Old 10-21-2013, 08:22 AM   #38701
ET-VT
ET-VT's Avatar
Oddometer: 244
Had to rescue a GS rider out of the woods yesterday...
We were about 70 miles from his truck and trailer. Fortunately my house was about halfway there, so we got to stop and switch to four wheels. Not a whole lot of room on that seat!
ET-VT is offline   Reply With Quote
Old 10-21-2013, 08:31 AM   #38702
malignity
The Hurt Locker
Oddometer: 361
Originally Posted by woofer2609 View Post
Not normal. Follow the wiring and check the switch. Shouldn't be too hard to isolate...
Thank you. I imagine something is exposed and hitting the frame and shorting after I removed the AIS. I didn't want to try and track down a phantom though if it was common.
Trying to start the bike with the horn going is surprisingly very difficult. Draws a lot of juice.
'10 Yamaha WR250R
gldsmc.org
malignity is offline   Reply With Quote
Old 10-21-2013, 08:51 AM   #38703
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,125
you guys match
That looks like a lot of fun Two guys on a little bike is always fun.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 10-21-2013, 09:33 AM   #38704
Superstar
Superstar's Avatar
Oddometer: 491
Final drive implosion?
Superstar is offline   Reply With Quote
Old 10-21-2013, 10:20 AM   #38705
burtonrider3889
Oddometer: 844
So the 13/47 gearing seems to be the most popular? People say that helps with top end, but does it also help with low end?
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Old 10-21-2013, 10:25 AM   #38706
jon_l
jon_l's Avatar
Oddometer: 3,133
yes
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 10-21-2013, 10:28 AM   #38707
jon_l
jon_l's Avatar
Oddometer: 3,133
How close to the headlight are you attaching the bag? I found the headlight is pretty low...
You are correct. I considered using Tusk fender bag like I did on the DR650, and it blocked a significant portion of the WRR headlight, so I don't use a fender bag on the WRR. I run a Wolfman enduro tool bag on the cowl above the headlight. It works fine, and hold more too.
CBF1000 & PCX150
Old 10-21-2013, 10:43 AM   #38708
burtonrider3889
Oddometer: 844
Originally Posted by jon_l View Post
yes
So it pretty much makes the bike better in every way? Does it actually increase top speed since 6th just doesn't have the Mphh to push it along with stock gearing? And what is the stock gearing?
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
Old 10-21-2013, 10:53 AM   #38709
ET-VT
ET-VT's Avatar
Oddometer: 244
No. A very unfortunately-positioned boulder to the tank shroud managed to break a fuel-line quick-disconnect. Really unlucky, but thankfully it's a fairly cheap and easy fix.
Old 10-21-2013, 10:55 AM   #38710
malignity
The Hurt Locker
Oddometer: 361
Stock is 13/42 or 43.
I ran my buddy's with 13/46 and it made quite a bit of difference. He was faster than me flat out too. I simply can't maintain speed in 6th and always have to drop to 5th to maintain R's.
My concern is once I change the gearing, the speedo will be off. You can get a speedo healer, but I've yet to find one under $100.
'10 Yamaha WR250R
gldsmc.org
Old 10-21-2013, 10:58 AM   #38711
burtonrider3889
Oddometer: 844
Oh ok, so the front is already good. That's good to know. Just need to buy a 47 then I guess.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
Old 10-21-2013, 11:01 AM   #38712
malignity
The Hurt Locker
Oddometer: 361
Also a larger chain. As far as I know, stock is 108, you'll need 110. Somebody correct me if I'm wrong.
'10 Yamaha WR250R
gldsmc.org
Old 10-21-2013, 11:06 AM   #38713
viper770
viper770's Avatar
Oddometer: 578
if you have a stock wr250r its 13/43 if you have a stock wr250x then its 13/42
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 10-21-2013, 11:09 AM   #38714
viper770
viper770's Avatar
Oddometer: 578
sorry to disappoint you guys but im using 13/42 gearing and im hitting 97 mph gps with no problems and im on a wr250r using stock tires as well
2012 YAMAHA WR250R
Old 10-21-2013, 11:12 AM   #38715
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 326
Speedo drd from 12 o'clock labs is under 100 and does same thing
EEKAMOUSE is offline   Reply With Quote
Times are GMT -7.   It's 02:40 PM.
