Old 10-15-2013, 05:43 PM   #38611
VOLdog
Oddometer: 323
Wicked
Originally Posted by SkidMarx View Post
Exactly.
Any idiot can make a big bike go fast.
It takes a special kind of idiot to make a small bike go fast.
EXACTLY!
I got a KTM 950 SE.......
And i LOVE my WR!
VOLdog is offline   Reply With Quote
Old 10-15-2013, 07:27 PM   #38612
woofer2609
woofer2609's Avatar
Oddometer: 784
Originally Posted by ba_ View Post
I thought you needed 112 links for a 47?
I'm running 13/47 with a 112 link and I am at the far, far end of the adjustment with the blocks just about out of the sliders.
woofer2609 is offline   Reply With Quote
Old 10-15-2013, 07:29 PM   #38613
woofer2609
woofer2609's Avatar
Oddometer: 784
Exactly.
Old 10-15-2013, 07:51 PM   #38614
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Originally Posted by simmons1 View Post
It is 25 HP 250 trail bike, why are you guys fixated on how fast it will go on the highway? Maybe you bought the wrong bike.
Equal and opposite logic suggests the guy that straps on a big ass tank and strap and a week's worth of camping gear to a WR bought the wrong bike. Or the guy that dumps a ton of money into engine and suspension on a WR.
That's why they make BMWs and KTMs, right?
bxr140 is offline   Reply With Quote
Old 10-16-2013, 03:36 AM   #38615
ba_
ba_'s Avatar
Oddometer: 2,785
Hmm ok. I am running 13/46 now with 110 links and want to swap out a 47 when I mount a D606. Guess I will try to keep the 110 for now
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 10-16-2013, 04:10 AM   #38616
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
So is it just me or does this bike seem to carry its weight up high?
Compared to anything with higher displacement in its class, I would say it carries its weight very well. A notable exception would be a bike like the KTM EXC 350-F, its absense of pork up high (rear sub-frame, steel tank, steel handlebars, glass headlamp housing) dozens of items that seem trivial until you stare at the weight difference, and quickly realize its not just you... bikes like that DO make the WRR feel quite top heavy by comparison. Now throw your leg over a 990 Adventure and the WRR seems light as a feather.
I find it a bit of burden in very tight trees and such.It's almost like the bike could use a few more degrees of steering on either side before hitting the stops. I'm just curious about others experience with the bike.
It does have a slightly fat turn radius, attributed in most part to the domain of water cooling components and the neighboring amenities nestled in the opposite side. Mine is equipped with an IMS 4.7G tank that concedes their location, and accordingly WON'T tolerate any fiddling with the stop screws before the upper triple hits the tank.
So is this bike more of an MX lineage, or a trails bike lineage?
Yamaha attributes its lineage to the YZ in their promotions of the WRR, which seems odd given the "WR" branding... which is still biased towards MX.
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 10-16-2013, 06:00 AM   #38617
Krabill
Krabill's Avatar
Oddometer: 4,891
With all the miles I've put on my bike, I've been through quite a few sets of chains/sprockets. Always replace them with 13/47 and 110 link. Works great.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 10-16-2013, 09:34 AM   #38618
Wapner
Oddometer: 24
Thumb Gearing
Originally Posted by Krabill View Post
As others have said . . . you need to re-gear it. Put a 47 on the back with a 110 link chain and see if that makes you happy. I bet it will.
I live at 4700 ft altitude and put a 49 tooth sprocket on the back and put a 14 tooth on the front. This setup allows me to cruise along at 70 no problems in 6th gear even when fully loaded with my wolfman saddlebags and my 225lbs on it during a multiday camping ride.
When things are going to really be tight or I need more grunt, I swap the 14 tooth with a 13 tooth on the front. Seems to be a versatile setup for me but I do like the 14 tooth better since it handles 90% of the places I ride and is more relaxed on the highway.
Wapner is offline   Reply With Quote
Old 10-16-2013, 10:12 AM   #38619
2008wr250x
Oddometer: 1
wr250x bar risers??
hi all:
anyone had success mounting the Rox 2" risers on the wr250x?
Would like to ad at least 1.5" to the stock bars without any cable issues....
open to other brands.
thanks!
2008wr250x is offline   Reply With Quote
Old 10-16-2013, 10:16 AM   #38620
advmgm
Oddometer: 1,064
+1 there is only so much to give on a 250.
I just ride at 50-55 on the road and live with it.
Sent from The Edge using TapaTalk 2
WR250R Adventurer
advmgm is offline   Reply With Quote
Old 10-16-2013, 10:23 AM   #38621
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,977
Originally Posted by 2008wr250x View Post
hi all:
thanks!
I'm using the 2" Rox risers on my WR-R. To have full-lock clearance on the throttle cables I had to turn the housing upside down (cables running under instead of over the bars). Other than that they're just fine.
GSBS is offline   Reply With Quote
Old 10-16-2013, 10:26 AM   #38622
malignity
The Hurt Locker
Oddometer: 409
Hey guys, I just picked up a 2010 WR250R with 1100 miles on it for $3500.
Got it for a steal. I love the thing so far. I too have a bit of a top speed issue. Nothing major, but pretty much stock (with stock gearing), 72 seems to be where she tops out with me on it. I'm 225lbs.
Seems 6th has no pull. I understand its overdrive mostly though.
I'm considering going larger sprockets, but I'm concerned doing so will make the top speed worse. Then again, I understand with poor gearing, the engine often times works against itself.
Will gearing smaller front or bigger rear kill my top speed more, or simply make it pull cleaner because of poor gearing?
Also, I'm debating whether I should go with a 46-47t rear or a 12 front. Switching a front is a lot easier, and I could potentially use the same chain, but it seems going with a bigger rear is more common. Why is this? Premature slider wear?
I'm pretty happy overall with it, but if I can squeeze more out of it, I will. Already cut the air box, and de-catting the exhaust today.
'10 Yamaha WR250R , '93 Yamaha TW200, '03 Honda Foreman 450ES 4x4, '96 Yamaha Big Bear 350 4x4. www.gldsmc.org
malignity is offline   Reply With Quote
Old 10-16-2013, 10:26 AM   #38623
jefmad
Oddometer: 647
hi all:
thanks!
Another option is using a much higher bend bar. I bought the Thor aluminum ATV bend bars and had to cut about 1/2" off each end to get the cables to work, but it's an easy option for $25.
jefmad is offline   Reply With Quote
Old 10-16-2013, 10:49 AM   #38624
Krabill
Krabill's Avatar
Oddometer: 4,891
Unknown for sure, but there is enough evidence that says the 12T is bad for the chain slider, so I'd stay away from it.
13/47 w/ 110 link chain. It'll help your top end and allow 6th gear to be useable.
Loud Sucks!
Old 10-16-2013, 10:54 AM   #38625
Z0RR0
Z0RR0's Avatar
Oddometer: 554
I'm sure this has been mentioned/discussed ... but I've searched with no results and not really keen on browsing through 2700 pages.
Has anyone considered a 450 swap, out of a WRR? Does it even fit?
Local regulation make the WR250R/X street legal, but not the 450. Hence the question. The swap isn't legal, but easier to get away with ...
My dumbass self and my red Ducati - www.julienconstans.com
Z0RR0 is offline   Reply With Quote
Times are GMT -7.   It's 01:38 AM.
