Old 09-16-2013, 05:45 PM   #38011
Mr.Black999
Mr.Black999's Avatar
Oddometer: 246
Sorry I meant if I'm going at speed and if it's vibrating I pull the clutch in and close the throttle the vibes stop but the bike is still rolling along so I don't think it's the tires. If i rev the engine in neutral or with the clutch in it vibrates, that's what I meant.
I also could have swore before that someone had a problem with the bolts holding their balancer weight on, that they had loosened up. I dont know what's up but it's driving me crazy and makes me want to tear everything down and rebuild it!!
Mr.Black999 is offline   Reply With Quote
Old 09-16-2013, 06:08 PM   #38012
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,112
hmmm, not really sure. It is a one cylinder engine, but really, I am pretty sure mine is smooth as butter. Certainly vibrates less than my two cylinder SV1000.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 09-16-2013, 06:12 PM   #38013
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 333
Originally Posted by coresports View Post
i went with front & rear caliper & rotor guards. i wanted a little more blue bling along with some added protection. i think they would reduce but not stop all damage in a fall, the rotors just seem a bit exposed stock.
Where did you get the front rotor and caliper gaurds
EEKAMOUSE is offline   Reply With Quote
Old 09-16-2013, 07:52 PM   #38014
Wallrat
Wallrat's Avatar
Oddometer: 730
Originally Posted by jkstehn View Post
Can't jump up and down enough to +1 on the double take mirrors.
When the Ram arms are set just barely tight enough to hold on trails they take a beating from brush, trees and dirt naps and move enough to prevent damage while still holding position fir normal riding. When I am on trails, especially desert two track, I often set one mirror to see behind when sitting and one to see behind when standing on the pegs. That way I can watch for fast movers on true dirt bikes.
Sent from my SCH-I605 using Tapatalk 2
Ha seriously. Can't tell in the photo but the backsides of my mirrors are scratched to hell from catching bushes, trees, even a cactus. I leave my mirrors up full time while offroad and haven't snapped one yet. Even if you do manage to break one, the modular design means you probably only have to replace 1 part @ $5-$20 instead of the whole assembly. Plus they're decently long and rock solid so seeing past your elbows and actually being able to tell what's behind you is a piece of cake.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 09-16-2013, 08:56 PM   #38015
TwilightZone
Oddometer: 3,100
>"Sorry I meant if I'm going at speed and if it's vibrating I pull the clutch in and close the throttle the vibes stop but the bike is still rolling along "
If you let off the throttle, do the 'vibes' stop ?
Might be chain vibration. Mine does that quite bit.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 09-16-2013, 09:03 PM   #38016
Luke308
Luke308's Avatar
Oddometer: 425
Vibes aren't normal. Might want to look into that.
Sent from my Nexus 7 using Tapatalk 4
Luke308 is offline   Reply With Quote
Old 09-16-2013, 11:18 PM   #38017
Dahlin
Need more time...
Oddometer: 169
Originally Posted by Superstar View Post
This is 6'4" 220lb for the Americans...
I'm the same height but a bit lighter @ 91kg and have no issues with the stock suspension.
Sounds like I should loose weight instead of working on the bike...
2003 Honda CB1300
2009 Yamaha XT660Z
2011 Husqvarna TE630
2012 Husaberg FE390
Dahlin is offline   Reply With Quote
Old 09-17-2013, 03:26 AM   #38018
goroka
Oddometer: 93
Front brake rotor
After some technical help: managed to knock the front rotor out of shape by about 4mm ( I think I moved my rib by a fair bit more in the maneuver )
I understand that the original rotor is allowed to flex - I am thinking of fitting a rigid rotar as a replacement. Will that make any difference to braking and the life of the pads? Anything else to consider?
Cheers
goroka is offline   Reply With Quote
Old 09-17-2013, 05:06 AM   #38019
Mr.Black999
Oddometer: 246
Well this is the second chain since it started and I have the chain adjusted per Yamaha's revised chain adjustment specs.
Any more ideas on what to check, could a clutch out of adjustment or something wrong with the basket cause vibrations?
Old 09-17-2013, 05:37 AM   #38020
Superstar
Superstar's Avatar
Oddometer: 493
14 stone takes a bit of effort to maintain, but the results are worth it as its all sprung weight. ;)
Superstar is online now   Reply With Quote
Old 09-17-2013, 07:04 AM   #38021
rvsixer
Oddometer: 72
Originally Posted by Luke308 View Post
FWIW my '08 primes every time.
Thanks for the reply. Turns out:
kill switch OFF -> ignition ON = no prime
kill switch ON -> ignition ON = prime
rvsixer is offline   Reply With Quote
Old 09-17-2013, 07:33 AM   #38022
coresports
coresports
coresports's Avatar
Oddometer: 304
http://www.yamahamotorsports.com/spo.../511/2103/1774
here but i don;t see it listed anymore, got mine almost 5yrs ago. they do have a sweet carbon fiber one for the rear tho.
coresports is offline   Reply With Quote
Old 09-17-2013, 07:36 AM   #38023
redkerk84
that guy
redkerk84's Avatar
Oddometer: 532
Do a google search for gytr billet brake guard.
You can order them from Yamaha also.
Sent from my magical wonder brick
things and information
Talk Like a Pirate Grand Tour
http://www.glmc.org/grand_tour.php
redkerk84 is offline   Reply With Quote
Old 09-17-2013, 08:17 AM   #38024
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,112
GYTR is Yamaha.
Genuine Yamaha Technology Racing(GYTR)
Old 09-17-2013, 08:50 AM   #38025
redkerk84
that guy
redkerk84's Avatar
Oddometer: 532
Originally Posted by DougZ73 View Post
GYTR is Yamaha.
Yeppers
Link
http://www.motosport.com/dirtbike/GY...PER-GUARD-BLUE
As I posted earlier, you can also find them on the Yamaha website.
On the yamaha website for the 2013 WR250R, click on the accessories link, then the billet and chrome link.
redkerk84 screwed with this post 09-17-2013 at 09:04 AM
Times are GMT -7.   It's 12:47 PM.
