Old 05-26-2013, 02:59 PM   #35776
scottmac
scottmac's Avatar
Oddometer: 1,871
Originally Posted by BluePill View Post
Have you bypassed the tuner to verify that it's not some other problem - e.g. fuel pump or ignition coil/module?
It only started doing this directly following the programmer swap. The
bike is an 08 ad the fuel pump has been replaced. The motor does not
die when the problem occurs, it just cuts out and fires again as soon
as you roll off of the throttle. My guess is if the fuel pump or coil were
going south it would be missing across the entire throttle range and
not in just this one specific range.
I was running the FMF factory default settings when it first occurred. I
now have it set at 3,4,.5,8,4.5,4.
Thanks SCOTT_PDX for the tip on the fifth # being 6+. I'll give that
a try and make some test runs.
scottmac is offline   Reply With Quote
Old 05-26-2013, 03:16 PM   #35777
jon_l
jon_l's Avatar
Oddometer: 3,380
Originally Posted by WeazyBuddha View Post
What specific handlebars did you go with? Did you also do risers?
Actually, this is a good question for "everyone". If you replaced the OEM handlebars, what did you go with and why? Did you add risers?
TIA
I have factory bars, because they work and I'm cheap.
I have Tusk 1-1/4" risers because they're cheap ($20).
This set-up works much better than stock for standing, takes 5 minutes to install, and costs $20.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-26-2013, 04:02 PM   #35778
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,377
They work if you don't lie thinking your going straight??? Factory bars are know to bend if you look sideways at them. Normally bend on your way home from the dealership, the irate time they are tied down.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 05-26-2013, 04:37 PM   #35779
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,834
I'm running the cheapo Tusk risers with OEM bars, because I had the risers and the OEM bars are straight, for now
When I bend them, I'll go with the Tusk ATV fat bars and 7/8" to 1-1/8" adapters. Somewhere in this thread someone said that combo will work with the stock cables. If my math is right, it's just about the same as the stock bars and Tusk risers.
cjbiker is online now   Reply With Quote
Old 05-26-2013, 08:07 PM   #35780
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,752
Hey all...hope you're well, been off the net a bit. Hope all is good.
Anyone know what this is?
MoBill is offline   Reply With Quote
Old 05-26-2013, 08:34 PM   #35781
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 341
Yeah I had to bump up the fifth setting to +6 to and it fixed it Dobek makes these controllers I would call them if you have any more problems Dobek Performance.
EEKAMOUSE is offline   Reply With Quote
Old 05-27-2013, 04:03 AM   #35782
VTbeemer
Traveler
VTbeemer's Avatar
Oddometer: 356
Bar end
Handlebar end weight...
http://vtbeemer.blogspot.com/
14' R1200GSW- 93' R100GS/PD- F650GS- 94' R11RS
08' WR250R- 95 R100R- K75s- 57' R69
77' R75/7- 06' Ducati S4R Monster- 74' XL 250
VTbeemer is offline   Reply With Quote
Old 05-27-2013, 09:32 AM   #35783
UtahFox
UtahFox's Avatar
Oddometer: 446
Chain roller?
UtahFox is offline   Reply With Quote
Old 05-27-2013, 03:11 PM   #35784
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,948
If the bike runs without it, it's optional and un-needed.
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 05-27-2013, 03:58 PM   #35785
sieg
sieg's Avatar
Oddometer: 2,894
TIA
YZ 80 bars, taller and narrower, but still have room for the controls and mirrors and stuff. Unlike when you shorten big bike bars, YZ 80 bars are shorter in the middle.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 05-27-2013, 04:29 PM   #35786
AZ TOM
Oddometer: 4,079
Probably dumb question but how about putting the old programmer back on & seeing what you've got?
AZ TOM is offline   Reply With Quote
Old 05-27-2013, 05:29 PM   #35787
scottmac
scottmac's Avatar
Oddometer: 1,871
The old programmer is shorted out. I sent it back in for a reprogram/fix
but it couldn't be repaired which is why I ended up getting the new one.
I bumped the 5th# up to 7 and spent yesterday afternoon and today
out testing it and did not have a single hiccup so hopefully that takes
car of the problem.
Old 05-27-2013, 06:52 PM   #35788
MoBill
MoBill's Avatar
Oddometer: 13,752
VT, Utah...thanks--it has Cycras on it....
BP--I was thinkin' the same thing. Kinda optional?
I did think it was a roller, but it's too clean--and I think there are only two-- and they're both on there.
This is nuts. :-D Thanks fellas.
Old 05-27-2013, 06:54 PM   #35789
ba_
ba_'s Avatar
Oddometer: 2,794
There is a piece that looks something like that that fits between the muffler and the heat shield... I can't tell the size too well from your photo
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is online now   Reply With Quote
Old 05-27-2013, 07:17 PM   #35790
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,339
Longer Clutch cable
I'm 6'4" and I think I finally got my handle bars at the height I need to stand up comfortably, but my clutch cable is stretched very tight, even with running it in front of the bars. I noticed this weekend, the tight clutch cable is actually causing some resistance in the bars when turning that I can feel and is bugging me and I figure with it stressed like that, its more likely to fail at a bad time. I'd like to get a longer clutch cable made or purchased.
Anyone know of someone that makes clutch cables to your specs or maybe a cable from another bike that is longer and fits?
Anyone happen to know the length of the stock clutch cable?
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Times are GMT -7.   It's 04:48 PM.
