Old 05-11-2013, 05:47 AM   #35416
shep546
shep546's Avatar
Oddometer: 215
So I did an AIS removal a while back... I took the pipe leading to the header, cut the pipe off, filled the hole with an aluminium nut and high temp silicone and just clamped it back off to plug the hole. Worked great until today.
I'm cruising on the highway at about 110km/h and all of a sudden I lose a bit of power, engine sounds weak... I'm like shit I'm running out of gas? Pull over and I did a once around and noticed the nut fell out...
the silicone held up fine it must have been the vibes.
So now I need to either weld a nut in there or get a piece of aluminium cut.
shep546 is offline   Reply With Quote
Old 05-11-2013, 08:09 AM   #35417
woofer2609
woofer2609's Avatar
Oddometer: 762
Originally Posted by zekester63 View Post
As far as rubbing goes, I have an X and I run both X and R wheels with no problems, swapping them based on the riding I'll be doing. There is no rubbing at all up front with my 606. I've got my swap down to about 30 minutes, front and rear, including the front caliper swap/bleeding.
Originally Posted by woofer2609 View Post
I hope I am not repeating common knowledge here, I've spent some time searching to find the answer to no avail.
I have an X, and just purchased some W wheels. The X wheels will be getting a 45t, the W's will be getting a 47t. ( I am currently using the stock 13/42, and 1st is just too tall. 6th actually feels about right. I'm coming from an XT225 which has a REALLY wide ratio.)
1.-I am curious how much slack the axle blocks take up(the site mentions 13mm, but what does this equate to in terms of links?) Will reversing them leave you with a similar amount of chain slack between the two different sprockets (45 and 47t)? Does anybody have experience with this?
2.- I know some people talked about the X fork guards rubbing R wheels, is this the case the other way around, and do the X guards need to be modified to run R wheels. I will be switching out the X brake setup for an R setup when switching wheels as well.
Thanks everybody!
Thanks Zekester, now, as far as the Zeta block questions, do they minimize the need for the chain slack adjustment? Somebody? Bueller?
woofer2609 is online now   Reply With Quote
Old 05-11-2013, 08:12 AM   #35418
UtahFox
UtahFox's Avatar
Oddometer: 446
I installed some yesterday, so I can't specifically answer your question. The reason I installed them is that Kalani recommended them because they make adjusting chain slack more simple. I'm not sure they solve either, but they do look good.
Edit - here's the video, the Zeta blocks are @ 6:40, though he's fun so you may want to watch the whole thing...
http://www.advrider.com/forums/showthread.php?t=783481
UtahFox screwed with this post 05-11-2013 at 08:23 AM
UtahFox is offline   Reply With Quote
Old 05-11-2013, 11:29 AM   #35419
Advental
Oddometer: 14
UtahFox, I see that you have Rotopax plate on your rack. I was looking into my rack system and leaning towards Wolfman's soft luggage. I like the option of carrying fuel/water on one side and luggage on other if I'm only going out on a day/short trip. However Wolfman's website where they say how it is easy to remove their bag, they don't recommend riding without center straps over the tail holding two bags together on each side. I'm sure it is possible and its pobably their way of limitting their liability if/when the metal brackets fail if the bag was only supported by the brackets. Can you confirm this?
Advental is offline   Reply With Quote
Old 05-11-2013, 12:03 PM   #35420
UtahFox
UtahFox's Avatar
Oddometer: 446
I'm sure you can ride without the cross-straps if your luggage was really light. I don't think I'd have too much problem carrying a gallon on each side on a day trip. But I wouldn't go without the cross straps while touring.
Old 05-11-2013, 01:23 PM   #35421
jon_l
jon_l's Avatar
Oddometer: 3,213
Why not just run a strap across the tail onto the opposing rack?
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-11-2013, 04:08 PM   #35422
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
Wolfman Side Racks with Rotopax Mounting Plate
FYI: I have a set of Wolfman side racks and Rotopax mounting plate for sale in the Flea Market. Only used on one ride to New Brunswick last summer.
http://www.advrider.com/forums/showt...5#post21386845
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 05-11-2013, 05:43 PM   #35423
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,480
Cool2 Nice day on the Ridge
I was gonna sell, now I'm not...too good of a tool...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 05-11-2013, 08:06 PM   #35424
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,866
Hey RD-
What's the setup you have on the left rear? I am looking for some more storage space. If you have posted before, can you give a link?
Thanks, BP
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 05-11-2013, 08:15 PM   #35425
goroka
Oddometer: 93
Originally Posted by ReeksyOfOz View Post
Finally I got a chance to use the WRR the way I'd hoped.
A spare Friday afternoon and a willing WRR partner in crime and holder of the GPS (Goroka) and we hit out through the pineapple fields and forestry surrounding the Glasshouse Mountains (the plugs of long extinct volcanoes).
We met at the local servo where it rained like hell, but undeterred we spent a few hours cruising through wide open trails.
And down single track lantana invested sand and red clay mud pits - places my old KLR definitely let me down!!!
An absolute ball, loved every minute of it ... including getting a push when my battery died .
And there was just time for coffee on the run home.
Didn't see another bike or 4X4 until we were just finishing ... although there was a roo and a curled up python.
Thanks to ReeksyOf Oz for posting - we had a top ride. Unfortunately did not get any photo's of the tight stuff. Could of gone through with his old KLR but it would taken a lot of huffing and puffing on our part.
I never cease to be amazed by the capability of this bike. I ride with two distinct groups - the adventure bike riders with their big KTM's, BMW's etc and then the pure enduro bikes - I am slower in the fast stuff with the adventure riders but usually catch them when the going gets harder and they start dropping bikes . I am a slow rider in the single trail stuff with the enduro's but we ride in some seriously steep stuff and I always get to the top with them. I dropped the gearing a bit as most of my riding is enduro and added a aftermarket exhaust. I have done nothing to the engine and removed the bits that I dont need like pillion footpegs. Suspension is standard. Bike had done approx 17 000 km and hasn't missed a beat .
Cheers
goroka is offline   Reply With Quote
Old 05-11-2013, 10:51 PM   #35426
DefyInertia
Saratogian
DefyInertia's Avatar
Oddometer: 153
Dual sport = Good for nothing?
There's a feeling I get when I look to the West...
DefyInertia is offline   Reply With Quote
Old 05-11-2013, 11:32 PM   #35427
Advental
Oddometer: 14
New Rumble, thanks, but looks like someone else already sent you a PM for your side rack. Let me know if it falls through.
Anyway, for the suggestion about running the seat strap to the rack on the other side, I'm not sure if it will work... From the pics, it looks like a buckle will attach the straps together. Maybe I can buy some opposing buckle and extra straps which will be attached to the rack?
edit: I attached a pig tail for charger last time I rode it, but today on my way to work, my bike didn't start. I had no time to look into it, so I jumped into my car and went to work. Now that I'm home, I tried to jump start it. Before, my turn signals and display came on with code Er-1 or something with what sounded like a fuel pump and crazy noise like the buzz you would hear from transformer. I tried to jump start bunch of times and after several times, my head light came on. After the head light came on, I tried to use the start button. Well, it didn't work and head light shut down... Few more times trying jump start, it started! So I figured I will try to recharge my battery using different charger system tonight and see what the outcome is tomorrow. Hopefully it was just a crappy charger drained my battery and everything is all good.
Advental screwed with this post 05-11-2013 at 11:44 PM
Old 05-12-2013, 04:50 AM   #35428
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,732
I flaked out, so AFAIK they're still on the market.
cjbiker is online now   Reply With Quote
Old 05-12-2013, 07:34 AM   #35429
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
Originally Posted by BluePill View Post
Hey RD-
Thanks, BP
Discussed here: http://www.advrider.com/forums/showp...ostcount=35364
Tool tubes, one for the fuel, one for tire irons etc
Old 05-12-2013, 08:00 AM   #35430
UtahFox
UtahFox's Avatar
Oddometer: 446
So I watched the original Girl With The Dragon Tattoo last night, and was pleasantly surprised to see her riding MY bike. Well, it was an X but who's counting.
I'd ride bitch with Noomi Rapace any day.
Times are GMT -7.   It's 11:21 AM.
