Old 09-06-2012, 06:25 AM   #76
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Originally Posted by regomodo View Post
and i'm correct in assuming that I only need the white oring & shim because I don't have a cooler?
Not exaclty- you need to check the depth of the filter canister relative to the outer case. It needs to be the correct deth to compress the o-ring by 30% or something. Youre going to need the white o-ring in any event, but you may not need the metal shim or you might, and you may not need the paper gasket, or you might.
Just have to measure, and here is what its all about: probably posted before:
http://largiader.com/tech/filters/
Alternatively, whatever came out was presumably working, so worst case scenario, just put it back like you found it
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 09-06-2012, 03:12 PM   #77
regomodo
Oddometer: 185
I had a look earlier: no gasket ( I remember it ripping when taking the cover off), the canister depth is 2.9-3.4mm (mostly 3.4mm), the o-ring is 3.7mm all around. No shim. The canister seemed to be pointy edged,not sure, and caused a good impression in the o-ring.
By those measurements 1 shim & o-ring should be sufficient.
regomodo screwed with this post 09-06-2012 at 03:18 PM
regomodo is offline   Reply With Quote
Old 09-06-2012, 03:17 PM   #78
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
This all doesn't apply to the 1985 R80RT does it?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-06-2012, 03:50 PM   #79
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Yes.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 04-09-2013, 12:24 PM   #80
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,815
Yeah Yeah I know this is an old subject. !984 R80 G/S- Decided to look into the -o-ring thing since having to do an oil change. I've been using the gasket, white o-ring and metal shim as that was what was in the bike when I got it. Measured the distance from the case to the inner can and it was 4.1 mm...way to much. Note o-ring wasn't even compressed...duh. Before actually measuring I thought I could get away with just not using the gasket. After reading up I decided to go with THREE metal shims, white o-ring and no gasket. This set up had the o-ring proud of the case. I'm amazed there hasn't been a problem....thank goodness. I've put 20,000 miles on the bike this way and who knows how long before me.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-10-2013, 03:05 AM   #81
ME 109
ME 109's Avatar
Oddometer: 3,029
Lots of concern about oil leaking past an o-ring but not much about unfiltered oil going through the bypass.
I think more oil goes through the bypass than people realise.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 04-10-2013, 03:09 AM   #82
Plaka
Brevis illi vita est
Oddometer: 4,609
That's dreadful!!
Old 04-10-2013, 09:58 AM   #83
190e
Oddometer: 806
Oil filter
The bypass is set at 1.5 bar. I expect oil goes through the bypass every time you start the engine with cold oil.
190e is offline   Reply With Quote
Old 04-10-2013, 12:50 PM   #84
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,078
Speaking of oil going other than where intended, I can't remember the answer to this question: Does the oil pressure sender measure pressure upstream or downstream of the filter? Upstream or downstream of crank & rod bearings?
In other words, will a mechanical gauge in place of the sender alert one to low pressure as when oil bypasses the white o-ring and returns straight to the sump? Will it confirm a safe pressure at the crank & rod bearings?
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-10-2013, 12:59 PM   #85
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Filter, --> pump, --> pressure gauge, --> big end front
It would make the most sense to measure pressure right between the pump and the bearings, to me.
Old 04-10-2013, 01:49 PM   #86
ME 109
ME 109's Avatar
Oddometer: 3,029
Oil pick-up from sump, oil pump, pressure switch, oil filter, to the front bearing web where it is distributed to cam bearing, main bearings, big ends and rockers.
The pressure switch will be under X pressure and not activating the warning light, depending on how much is leaking past the oil filter o-ring.
All to my understanding anyways.
Old 04-10-2013, 01:59 PM   #87
ME 109
ME 109's Avatar
Oddometer: 3,029
Are you referring to the oil pressure relief valve attached to the front bearing web?
The 'bypass' is for the oil filter and is at the rear of the filter canister.
Old 04-10-2013, 02:12 PM   #88
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Well I stand corrected. It goes Pickup, pump, filter, front main, rear main, then the pressure switch :whoa unless i totally read it wrong:
Here is a description:
http://bmwmotorcycletech.info/oilsketch.htm
Old 04-10-2013, 02:20 PM   #89
190e
Oddometer: 806
I was talking about the oil filter bypass.
The oil pressure relief valve is set at a much higher pressure - 5 bar (71 psi).
To complete the picture the oil pressure switch operates at 0.2 to 0.5 bar (3 - 7 psi).
Old 04-10-2013, 02:28 PM   #90
ME 109
ME 109's Avatar
Oddometer: 3,029
That's the first time I've read a value associated with the bypass.
Do you think the spring sets the value, or the restriction created by the 8mm ball in the X diametre bypass chamber?
Times are GMT -7.   It's 07:45 AM.
