Old 05-06-2008, 10:53 AM   #91
reconsmr
Oddometer: 1,522
Your the #s guy I was waiting for, what is the theoretical top speed at the 10k RPM limiter? I've had the lil Ninja indicate over 90 MPH but in 5th, she didn't want any part of 6th gear.
IIRC Dirt Bike did a top speed test with a built XR650 of Johnny Cambells Baja race effort, full factory Honda race built bike and a Factory 525 EXC KTM, after pulling off fenders & schrouds and laying on the bikes in sheer clothing they only got around 108-109 mph, two bikes probably near double the crank HP of a WR250r.
Is the 25 RWHP confirmed?
reconsmr is offline   Reply With Quote
Old 05-06-2008, 10:58 AM   #92
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,673
I thought the European site was listing ~31 hp for the little WR..
Fast1 is offline   Reply With Quote
Old 05-06-2008, 10:59 AM   #93
reconsmr
Oddometer: 1,522
Someone posted 24.9 on the other WR thread. 31 crank???
Old 05-06-2008, 11:09 AM   #94
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,626
Dynos are all different. I'd like to see Cycle World do a full test so we can get comparable weight and power numbers on this new guy. Meanwhile, here's one take:
Originally Posted by bryantjt
A16tony has had both on a dyno, a piped/jetted KLX put out 21 hp and his new WRR put out 24.9 stock. Stock the KLX was 17. A 331cc, pumper carbed, piped/jetted KLX puts 28 hp to the wheel (Nobrakes' bike).
The YZF-R1 engine on which the WR250R is based puts out 157.1 horsepower at 12,200 rpm (Cycle World, August 2007) so theoretically in the same tune the WR250R would be capable of producing a fourth of that, or 39.3 horsepower!
The WR250 is running less compression and has a lower redline. The exhaust is probably more restrictive. It might have altered cam timing as well. Even so, 25-30 hp is no stretch.
Oh, and my calculations show 99 mph at 10,000 rpm in 6th gear.
Often wrong, but never in doubt.
montesa_vr is offline   Reply With Quote
Old 05-06-2008, 11:24 AM   #95
reconsmr
Oddometer: 1,522
OK, assuming it'll pull it that far, 99 MPH. I ride side by side with my own SMR450 Husky, wind limited at just over 100 and a KTM EXC250RFS that only pulls 74 MPH on flat pavement, somewhere between the 2 the true top speed must lie, I'm betting closer to the KTM than the 17" wheeled SMR450 with over 50 crank HP.
Old 05-06-2008, 11:39 AM   #96
montesa_vr
montesa_vr's Avatar
Oddometer: 1,626
Cycle World tested the SMR450 in the April 2007 issue. It put out 48.3 hp at 8,500 rpm and top speed was measured at 106 mph.
In physics terms, 106 mph is an awful lot faster than the 95 mph people are claiming for the WR250R. Wind resistance increases with the square of the speed and all that. I see no reason to doubt that the WR250R will honestly exceed 90 mph.
Old 05-06-2008, 11:44 AM   #97
reconsmr
Oddometer: 1,522
106 is probably with a pro jockey under 4-6"in plastic saran wrap, LOL. 95 is a long way off from 106 but that GPS 74 mph on the 250 RFS is a far, far away number from 95 as well, no???
Old 05-06-2008, 12:05 PM   #98
montesa_vr
montesa_vr's Avatar
Oddometer: 1,626
74 mph for a 250 dual sport isn't much. In the Dec. 1990 250 dual sport comparison in Motorcyclist, two of the bikes (Honda NX250 and Kawasaki KLR250) had 76 mph terminal speeds in quarter-mile drag strip testing.
According to a Nov. 1989 road test in Cycle, the KLR250 would "pull the 9500 rpm redline in sixth (90 mph)."
No mention of top speed in Cycle's May 1988 test of the NX250, but theirs topped 78 mph at the drag strip.
montesa_vr screwed with this post 05-06-2008 at 12:22 PM
Old 05-06-2008, 02:07 PM   #99
norshor1
Oddometer: 21
the bike should go 90+ according to the speedo , but it will be at least 6mph off. i tried to see what it would do today but couldn't because of ditch donkeys. i hit 80 on the speedo [74 gps] but had to back off because of the donkeys.
norshor1 is offline   Reply With Quote
Old 05-06-2008, 02:20 PM   #100
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,673
I'd place my bets on somewhere between 85 and 90 mph on GPS with minimal wind.
Also check the Jap and Euro websites for manufacture posted hp..
Old 05-06-2008, 03:36 PM   #101
djchan
djchan's Avatar
Oddometer: 1,137
Any WRR owners out there coming off a KLR650 as a previous bike? I've had 'em all from KLR to DRZe to LC4E. My question for you KLR ownwers is - does the WRR pull through the gears with at least the gusto of a KLR? I'm about ready to buy one and this has been a reservation. It doesn't need to pull like the LC4 but I'd really like nothing more sluggish than the KLR. My sense is that it's probably got about the same pickup ... and that would be acceptable. Lil help?
djchan is offline   Reply With Quote
Old 05-06-2008, 07:58 PM   #102
Reposado1800
Bronze Age Fall Guy
Reposado1800's Avatar
Oddometer: 5,122
The WRX pulls through the gears like a MX bike. I don't know why everybody is amped up about top speed. The bike is fast. The bike is powerful. It is geared nearly perfect. Yamaha did there homework and got it right. I see people cringing like there is supposed to be a XT250 hiding inside it somewhere. Fir cripes sakes it is a Yammy version of a KTM or Husky! Does it have to walk on water too?
Hate gets you nowhere.
Old 05-06-2008, 08:00 PM   #103
Gargoyle
Trail Jester
Gargoyle's Avatar
Oddometer: 1,007
I am enjoying watching this discussion on top speed. Thought I would try to get some input from WR250X owners to add in so I started a thread over at TT to get input.
This is the most interesting post so far ... that is he sees 105 mph on speedo, 95 mph paced by a car ... and has 4000 miles on already!
"I drive my wrx 110 miles a day to work I have hit top of 105 on my speedo in MPH not KMH I also dropped one tooth in the front.....I can go faster now than I did stock. My stock top speed was 99 but now I can get to peak power with the smaller sprocket. I have been running with my friend in his sububan at that 105 I am running actual 95. This machine will rev so freakin high I think I am really pushing it as far as it will go. I change my oil once a week and hope that I don't run into problems. At the end of this week I'll have over 4000 miles on her."
http://www.thumpertalk.com/forum/sho...d.php?t=641295
'11 Husaberg FE570S
'12 KTM 990
'13 Husaberg FE350
Berkshire Trail Riders on Facebook or follow me on Twitter
Gargoyle is online now   Reply With Quote
Old 05-06-2008, 08:37 PM   #104
OrangeTJ
Oddometer: 32
speed
Personally, I don't care about the top speed of any bike as long as it can cruise at 70 or so without feeling particularly stressed. Anything above that is superfluous to me, as there's no speed limit in the land higher than that. I don't mind getting passed by fast laners as long as I can keep up comfortably in the right lane.
OrangeTJ is offline   Reply With Quote
Old 05-07-2008, 03:48 AM   #105
reconsmr
Oddometer: 1,522
My interest was from comments it would cruise easily at 80+, I'd certainally keep a 8100 RPM cruise to a short passing blast. It dosen't take much of a headwind, or side wind for that matter to keep my de-emmissioned +50 HP 450 from getting past 90 MPH, a 30 crank HP 250 getting there easily is certainally suspect.
Having a 80+ reserve is real nice, I'm guessin the real cruise speed is 65-70 at reasonable RPM/piston speed??? Time for more math,,,
Times are GMT -7.   It's 04:32 AM.
