote
Old 05-03-2013, 06:36 AM   #35241
what broke now
Petroleum Brother
Oddometer: 1,394
The spec is a baseline; filling to 110mm is feasible if that is all the oil $32 worth provided. The length of that "air chamber" is often used as a tuning tool.
what broke now is online now   Reply With Quote
Old 05-03-2013, 07:57 AM   #35242
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by skierd View Post
Some non-WR content... took my new bike on a spring road trip around Alaska.
My quick 4 day spring ride...
Brrrr. I'm having a hard time leaving Flagstaff because its in the 50s with double digit winds.
UtahFox is offline   Reply With Quote
Old 05-03-2013, 08:08 AM   #35243
soupknotzee
soupknotzee's Avatar
Oddometer: 244
I just changed the oil in my forks to Maxima Race Fork Fluid 5 wt or 85/150 purchased here LINKY I went with 110mm per recommendation from notable suspension tuner. 1 liter is NOT enough for both legs DAMHIK 7 clicks on compression and 8 on rebound. I may try 8 on compression next as it felt a slightly harsh on initial movement. The front end now feels more compliant and hasnt been bottoming out bad on the big landings like before with the OEM fish oil in there.
soupknotzee is offline   Reply With Quote
Old 05-03-2013, 08:24 AM   #35244
UtahFox
UtahFox's Avatar
Oddometer: 446
FYI, I'm running the Pirelli MT43 DOT trials tire on my WR-R (4.00" x 18) and it is significantly taller than the stock 120/80-18 size. I compensated for the taller gearing effect with a 47T rear sprocket (+4) and still run the 13T front. Aside from being 1/2-inch taller (when the tire is new) there is no noticeable change in the feel of the bike. I'm on my third MT43 now and expect this to be my rear tires for the WR from now on. Very happy with it!
So what is this gearing effect you speak of here? If you left the stock gearing what would be the effect then? I'm fixing to change tires after I get home.
Also, I'm really easy on tires so I'm trying to find a balance of better performance in sand & dirt, while getting as many miles as I can out of them. Having a hard time deciding on the front.
UtahFox screwed with this post 05-03-2013 at 08:33 AM
Old 05-03-2013, 11:28 AM   #35245
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Anyone know what size "mm" forks we have? I'm looking to pick up Motion Pro Fork Seal Bullet to help assist me doing my fork oil change.
leftystrat62 is offline   Reply With Quote
Old 05-03-2013, 01:22 PM   #35246
shep546
shep546's Avatar
Oddometer: 215
Hey guys,
When I put my FMF pipe on I removed the exup cables and wrangled up one of them in the process...
If I put the stock pipe back on does the valve stay open? Is it fine without the cables?
shep546 is offline   Reply With Quote
Old 05-03-2013, 01:30 PM   #35247
AZ TOM
Oddometer: 4,000
Not needed to change fork oil. Remove fork, remove top cap, turn upside down, drain & refill. I think the forks are 48mm
AZ TOM is offline   Reply With Quote
Old 05-03-2013, 01:50 PM   #35248
skierd
Wannabe Far-Rider
Oddometer: 2,938
Originally Posted by shep546 View Post
Hey guys,
Yes, it'll be fine. Default position of the valve is open.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 05-03-2013, 01:53 PM   #35249
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,328
Hey guys,
FMF Too Loud?
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 05-03-2013, 01:59 PM   #35250
shep546
shep546's Avatar
Oddometer: 215
Originally Posted by Scott_PDX View Post
FMF Too Loud?
Nope I was just wondering if I should bother keeping my stock pipe at all for when I sell it
Times are GMT -7.   It's 09:04 PM.
