Old 04-15-2008, 05:10 PM   #31
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,761
Originally Posted by drhach
This may be the place to ask a question that I have regarding the oil pickup tube in an airhead. I have a non-oil cooler bike. I bought a thermostatically controlled oil cooler and the appropriate pick up tube to convert my bike. So, my question is, how the hell do I get the old pickup tube out? It's screwed in tighter than a virgin on prom night. Is there a special wrench (for the tube, not the virgin)?
Not that I know of. Just a big damn flat screwdriver. Its just threads.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 04-15-2008, 05:22 PM   #32
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
Originally Posted by datchew
Lesson cost: just under 3 quarts of oil that had run for approximately 8 miles.
Why didn't you just put it on the sidestandand pull the cover?
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 04-15-2008, 08:23 PM   #33
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
I have a lipped cannister on my 92 GSPD and to complicate things a bit further, mine measures 4.3mm at 3 o'clock and 4.6mm at 9 o'clock. I use 4 shims with no cover gasket (of course). Based on computations (using the 4.3mm depth), I should get the o-ring squashed to 22.5%.
To provide some data which might prove useful to some, I installed an oil pressure gauge with a 0.5-bar switch for the idiot light for that extra margin of safety (vs the usual 0.2-bar BMW switch). These are the readings I got:
With 1 shim
40 psi with cold engine at idle speed
30 psi at operating temp, 4500 rpm
3 psi at operating temp, idle speed
With 4 shims
Over 80 psi with cold engine at idle speed (only have an 80 psi gauge)
65 psi at operating temp, 4500 rpm
12 psi at operating temp, idle speed
During very hot days, I used to get the oil lamp to flicker with the old 0.2 bar oil switch. Now, it doesn't flicker even with the higher 0.5 bar switch installed. Peace of mind is what all these got for me.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 04-16-2008, 02:32 AM   #34
Beemerboff
Oddometer: 2,322
With one shim you have zero compression and enough oil pressure to keep the light off , which is what I had when I bought my bike.
Makes me want to fit a oil pressure gauge now - have you posted somewhere how you did it and what bits you used.?
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 04-16-2008, 05:55 AM   #35
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Is there an echo in here?
datchew is offline   Reply With Quote
Old 04-16-2008, 05:57 AM   #36
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Ditto.
Old 04-16-2008, 05:58 AM   #37
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,047
With 1 shim
With 4 shims
That is some very telling info right there.
And that settles it, I'm going to stick that home made mechanical oil pressure tester I made up for routine checks on the Ducatis onto the R80 and record my results. I like to track oil pressure trends on a motor anyway.
BTW, you can make a tester like this for probably less than $10
I used a standard liquid gauge from a pool supply store and the correct metric-to-NPT adapter from a 5-piece set from Autozone.
I've just been lazy about testing the R80 because the air injection line is in the way for installing the gauge in place of the electrical sensor.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-16-2008, 06:01 AM   #38
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
what's the actual spec for pressures?
Old 04-16-2008, 06:37 AM   #39
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
Old 04-16-2008, 06:44 AM   #40
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,761
I thought, but of course doubt everything that comes out of my mouth but wtf Im here to learn-- that Its quite high while running at 4-5Krevs. Upwards of 80-100psi I think I remember 130 but I was probably runk
While idling its low, not higher than 15 or 20
What say you, Joerg?
Old 04-16-2008, 06:47 AM   #41
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
he he he. I think I should put that in my sig line to qualify all the bonehead stuff I put in here. Probably drives Joerg and Anton and other organized folk crazy when I ask questions BEFORE i remember that it's already documented.
Old 04-16-2008, 06:48 AM   #42
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,419
It's just so tight that I was worried about slipping and damaging the notch in the tube. I assume there is some sort of thread locking material on there as well. I know tha they advocate that on reassembly. I'll get out my BAS (Big-Assed Screwdriver) and try it.
drhach is offline   Reply With Quote
Old 04-16-2008, 06:53 AM   #43
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,761
Yeah, I hear you. try to fill the notch with screwdriver, you know?
Old 04-16-2008, 07:23 AM   #44
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
it's a big enough slot that you might try just fabbing a tool from some bar stock.
Old 04-16-2008, 07:48 AM   #45
AliBaba
AliBaba's Avatar
Oddometer: 372
Thumb
With 1 shim
With 4 shims
Your reply gives a really good overview on what happens when there is a leakage in the canister!
The oilpressure drops to 50% or worse. The pressure at idle and operating-temp is still a bit lower then mine, maybe you canister is not completely sealed…
AliBaba is offline   Reply With Quote
Times are GMT -7.   It's 09:33 AM.
