Old 04-15-2008, 08:23 AM   #1
ogklx400 OP
Oddometer: 972
What is the T-Mod on a klr 650?
Just wanted to no what the T-Mod is a what it does for the bike thanks
ogklx400 is offline   Reply With Quote
Old 04-15-2008, 08:54 AM   #2
Silver King
Maita'i roa ae!
Silver King's Avatar
Oddometer: 1,801
It makes your bike into a KLT! Thank you. Thank you. I'll be here all week. GONG!
Seriously...this mod provides an alternative vent for the carb (up high) in the event of a water crossing or heavy rain.
Too lazy to search, but I'm sure there's a thread here somewhere.
Silver King is offline   Reply With Quote
Old 04-15-2008, 09:01 AM   #3
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,242
it allows you to go thru water crossings.
it takes under 5 minutes and costs $1.60.
if its not on this forum, go to www.klr650.net
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 04-15-2008, 09:03 AM   #4
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 2,010
I first discovered the T-mod on a klr forum, but there are plenty of other bikes that could benefit. In the '90s, when the Funduro was a new thing, the book on them was that they didn't like to run in the rain. Dealer techs scratched their heads over that one, and one friend sold hers because she got sick of her bike's balkiness whenever it got wet out. What do you want to bet that a T-mod would have fixed her right up?
For deMille, young fur-henchmen can't be rowing.
judjonzz is offline   Reply With Quote
Old 04-15-2008, 09:24 AM   #5
GB
Mod Squad
GB's Avatar
Oddometer: 56,848
Print this and keep it as your KLR bible:
http://www.bigcee.com/klr650faq.html
Old 04-15-2008, 10:03 AM   #6
ogklx400 OP
Oddometer: 972
Thanks for the info everyone you guys an gals are great..
Old 04-16-2008, 07:48 AM   #7
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Thumb
I'll second that statement! I have done the T-mod on almost every bike I've ridden since I do cross streams a lot.
What you are doing is adding a "T" to the vent lines on the carb and running one up high under the tank or seat to allow the carb to vent while the line down low is in the water. If you don't the line down low will be blocked by the water and your bike will starve for fuel and die! Not a good thing in a creek.
Go forth and modify my friend.
jeff_in_rc is offline   Reply With Quote
Old 04-16-2008, 10:40 AM   #8
Beezer
Oddometer: 5,874
Variations on the "T" mod are.... take a leather punch & put a hole in the vent line big enough to slide in a smaller tube (like a battery drain line size), no fitting required...... or punch the hole & forget the extra line....... or pull off the line all together..... or re-route the original line so it points up under the seat and punch a drain hole in the low spot.
Beezer is offline   Reply With Quote
Old 04-16-2008, 11:19 AM   #9
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,242
i wouldn't do that. you'd have gas all over your engine, tire, chain, etc.
i would just do the mod properly and forget about it.
it seriously takes under 5 min, you get the T and the tube from a hardware store( or an auto store) and your done.
YOUTUBE
SPOT
Old 10-31-2009, 08:21 AM   #10
XS500RUS
XS500RUS's Avatar
Oddometer: 376
I figured I'd bring this back from the dead rather than starting another thread.
I just bought a '99, and was reading up on some common modifications, this being one of them. My question is: If this is a carb VENT tube, not the overflow tube, how serious is the risk of having gas come out through this tube? If it is indeed strictly a vent for air, couldn't I just reroute the vent up higher without worrying about gas running all over the bike? TIA
Looking forward to some water crossings
1977 Yamaha XS500C cross country veteran
XS500RUS is offline   Reply With Quote
Old 11-01-2009, 09:24 AM   #11
XS500RUS
XS500RUS's Avatar
Oddometer: 376
To update that last post, I rode some pretty gnarly trails on the KLR with my brother (who actually rode a Cb360 shod with knobby tires ) and it only stalled once right after I went through a fairly deep (2 feet) mud hole. I learned to just keep the revs up a bit after each crossing and had no more issues, it idled and ran fine. I's still like to do the modification for piece of mind, and am still wondering if its OK to just route the tube higher instead of splitting it.
Old 11-01-2009, 11:52 AM   #12
Hootowl
Oddometer: 1,268
I did run the tube higher for some months and eventually did the split
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 11-02-2009, 06:40 AM   #13
tpar1220
such a pud..
tpar1220's Avatar
Oddometer: 2,613
if you dump the bike on it's side, gas can run out of every tube on the carb. if you just run the tube high... when you pick the bike back up... that gas can't get out of the tube and will be a real bitch to restart.
just cut the line and install the t... run the 2nd line up under tank somewhere.
this thing is AWESOME... and makes the mach V look like a vagina!
There will only be two things left moving after WW3.
Cockroaches & KLRs.
tpar1220 is offline   Reply With Quote
Old 11-02-2009, 01:22 PM   #14
XS500RUS
XS500RUS's Avatar
Oddometer: 376
Thumb
Ahh, that makes sense. Thank you, I'll do the mod next weekend then.
Old 05-31-2010, 09:17 AM   #15
britman
Britman
britman's Avatar
Oddometer: 279
Ummmmmmmmmmmmm,
Why does everyone on a KLR seem to run the extra gas vent line on the side of the bike where the exhaust is???
britman is offline   Reply With Quote
Times are GMT -7.   It's 12:49 AM.
