Old 05-16-2013, 09:33 AM   #35551
rhollamby
Oddometer: 333
Originally Posted by soupknotzee View Post
Height of the tire is the concern. 112 is what you need with the TALL MT43 so it can be farther back on the swing arm or it WILL rub the front mudflap. Width is not an issue here as this is a narrower tire.
I run 13/47 112 and have been on many of the steep stuff I ride my KTM300 on in CO at 13,000'+ and it can run out of steam with this gearing/elevation. Other than steep rocky climbs or technical single track 13/47 is pretty good all around. But if I had to fine tune it I would give 13/48 a go or the equivalent with a 14 tooth front.
What tire are you running with this gearing in this terrain? Taller tires like the D606's or mt43s or something more stock like the T63?
I'm shooting for overall gearing of 13/47 and believe the 13/49 with the mt's will achieve this.
Most of my riding will be 8,000-12,000 feet, and every couple weeks above 12k feet. Although to get to these trails running with more power at ~5-6k feet in elevation.
rhollamby is offline   Reply With Quote
Old 05-16-2013, 05:26 PM   #35552
Bogus Jim
Oddometer: 105
Originally Posted by Rapid Dog View Post
Measured the MT43 on my friends trials bike yesterday (400x18).
70cm or 27.5 inches tall.
Anyone know the height of the stock tire?
Mine measures 25.5". That is not the stock tire but it's a 120/80-18 50/50 knobby so should be in the ballpark. Not new; about 1/2 tread left.
2012 800 XC
2009 WR250R
2008 250 XC-W
Bogus Jim is offline   Reply With Quote
Old 05-16-2013, 05:57 PM   #35553
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,480
...that's what I got too, so the MT43 is gonna be a good 1"-1 1/2" taller...hmmm...I want to here reports.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 05-16-2013, 06:16 PM   #35554
rideonjon
Oddometer: 25
wheel spacers
does anyone have some wheel spacers laying around that they could measure for me.i just need the lengths from them I believe the fronts and the backs all have different lengths.it would be much appreciated.
cheers,
jon
rideonjon is offline   Reply With Quote
Old 05-16-2013, 06:18 PM   #35555
ramz
Professional Trail Rider
Oddometer: 2,001
More info here:
http://rickramsey.net/WR250Rmods.htm#tires
ramz is offline   Reply With Quote
Old 05-16-2013, 07:03 PM   #35556
rhollamby
Oddometer: 333
Originally Posted by ramz View Post
Thanks Rick, your part of th reason I'm going with these tires because I'll be riding in your back yard.
Seems like the 112 will work, thats what I'm going to go with.
Old 05-16-2013, 09:30 PM   #35557
Llamaha
Oddometer: 849
If I put Pirelli MT21's on my X will I need to change the gearing?
Llamaha is offline   Reply With Quote
Old 05-17-2013, 03:13 AM   #35558
jon_l
jon_l's Avatar
Oddometer: 3,217
Originally Posted by rhollamby View Post
Hey guys and gals,
To help with gearing going to a 13 49 set up and buying a 14 also. 14 for the long hauls and 13 for the mountains here in Colorado.
Buy an extra nut or 2, if you're going to do frequent swaps; the peening will take its toll.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-17-2013, 04:19 AM   #35559
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,734
Anyone know what the thread size is? Maybe the Eagle Mike KLR countershaft nut will fit?
cjbiker is online now   Reply With Quote
Old 05-17-2013, 05:18 AM   #35560
jon_l
jon_l's Avatar
Oddometer: 3,217
pn 90179-18010-00
$5.64 at Service Honda
CBF1000 & PCX150
Old 05-17-2013, 06:35 AM   #35561
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
...you mean on your 17's?
Old 05-17-2013, 06:44 AM   #35562
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,930
pn 90179-18010-00
Yeah, I just bought one for my third CS sprocket change. I really do not like this method of securing the sprocket nut. First it requires that you beat on the spline with a hammer/drift, etc., which can't be good for it. Secondly, the tried-and-true dog-ear, bend over spline washer used on most bikes is cheap and never fails.
Once I removed the CS cover to find this nut just finger tight. Yamaha must've recognized this as a weak design because I noticed the plastic CS cover has a keeper that prevents it spinning off. That's the only reason I haven't gone to one of the more open, aftermarket case savers.
BTW, at the local dealer these nuts are about $8 with sales tax.
I wonder if there's a normal nut with dog-earred washer that will fit the WR-R spline that can replace this system???
GSBS is offline   Reply With Quote
Old 05-17-2013, 06:47 AM   #35563
UtahFox
UtahFox's Avatar
Oddometer: 446
Red Loctite doesn't work on this nut?
Oh, I bought a breaker bar and had a friend help, and I was still unable to remove it. I have a friend here who works @ the dealer - they're going to take it off for me for $15. I was planning on the Loctite upon reinstalling.
UtahFox is offline   Reply With Quote
Old 05-17-2013, 06:55 AM   #35564
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
Cool2
...what gearing you planning on running Utah?
I'd stear away from a 12T counter, but that's just me.
I have one if anyone needs it amongst a couple other rears.
Old 05-17-2013, 06:56 AM   #35565
UtahFox
UtahFox's Avatar
Oddometer: 446
ATM it's 13x50 - 14 is what I want to get on there.
Times are GMT -7.   It's 08:15 AM.
