Old 07-16-2013, 04:08 AM   #36586
goroka
Oddometer: 95
Originally Posted by Sean-0 View Post
thank you ... I have the manual here I have not read it ... its my sons bike .....good to know tho ... I shall read the service part myself tomorrow at work
Not sure if this helps - did Cooktown - Tip - Daintree with no change as I felt that fell in the 5000km type of conditions. At home most of the stuff is in Kenilworth/Beerburrum so I work on 1500km on the theory that oil is cheaper than an early rebuild.
Cheers
goroka is offline   Reply With Quote
Old 07-16-2013, 09:38 AM   #36587
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,578
Can't seem to find what I'm looking for...
My new to me WRR has a FMF Q4 and Powerbomb header. I'm gonna put stock exhaust back on.
a) leave powerbomb on? Any gain over stock header WITH stock exhaust?
b) take powerbomb off and put stock header back on?
If there is no power difference, I'll likely remove both. More to sell for farkles I really want. If there is a power difference, I'll likely keep the powerbomb on. Goal here is a quieter bike, not a couple hp.
Thanks.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 07-16-2013, 09:54 AM   #36588
japako
japako's Avatar
Oddometer: 592
Thanks.
I can't help first hand, but mine is stock and it is fast enough for me. It is also quite.
I read on the 250 forum and some people did not notice a difference while others said they did.
It is kind of up to you. If you want less mgp, and a load noise, and maybe a couple of hp, go for it.
The only way you will feel a difference in my opinion, is to go with a total mod, including a larger jug and piston. jmho
japako is offline   Reply With Quote
Old 07-16-2013, 10:18 AM   #36589
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
Cool2 do it or dont
My new to me WRR has a FMF Q4 and Powerbomb header. I'm gonna put stock exhaust back on. .
I had a PB and stock pipe that I opened up a bit by drilling out the flat baffle you can see if you remove the tip and look inside.
I'd say a bit more poop than the stock header but nothing to write home about.
I also had a stock pipe with the cat section removed. It wasn't much diff at all.
That said, your best bet is to do the whole FMF mod or not at all.
Q4, PB, and controller. On my friend's stock bike with the airbox door removed, and the FMF package installed, bike ran almost as well as my Athena kitted bike, but without the vibration...
Bone stock and constricted the bike is pretty tame.
Opening up the airbox is a good thing, but most of the noise on a WR comes directly from the airbox, right up into your helmet. The pipe noise is incidental in comparison.
Cheap alternative mod is the airbox flapper, drilled airbox door, and open up the stock pipe.
believe me, I tried it all...
Now if you're looking for some farkles, I have a nice set of Pivot Pegz in the FM......
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 07-16-2013, 10:37 AM   #36590
coresports
coresports
coresports's Avatar
Oddometer: 330
i would put the entire exhaust back to stock along with the EXUP valve if you have it as that improves low/mid range response, it will be quiet but still peppy and you wont have to repack the muffler. i have ran stock vs modded wrr's side by side and there is just not that much difference, imo. modded bikes have less mpg/more noise and unlike my neighbor with a harley, i want my neighbors to like me!
Thanks.
coresports is offline   Reply With Quote
Old 07-16-2013, 11:33 AM   #36591
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,578
Originally Posted by coresports View Post
i would put the entire exhaust back to stock along with the EXUP valve...
Hmm. Alright. Mine is removed. Anybody want to dispute this? What about the AIS? Its been blocked off..
Old 07-16-2013, 12:55 PM   #36592
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
The whole stock vs aftermarket exhaust/ programmer has been debated multiples times in this thread as well as other sites. Each has its advantages.
Stock: quieter, heavier, less restrictive bottom end, more restrictive top end
Aftermarket: Louder( model depending), lighter, more(hair) restrictive bottom end((less power)), less restrictive top end
EXUP valve: In my opinion, based on what I have read and seen of vids in its action on the WR250R/X, its function is more for show and EPA noise standards than anything else. Extra weight.
AIS: Again, in my opinion, its post combustion, so only there for emissions reasoning and does nothing for running of bike. Extra weight.
Programmer: Stock maps are never optimal due to regulations they have to meet, for a street bike. Yes, Japanese engineers are very smart people, and make the best map they can to meet the needs and guidelines they have to have the bike fall into. BUT, especially when changing around the restrictive exhaust, changes are need to map.
So, for me, I wanted the lighter weight, and less restrictive top end( bike does not make a lot of power low anyway...so who cares about lower end). I used gearing changes to get a little more grunt on low end. I am also not worried about noise....I like to hear my bikes personally. I got rid of the EXUP and AIS....just weight to make the bike heavier than it needed to be.
And to boot, I got a used FMF Q4 can and a new programmer( private seller) for about $250 combined.
So, that was the right decision for me..others may vary. Get what works best for you.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 07-16-2013, 01:00 PM   #36593
viper770
viper770's Avatar
Oddometer: 592
well said my freind well said
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 07-16-2013, 01:35 PM   #36594
ryguy83
ryguy83's Avatar
Oddometer: 98
I read somewhere the powerbomb is for more top end, and the megabomb is for more bottom, being that the wr is already weak at the bottom,I'd go with a megabomb.
-ry
ryguy83 is offline   Reply With Quote
Old 07-16-2013, 01:47 PM   #36595
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
-ry
I still have my stock header, so I really don't know. Personally, buying new, seems like a lot of money for maybe 0.7 HP it may add.
Old 07-16-2013, 01:49 PM   #36596
ryguy83
ryguy83's Avatar
Oddometer: 98
True true, I just don't like stock exhausts,I just need that aftermarket look, to each his own I guess right.
Where ya from in jerz, I'm right around the block from Pnc Arts Center. Ya know where that is?
-ry
Old 07-16-2013, 02:24 PM   #36597
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,759
Thanks.
Did the guy open up the airbox, remove flapper and all that? If so, there might be something to be said for having a more free flowing exhaust to balance that out. Of course that's assuming there is also a programmer installed to set this all up correctly. Going back to stock might be difficult if he ripped all that out.
FWIW - I did all the above + FMF + PowerBomb, and it's a noticibly more responsive, not a huge gain, but a bigger "smile factor". That being said, If I were to do it again, I'd have left it stock (Too much $, and a little too loud - but it's growing on me), but don't regret it by any means - and certainly not enough to go back to stock.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 07-16-2013, 03:58 PM   #36598
kawagumby
Oddometer: 1,032
It sounds like the aftermarket mods just aren't worth it for some of us, especially if the low-end is compromised in any way. So far, I've put all my extra money into suspension work, as I'm beginning to ride it more on black-diamond narrow technical trails with jumps, square edged holes, etc...
Once you get the suspension dialed in (revalved and resprung) it handles the rough pretty well for a 300 lb bike. You definitely need that low end semi-grunt for lofting the front on the trails I ride - the conditions really don't lend themselves to high rpm's much. IMO, this bike just has enough low end to get the job done with a little weight shifting.
kawagumby is offline   Reply With Quote
Old 07-16-2013, 04:57 PM   #36599
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
How high can you go? WRR ride height adjustment?
How high can you go on the WRR ride height adjustment? I got to looking at the ride height adjustment on my WRR awhile back and realized it was pretty far in compared to my buddies WRR and I'm taller than he is. I'm 6'4"/250, so the extra ride height is welcomed.
I have the shock off the bike sitting on my work bench and mine was set where the end of the shaft of the shock was dead even with the inside threads of the u-shaped shock mount on the inside. Obviously you need enough threads in that U shaped bolt that it won't come out or be stressed, but I would think you have some play there? Measuring the U-shaped shaft, there is about an 1" of threads in there. Measuring the threaded part of the shaft below the shock adjustment shows just under 1.5" total. So prior to this, I had about an 1" of shaft inside the U-shock mount. Could I go where I have about 1/2" of shaft inside the u-shock mount and about 1" exposed? That's probably about as high as I would feel comfortable with it and should leave plenty of the shaft inside the U-shock mount.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 07-16-2013 at 05:04 PM
BlueLghtning is offline   Reply With Quote
Old 07-16-2013, 05:48 PM   #36600
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,578
Me too
All I can find is posts about lowering the WR, and none of them spell out the procedure. This will be old hat very soon, but as a noob, and considering there is no mention of this "ride height adjustment" in the manual.. The PO of my bike said it was really easy, but I can't figure it out. I'd like the bike as tall as it'll go, then maybe ease it back. Where can I find how to do this? Google didn't get me anywhere.
levain screwed with this post 07-16-2013 at 05:57 PM
Times are GMT -7.   It's 02:22 PM.
