Old 06-20-2013, 01:18 PM   #36196
japako
japako's Avatar
Oddometer: 592
Originally Posted by tick-tock View Post
I'm not sure what you mean. How could they not be lined up?
The rear wheel can move at an angle to the center line. The sprocket is attached to the wheel. So the rear sprocket is not in line with the front sprocket.
Something like that...
japako is offline   Reply With Quote
Old 06-20-2013, 01:22 PM   #36197
tick-tock
Oddometer: 27
Got it, thanks. I'll make sure my back wheel is lined up.
tick-tock is offline   Reply With Quote
Old 06-20-2013, 01:49 PM   #36198
camaroz1985
Oddometer: 172
Originally Posted by Wingnut037 View Post
I have an HID bulb in the stock housing, ballast fits behind the shroud nicely. Only downside is no hi beam with my setup. Stock headlight adjustments keeps it pointed down and out of others faces, but lights things up well.
Do you have a night time picture of the beam pattern?
camaroz1985 is offline   Reply With Quote
Old 06-20-2013, 06:33 PM   #36199
RRM707
RRM707's Avatar
Oddometer: 650
Originally Posted by EEKAMOUSE View Post
Nice like the custom frame protector what did you use
They aren't custom. I got them off *bay.
I couldn't find them anywhere in the US.
They came from the United Kingdom. I installed inner tube strips behind them, to
avoid some wear.
RRM707 is offline   Reply With Quote
Old 06-20-2013, 06:45 PM   #36200
rsteiger
Bob
rsteiger's Avatar
Oddometer: 224
I went with the HID route on my DR650 and had issues with the things holding up on the trails. In the end I went back to the regular halogen bulb and added some ADVMonster LED spots which were wired on the hi beam circuit.
For my WRR I went with the same basic solution but modified it a bit. I went with Mondomotos LED Spots and wired in a separate on/off switch from HDB.
Switch mount:
Left side:
Right side:
Off:
On:
I was a little bit disappointed with the beam pattern on the Mondomoto's LED spots since they were not as tightly focused and the ADVMonster LED Spots. Initially I was going to replace them with an extra set of ADVMonster units but they actually seem to work better when you are on a heavily wooded trail at night so I am leaving it as is.
Generally I have found this to better solution than the HID route since it gives me the ability to aim three separate beams which gives me a lot of latitude over the final beam pattern.
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
rsteiger is offline   Reply With Quote
Old 06-20-2013, 07:06 PM   #36201
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 341
Originally Posted by RockinTheRVA View Post
Hey quick question for those of you with FMF programmers and FMF exhaust.
I was riding down the road at 70mph indicated in 6th gear when I had a momentary power loss while on the throttle. It has only happened once in 400 miles of owning it, and power came back within a second. Any idea what may cause that? Should I worry?
1200 miles on the bike, FMF programmer w/Powercore 4 exhaust.
Mine did that set the 5th # at 6 and it will stop that is per the person that made the controller dobek performance
EEKAMOUSE is offline   Reply With Quote
Old 06-21-2013, 10:47 AM   #36202
Wingnut037
Two Sheds
Wingnut037's Avatar
Oddometer: 285
Video work? This was at dusk. Zero issues the last 25k miles
Wingnut037 is offline   Reply With Quote
Old 06-21-2013, 02:15 PM   #36203
Torontorocko
Ordinary Average Guy
Torontorocko's Avatar
Oddometer: 37
You don't pull the clutch during gear changes?
2012 WR250R
Torontorocko is offline   Reply With Quote
Old 06-21-2013, 02:25 PM   #36204
sieg
sieg's Avatar
Oddometer: 2,889
Does anybody?
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 06-21-2013, 03:35 PM   #36205
Wingnut037
Two Sheds
Wingnut037's Avatar
Oddometer: 285
I do from first to second and back into first. I used to shift every gear before an instructor at an Advanced Riders Course from MSF told me there was no need. Just kick it up or down unless you are under full throttle, and for then just back off for a fraction of a second.
Old 06-21-2013, 06:32 PM   #36206
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,998
Originally Posted by sieg View Post
Does anybody?
Ummm.... yes.
I do it both ways but use the clutch more often than not.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 06-22-2013, 05:44 AM   #36207
coresports
coresports
coresports's Avatar
Oddometer: 317
clutchless
i thought i was seeing things, haha. im going to try it on my wrr,
i had an old chevy vega i could do that with after first gear.
i was not interested in the headlight issue but still worth watching...
nice video, all curves. such a beautiful state! im a little jealous!
(You don't pull the clutch during gear changes? )
[/QUOTE]
coresports is offline   Reply With Quote
Old 06-22-2013, 10:41 AM   #36208
burtonrider3889
Oddometer: 875
Another race video for those cross shopping dual sports.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Old 06-22-2013, 03:24 PM   #36209
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,224
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 06-22-2013, 09:50 PM   #36210
VOLdog
Oddometer: 323
sale pending
Originally Posted by VOLdog View Post
Guy looking to buy my bike asked and I have no idea
He lives near Dulles and its required.
maybe someone lives in that area can advise...
I guess emissions are not an issue
VOLdog is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
