Old 04-17-2008, 03:25 AM   #1
reollc4 OP
reollc4's Avatar
Oddometer: 214
Autocom Wiring
Hi all just scored a good bargin on fleebay and picked up a easi-rider autocom system, i'm going to hook it up to my uniden UH078sx and mp3 to my 640A the questions are how have you all wired yours up eg
(1) where did you mount the plugs.
(2) are the cables long enough if you stand on the pegs or do you need longer ones.
(3) Is there anything i need to watch out for.
Reon
reollc4 is offline   Reply With Quote
Old 04-17-2008, 01:06 PM   #2
DMME
Old Fart, Older Bike
DMME's Avatar
Oddometer: 233
Main thing to watch with the -078 is that it has a metal case and if you mount it so it contacts the frame you'll end up with an "earth loop" and ignition noise through the system. So keep it insulated and you'll be OK.
DMME is offline   Reply With Quote
Old 04-17-2008, 02:35 PM   #3
Gonz
BMW Bike Bum
Gonz's Avatar
Oddometer: 756
Send a message via Skype™ to Gonz
+1 Unidens seem to have bad filtering in that respect.
Sorry, cant help you out with questions relating to your bike. I havent fitted one yet. Plenty of parts availiable, give us a hoy and I'll sort something out for ya.
Gonz.
If in doubt, give it a clout..
The bigger the doubt, the bigger the clout!!
Gonz is offline   Reply With Quote
Old 04-17-2008, 06:44 PM   #4
reollc4 OP
reollc4's Avatar
Oddometer: 214
Thank Gonz I'll work out a list of parts when i get the system and let you know what i need, From what i've seen the part are quite expencive so every bit helps.
Reon
Old 04-19-2008, 08:09 PM   #5
reollc4 OP
reollc4's Avatar
Oddometer: 214
Come on guys i need some info from ya, is there any problem in mounting the main unit under the front fairing of my 640A it will get wet there but i don't think it will fit under the seat.
Has anyone with a 640A fitted a autocom to there bike any info will help !!!
Old 04-19-2008, 10:09 PM   #6
Peka
Peka's Avatar
Oddometer: 1,991
I don't have a 640A but....
(1) Rider's lead is cable tied to the bar on the left side. Pillion lead is cable tied near the pannier mount on the left, near the pillion's leg when seated. Easy for the pillion to connect/disconnect here. She connects before getting on, disconnects after getting off
(2) Should be long enough if you have the lead going up to the bar, I've had no trouble with it. You can get a coiled lead which stretches a bit more, and I believe you can get longer leads too
(3) Rammstien makes me ride like a fucking lunatic
I have some pics here: http://peka.smugmug.com/gallery/3908179_gArfm
Peka is offline   Reply With Quote
Old 04-20-2008, 03:04 AM   #7
reollc4 OP
reollc4's Avatar
Oddometer: 214
Thanks Peka, the picture were a great help.
Reollc4
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure
99 XR400 electric start
95 DR350se
Times are GMT -7.   It's 06:39 PM.
