Old 05-15-2013, 08:04 AM   #35521
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Rapid Dog View Post
...selling...what!?! ...well no one's come up with the ubercash and...
If you rode around town on the new tires and HD tubes you are probably feeling the weight plus the rolling resistance. I'm here to say swapping tires on this bike make a big change, not necessarily positive, but different at any rate.
I want to hear about it...
You know you will :) Whether or not my opinion makes any difference is another story.
So on my new chain, it comes coated in a waxy feeling substance. Do I strip that and use my own lube, or just leave it be for a few hundred miles?
UtahFox is offline   Reply With Quote
Old 05-15-2013, 09:33 AM   #35522
johnlt
Oddometer: 591
Just ride it. Back in the old days, we use to boil our chains in hot wax because it was a good lubricant and dirt didn't stick to it like it does oil. Now with o-ring and x-ring chains, it is probably OBE and many don't lube their chains at all, only clean them.
Johnlt
2009 BMW R1200 GS Adventure
2000 Suzuki DR200
1975 BMW R75/6
Yamaha WR250R
johnlt is offline   Reply With Quote
Old 05-15-2013, 11:17 AM   #35523
AZ TOM
Oddometer: 4,156
[QUOTE=Rapid Dog;21413493]...selling...what!?! ...well no one's come up with the ubercash and...
The best 290 WRXR on the planet. That would be an awful lot of pressure for any one to own
AZ TOM is offline   Reply With Quote
Old 05-15-2013, 11:19 AM   #35524
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
That would be me. I dont lube xring chains anymore. Just clean it. Chain lube just makes a huge mess that attracts grunge.
Hate gets you nowhere.
Old 05-15-2013, 11:36 AM   #35525
Revvy
Okayest Adventurer
Revvy's Avatar
Oddometer: 38
I posted this on the wr forum, but I'm looking for more photos concerning my fit issue with the IMS 3 gallon tank. Does everyone else's look like mine in this regard? My front black panel and side blue panel on the clutch side have a rather large gap that seems to me will be a huge mud collector. If your tank fits better than this, can you with post or pm me a picture so I can send it to IMS?
Just for clarification: I have made sure that the side clips are in place and slotted into the panel; I've made sure the front and rear brackets are in the correct position; I've made sure that the rubber pad under the tank is sitting correctly; I have not put the heat tape on the new tank; the panels align perfectly with the stock tank.
Revvy is offline   Reply With Quote
Old 05-15-2013, 11:42 AM   #35526
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,913
Yes, my IMS tank fit the same way. I spent way to much time trying to get everything to line up right, and it just doesn't. Go to Rick Ramsey's excellent WR250R site, and he reported the same issue.
cjbiker is online now   Reply With Quote
Old 05-15-2013, 11:43 AM   #35527
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,392
I don't think I can fit my fingers in like that? But I've got big hands. Yu know what they say about big hand??
Big non pink gloves. Lol
Ill get you a picture but I know the clip is broken on my left side so it sticks out more then it did. I wonder if fuel makes it expand???
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 05-15-2013, 11:49 AM   #35528
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,081
Mine looks like that, I personally don't really care... if I did care, I would be more annoyed with the gap at the seat.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 05-15-2013, 11:52 AM   #35529
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,663
...mine's about the same. Fitting a tank those plastic panels isn't critical.
It's dirtbike engineering is my guess. Not really an issue.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-15-2013, 11:52 AM   #35530
UtahFox
UtahFox's Avatar
Oddometer: 446
I posted this on the wr forum, but I'm looking for more photos concerning my fit issue with the IMS 3 gallon tank. Does everyone else's look like mine in this regard?[/IMG]
One thing I had to do when fitting mine was to put a washer on the forward screw of that rail the plastic slides onto. I'm guessing this is what you're seeing there, the plastic can't move back far enough.
I just went out and looked at it, it fits like a glove.
UtahFox screwed with this post 05-15-2013 at 11:59 AM
Old 05-15-2013, 12:10 PM   #35531
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,913
I can't picture what you're referring to. Is this on the tank mount or the left side plastic?
Old 05-15-2013, 12:17 PM   #35532
UtahFox
UtahFox's Avatar
Oddometer: 446
On the top of the tank, there are two 'rails' that you screw to the tank so that a notch in your plastics slide over them. On mine the rail was too tight to the tank, and by putting a washer under the rail on the forward screw, I was able to slide my plastics all the way on.
P.S. Getting my hair cut so will be gone for a while, lemme know and I'll take some pics when I get back.
Old 05-15-2013, 12:23 PM   #35533
Revvy
Okayest Adventurer
Revvy's Avatar
Oddometer: 38
Please do get a pic. I'd really like to make this fit better. I'll look into adding a spacer tonight when I get home.
Old 05-15-2013, 12:25 PM   #35534
UtahFox
UtahFox's Avatar
Oddometer: 446
Look for 2 brass rectangular fittings on the top of the tank, mine had these and its where the rail that came with the tank goes.
Cya in a couple hours.
Old 05-15-2013, 12:27 PM   #35535
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,913
Ah, right. Mine fit like crap too. I had to bend them to get the plastics on. I've had IMS tanks on a couple of bikes and the fit was terrible on both. It's too bad there aren't many alternatives. I haven't read too many problems with the Safari tank, but it's a lot more expensive and I don't like the idea of the secondary fuel pump... Oh well.
Times are GMT -7.   It's 11:57 PM.
