Old 08-24-2013, 09:57 AM   #37441
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 759
Originally Posted by coresports View Post
The valve goes from being almost fully closed at idle speed, through to fully open at higher engine speeds.
This ensures superior low to mid-range performance & more linear power output.
Supposedly! Video evidence suggests otherwise.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 08-24-2013, 10:03 AM   #37442
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 455
Originally Posted by beee View Post
I have a wr250x. I just bought warp9 18/21 dirt wheels for it with the large x rotor for an easy swap.
The warp9 front wheel will not accept a stock wrx rotor, how can I get another rotor? Do I have to buy from warp9?
Sorry if this has been asked before, I searched and couldn't find anything.
Call Warp9. They were very helpful when I had questions about mine. Of course I forgot the answers , but I did ask them about the rotor and wheel bearings.
'06 Wee-Strom
'08 WR250X with X and R setups
'08 KTM 300xc-w - Plated
Colorado 2012
UPAT 2011 2014
jgino157 is offline   Reply With Quote
Old 08-24-2013, 11:58 AM   #37443
johnkol
Oddometer: 136
Originally Posted by DougZ73 View Post
Speaking as someone who came from a DRZ 400 to the WR250R...its not where near as grunty...BUT...but where as you keep the revs low and use the torque of the DRZ, you rev high and use the top end of the rev range on the WRR. Once you get used to it...you never look back.
That was not my experience with the 400E when I sampled it some years ago: it not only had tons of power at the top, but a lot of duration too. At that time I was riding a Husaberg 400, and the DRZ definitely had the more rev-happy motor.
You could certainly use the torque of the DRZ instead of its power in almost all situations, and most of the time that was the only way to ride it since the inadequate suspension (and the weight) put a damper on any high speed adventures -- the same ailments that afflict the WRR (but without the power).
johnkol is offline   Reply With Quote
Old 08-24-2013, 12:33 PM   #37444
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,943
Originally Posted by BluePill View Post
To each their own, of course. Center-to-center, the wrench is 4.5 inches. That means you need to put a weight of 240 pounds on it to get the required 90 Ft-Lb torque. If you weigh 175, you can only apply 66 Ft-Lb. IMO, it's not a nut you want to lose in the woods.
I've changed flats several times on the trail with no issues whatsoever using the supplied tool kit. Just give that sucker a kick and it comes right off (and I do torque the nut to the specified 90 foot pounds whenever I take if off at home).
I did change out the pinch bolts on the forks, which have 10mm heads, with some hex-head bolts after the tool kit's 10mm wrench bowed when I tried to loosen them. Luckily on that occasion a buddy had some vice grips to loosen the pinch bolts.
GSBS is offline   Reply With Quote
Old 08-24-2013, 12:55 PM   #37445
kawagumby
Oddometer: 909
The DRZ E and S are different animals though. I had an S and with the CV carb and lower compression etc. it wasn't much of a power house.
kawagumby is offline   Reply With Quote
Old 08-24-2013, 01:19 PM   #37446
Andysrage
Oddometer: 65
I agree. I have ridden a DRZ400S and it wasn't nearly the torque monster some make it out to be. Considering the displacement delta, I think the WR's torque to be adequate and a reasonble trade off since top end power on both is nearly the same. Basically, we're getting a lot more bang from each of our 250cc than the DRZ's 400.
'00 Aprilia Pegaso 650
Andysrage is offline   Reply With Quote
Old 08-24-2013, 01:40 PM   #37447
Andysrage
Oddometer: 65
the stock exhaust without the exup would not run very well, imo. this valve has nothing to do with emissions (unlike the ais)
I don't think the engine will actually run poorly without the exup but, to your point, with a bike so short on torque relative to its capabilities, why sacrifise the little torque on hand to gain a fraction of a HP that the engine already makes in spades? This is why I built myself a custom FMF Q4 slipon while maintaining the EXUP. http://wr250rforum.forumotion.com/t4...f-q4-with-exup It doesn't feel like I have lost any torque. Actually, after climbing the rocky hills of Hancock Quarry Run a few weeks back, I think the bottom end is better than ever.
I think the bigger issue is running a stock cat-equipped muffler without recionnecting the AIS will result in a clogged cat in the long term. the AIS is there to provide the cat with the extra oxygen it needs to properly burn off the residual carbon emissions. Without this extra air, these emissions will slowly build up and long-term foul the cat, sapping performance.
Old 08-24-2013, 01:43 PM   #37448
ba_
ba_'s Avatar
Oddometer: 2,754
LH mirror base
Where can I get the LH mirror base 10mm x 1.25? I don't want to buy the whole assembly since I am putting on Doubletake Mirrors. My RH reverse thread adapter base is fine.
I feel like this are pretty universal yet I can't seem to find one easily
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 08-24-2013, 02:22 PM   #37449
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,720
A standard RAM ball will thread right into the clutch perch, no adapter needed.
cjbiker is online now   Reply With Quote
Old 08-24-2013, 02:26 PM   #37450
ba_
ba_'s Avatar
Oddometer: 2,754
I wanted to height to match hence the base on the LH size...
Old 08-24-2013, 03:14 PM   #37451
japako
japako's Avatar
Oddometer: 592
You can buy the adapter from your dealer, or search Google.
I just use the left mirror, you really don't need two, unless you ride on the road more than dirt.??
japako is offline   Reply With Quote
Old 08-24-2013, 03:26 PM   #37452
ba_
ba_'s Avatar
Oddometer: 2,754
The LH adapter (with the normal threads) is the one that is busted. My RH adapter (with the reverse threads) is fine. I would use just the left it it worked. :)
I found a pair on eBay. For now I'll just use my right mirror
Old 08-24-2013, 03:32 PM   #37453
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,035
I had a plated kicker DRZ. Best of the DRZs......but once I got used to the lack of torque on th WR250R...I am able to ride the Yami much faster.
Sent from my SCH-S738C using Tapatalk 2
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 08-24-2013, 03:47 PM   #37454
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,859
Originally Posted by ba_;
22173119]The LH adapter (with the normal threads) is the one that is busted.
Hmmmm.............
Pray tell just how did that happen????
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 08-24-2013, 03:56 PM   #37455
ba_
ba_'s Avatar
Oddometer: 2,754
Hmmmm.............
I ruined the threads since I didn't realize that the RAM balls I had on my BMW were 1.5 pitch instead of 1.25
Times are GMT -7.   It's 05:33 AM.
