04-08-2008, 02:35 PM
#1 |
oot & aboot
Oddometer: 25,743
1976 R90/6 oil leak advice
1976 BMW R90/6
Looks like its the oil pressure switch? (left side of engine behind the pushrods). Anyone have any knowledge of whats involved in stopping this leak?
www.motogeek.com |
04-08-2008, 02:36 PM
#2 |
Oddometer: 9,781
Yep new switch comes with a crush ring.
Install and torque to spec. |
04-08-2008, 02:48 PM
#3 |
oot & aboot
Oddometer: 25,743
is this the same part as the "Duralast PS158" for "$7 bucks at auto zone" as per the "airhead parts - the dark secrets revealed" thread?
http://www.advrider.com/forums/showp...4&postcount=78
www.motogeek.com |
04-08-2008, 02:53 PM
#4 | |
Oddometer: 9,781
04-08-2008, 02:57 PM
#5 |
all good advice
I just had the same problem on Barbie's bike.
Go with the cheapest unit; only thing to remember si to clean up everything well before installing and use the correct torque. |
04-08-2008, 03:06 PM
#6 |
oot & aboot
Oddometer: 25,743
can I remove it without draining the bike's oil?
www.motogeek.com |
04-08-2008, 03:08 PM
#7 | |
Oddometer: 9,781
there will be some drips, but it shouldn't be pressurized much. |
04-08-2008, 03:22 PM
#8 |
Oddometer: 3,318
Some guy changed one out in my parking lot and made a mess for me to clean up. For mine, I set it down on the right cylinder, and diden't lose a drop of oil.
04-08-2008, 03:44 PM
#9 | |
Red Clay Halo
Oddometer: 11,159
Yep, can't tell clearly, but it looks like it is leaking through the switch, so there is only one way to fix it.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
04-08-2008, 05:39 PM
#10 |
Beemerholics Anonymous
Oddometer: 7,354
+2 - they start leaking around the crimp and there aint nuthin you can do about it! Just replace it! I went to the foreign auto parts place and got one for a 2002 if I recall correctly. That was a lot closer than 30 miles to the dealer. Something like $7 or $8. Or you could go the the BMW car dealer and get one for about the same price, if you have one near you. Same little unit, but when it's for a motorcycle it's suddenly very special.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
04-08-2008, 05:49 PM
#11 | |
Still a stupid tire guy
Oddometer: 7,267
Yes. The swap will take you all of about 3 minutes to do. Spray the area down with some contact or brake cleaner, remove the old unit, reinstall the new one. Torque to spec. If you're worried about oil coming out of the hole, lean the RH rocker cover over on a milk crate.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
04-08-2008, 05:52 PM
#12 |
Oddometer: 7,354
You'll also need a 24mm socket for this job - crescent wrench, box or open end won't work.
04-08-2008, 06:11 PM
#13 | |
Oddometer: 7,267
A 15/16" will also sometimes do the trick.
04-08-2008, 06:19 PM
#14 | |
Oddometer: 9,781
04-08-2008, 06:49 PM
#15 |
oot & aboot
Oddometer: 25,743
I don't care what they say.. all y'all are the best
www.motogeek.com |
