Old 10-22-2013, 10:59 AM   #38746
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
Your chain is too loose
Originally Posted by skierd View Post
One day this winter, when my bike's apart for maintenance, I'll take a picture of the grooves in my Sandman case saver that came from running a 14T front sprocket and I'll let y'all decide if it's worth running. I'll never run a 14T again.
I run a 14t sprocket and a Sandman Case Saver with zero issues. I run 14/49 sprockets and adjust the chain by deflection measurement.
This is hard to explain in text. Both of my sprockets are larger there by increasing the chain distance from the swingarm (top and bottom). If a proper stock gearing adjusted chain is say 10mm from the swing arm with x amount of slack taken out of the chain (pushed up towards the swing arm) When you increase the size of the sprockets you increase that distance, 10mm goes to say 15mm. If you keep it at 10mm with the larger sprockets your chain will be looser.
That is probably as clear as mud..... regardless I have not had any wear on my sandman case saver, and only typical wear on my slider (compared to your avg dualsport, not just WRr)
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 10-22-2013, 03:42 PM   #38747
jon_l
jon_l's Avatar
Oddometer: 3,484
Originally Posted by rubberband View Post
if 14/48 seems wound out...why change to 14/50? wouldn't that be eve more wound out? or you planning less highway, more gnarly ST?
He said 13/48 and 14/50. The latter should be very slightly higher gearing.
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 10-22-2013, 03:54 PM   #38748
jon_l
jon_l's Avatar
Oddometer: 3,484
Once again, the discussion has focused on the diameter of the front sprocket as the cause of slider wear. My 12T front and lack of slider wear suggests otherwise to me.
As I have posted before, I think this is a more complex issue, caused by a combination of factors, a "perfect storm" if you will. A worn, kinked chain, perhaps combined with a heavily loaded bike, perhaps combined with improperly set sag, and maybe a too-tight chain, AND in some combination of these all at the same time.
I already have my next sprockets, and I will go to a 13/47 (currently 12/43), because the logic of moving the chain further from the swingarm is undeniable. The reason I will do so is because it seems sensible & logical, but I have not had any issues (yet anyway) running a 12T front.
Thinking a 14T front is the silver bullet to eliminate slider wear may lead some to think "problem solved", and perhaps to damage a swingarm due to decreased diligence in inspecting the chain, sprockets and slider.
Old 10-22-2013, 04:01 PM   #38749
chabon
chabon's Avatar
Oddometer: 294
Originally Posted by r6realtor View Post
looks good, I would like to see the whole bike in a pic with it on do you have any? im digging that whole dirt tires on 17's looks sharp!
Here's a couple shots all loaded up to go to Cambria for Horizons Unlimited get together and then followed by trip to Copper Canyon in a couple weeks. It looks pretty good without all the gear hanging off it also.
2013-10-22 15.51.43
2013-10-22 15.51.27
Copper Canyon Mexico or Will I Come Back Alive?
Baja Team 6
Barracas Del Cobre
Chabón - F650 Funduro - WR250X
chabon is offline   Reply With Quote
Old 10-22-2013, 04:14 PM   #38750
skierd
Wannabe Far-Rider
Oddometer: 2,993
I understand what you're saying, and maybe it was due to having a somewhat loose chain though I also go by chain deflection.
Regardless, the amount of wear on the chain links and the chain saver itself convinced me to not run that sprocket size again. I've had good luck with my swingarm guard over the years, and only get wear on it when the chain gets old, kinked, and dirty, chain tension and whether or not the bike is loaded or unloaded doesn't seem to matter nearly as much as the condition of the chain itself. I'm sitting at just over 43,000 miles and have gone through two sliders, both were with 12T, 13T, and 14T sprockets on throughout their life.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 10-22-2013, 05:42 PM   #38751
sieg
sieg's Avatar
Oddometer: 2,936
Originally Posted by SR1 View Post
Wow, I put an HD tube on the fender alone (in a bag of course) and it was floppin' around everywhere. Hmm...
Well I never carry a HD tube for a spare (but I run one) so you may have a point there.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 10-22-2013, 06:11 PM   #38752
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 217
Have you actually ridden with the tank panniers loaded up? I tried them and it was a pretty awful failure. Velcro adhesive proved insufficient, bags started moving around, then beating me in the kneecaps. Roadside fix involved straps around each bag, connected to each other over the steering head. They're great for holding standard nalgene bottles though, if you can make them work.
DaymienRules is offline   Reply With Quote
Old 10-22-2013, 06:38 PM   #38753
jgormley
jgormley's Avatar
Oddometer: 812
It might be helpful to note compression and rebound settings when reporting chain wear...
I just switched to a soft compression and a slow rebound on both front and rear.. in an attempt to stop a wear issue...
I did have soft compression and fast rebound and the rear swing arm was much more active than it is now...
jgormley is offline   Reply With Quote
Old 10-22-2013, 07:11 PM   #38754
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
Question Baja?
any of you guys going to amateur-ride one of these in the november Baja?
Zapp
"I will not let the White City fall... nor our people fail.” - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 10-22-2013, 09:06 PM   #38755
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,442
Looks like you could leave in the morning. Well sorted WR. I need to start getting ready, a couple of weeks is coming fast.
Bgunn is offline   Reply With Quote
Old 10-23-2013, 07:06 AM   #38756
byron555
byron555's Avatar
Oddometer: 1,129
the 12t
I'm sure you can run the 12t without issue, it just takes more effort to dial in the tension. The 14t has not been a problem for my bike so far. All 3 work, provided the chain tension is correct for each set up.
This and the fuel pump get kicked to death on this tread, primarily because the only real problems this bike has is with the fuel pump and the swing arm wear. If these problems didn't exist, the WR250r would be the absolute perfect Dual Sport... this would be a sign of the end times as there is no such thing as true perfection
WRr re-build
Old 10-23-2013, 07:53 AM   #38757
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 90
Originally Posted by Kent Glasscock View Post
On the purchase list is the wolfman side racks and was looking at a decent rear rack. I did see where the OEM rack works but may require a little more work for installing. I like the moose racing rear rack and Immix also has a nice one. Has anyone tried to use either of these with the Wolfman's. Thanks!
I have an Immix rack, it's a pretty solid rack. It is 100% steel so it's maybe a bit heavier than some aluminum racks, but being steel it should be quite strong. I think you could probably lift up the whole bike with it.
It is one of the larger platforms out there, which I like. And the mounting to the subframe is pretty robust. Rather than using the four closely-spaced anchor points under the fender, the mounting is spread further apart (two anchors under the fender, two farther forward under the seat with a bracket).
YMMV
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Old 10-23-2013, 09:41 AM   #38758
TexaNate
TexaNate's Avatar
Oddometer: 414
Exactly. Yamaha did us a favor - if the WRR were the perfect dual-sport, the sky would turn red, pigs would fly and the world would end!
I have 6800mi on the original chain slider (13/47 gearing), the last 1,800 of which I've been adjusting the chain tension using SheWolf's heuristic. Inch and a bit between the swingarm and chain, tighten it up and off I go. Seems to work OK. Once I did it up a little too tight and I really liked the way the bike felt (less jerky at low speed because less driveline slack, easier shifts as well) but I loosened it up a little after that. Scared of oil leaks at the countershaft sprocket, and all the associated horrors...
2014 690 Enduro R
TexaNate is online now   Reply With Quote
Old 10-23-2013, 11:39 AM   #38759
chabon
chabon's Avatar
Oddometer: 294
Forget the Velcro, I put a couple grommets in the bottom of the bags and ran a bungee cord between the bags. No more flapping.
Sent from my HTC One using Tapatalk 4
Baja Team 6
Barracas Del Cobre
Old 10-23-2013, 01:01 PM   #38760
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,255
my 2008 has the original fuel pump and chain slider....42000km's
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Times are GMT -7.   It's 07:19 PM.
