Old 08-26-2010, 07:48 AM   #1531
toofast4uu
adventurer
toofast4uu's Avatar
Oddometer: 971
Originally Posted by Alcanara
to buy an excel rim and spokes etc etc,and build you own front wheel..... has any one done this?
Can a complete novice do this?
Stuart
Lacing the wheels is a piece of cake...
Replacing the front, you can use a Husky Excel rim (The Huskies have the same spoke / hub / rim angle positioning)...so it's not as costly as replacing the rear rim, which requires a blank rim to be drilled to match the unique spoke angles of the rear hub. Buchanan can help you out if your on a tight budget..there's other companies as well..but Buchanan was the most reasonable..
When you lace your new wheel, ride it rough for about 50 miles....then re-tighten the spokes..you'll be amazed at how loose they get in such a short time...but once you tighten them that second time, you should be done..
RMATV sells Warp9 rims for $95 and spoke&nipple kits for $65...google a coupon code and you'll save a few more bucks...but that's only gonna work on the front rim....
good luck!
toofast4uu is offline   Reply With Quote
Old 08-26-2010, 10:23 AM   #1532
Alcanara
's not me occifer
Alcanara's Avatar
Location: Harrogate (UK) and Murcia (Spain) Trail Heaven
Oddometer: 122
toofast4uu..... fantastic info. Cheers
Stuart
G650 XChallenge Feb 2008, R1100S 2003, F650CS 2003 (My Wife's)
Retired Young and broke:- but in Spain where the sun shines and the beer is cheap... what more could you want
Alcanara is offline   Reply With Quote
Old 08-27-2010, 12:19 PM   #1533
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
Helppp!! Need help with OEM clutch on my XCh.
So, back last year when I bought my XChallange new, I insalled a Rekluse and life was good.
Now, I've decided to go back to the OEM clutch and un-install the Rekluse.
The first problem was I only had 7 OEM steel clutch plates. I assume I lost one during the Rekluse install. BMW parts show 8. So I finally get another one. But after installing 8 steel and 8 friction, starting with the steel, the last friction plate doesnt fit into the tabs on the outer basket, everything seams too thick for the tabs.
And when I go ahead and put on the preasure plate and the outer cover, I cant get any cluthey feel out of the lever and the clutch/preasure plate will not release.
It all seams so simple and straight forward, what am I doing wrong???? Gotta be a no brainer.....
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 08-27-2010, 12:36 PM   #1534
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
I think the image is wrong. should only be 7 steels not 8 you didn't lose one.
I have never seen a basket clutch on a motorcycle that has a steel plate on the back.. should be friction/steel/friction/steel... etc. Then when you install the pressure plate you should have an arrow that has an alignment mark on the basket... if the pressure plate is not aligned (rotate like a clock) it will not fit on to the basket all the way, as it has notches on it just like the steel plates.
_________________________
2006 BMW R1200GS
2010 KTM 690 ENDURO R
1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 08-27-2010, 01:11 PM   #1535
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
Thanks, but I just figured that out. Well, anyways the service guy at Ted's Beemer figured it out. After looking closley one of the friction plates was made just a lttle different, that musta been the one that came with the Rekluse setup.
Anyways, all is well again. "World, carry on".
Old 08-27-2010, 01:43 PM   #1536
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
the outer friction plate is different, from the factory. It has a narrower band of friction material on it. Often called a damper plate.
2006 BMW R1200GS
1969 BSA STARFIRE
Old 08-27-2010, 02:53 PM   #1537
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
Did'nt notice that. Do I need to take it back apart again?? How can I tell by looking??
Old 08-27-2010, 04:02 PM   #1538
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
If you *do* then take a lot of pictures, I can take pictures of mine and compare...
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 08-27-2010, 06:22 PM   #1539
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
No don't take it apart.. just so you have them all in there.... some guys take out the damper plate and replace it with a standard disk... No biggie
2006 BMW R1200GS
1969 BSA STARFIRE
Old 08-27-2010, 07:49 PM   #1540
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,124
A little bit off topic, but how did you find the Rekluse on the XCH?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 08-27-2010, 09:52 PM   #1541
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,970
was missing now stopped
Hi guys
I trailered my bike home once more today.
2 weeks ago I felt a barely perceptible bilp while cruising through the countryside at about 110 - 120 this happened a couple of times
A few days later the bike stammered and then came to a stop. But started again as soon as I hit the starter. I thought the problem may have been dirty fuel.
A few more days and the bike is stammering and cutting out. I would just let the motor die and I would hit the starter and off I would go again
This behavior happened about 10 times in an hour and then subsided and I thought it was dodgy fuel and I had eventually sucked it all through
A few days ago I took it for a run and when I opened up the throttle to give it a bit of a blast it started stammering again, like a rev limiter. Again the situation seemed to disappear. I was starting to think that perhaps the spark plug lead was shorting out on the frame somewhere.
Today I started to head off for the week end with the bike fully packed. After a few k's when I opened up the throttle she died and would not start.
So I have
  • drained the fuel tank
  • cleaned the grit out of the bottom of the tank (I don't think that this was a significant amount)
  • Removed the fuel pump
  • Checked the fuel filter (nothing significant there either)
  • checked that the fuel pump is pumping
  • cleaned the idle actuator
No joy
Any suggestions , pointers, advice?
dirtsurfer is online now   Reply With Quote
Old 08-27-2010, 11:36 PM   #1542
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,124
Check the ignition swith to make sure that none of the connectors have cracked or have corrosion build up, solder cracked etc?
I remember someone with a X bike having trouble with this, also check all the other fuses and connections for corrosion buildup.
Could you replicate the break down while you had the seat and covers off?
xronly
Old 08-28-2010, 12:29 AM   #1543
mindazzz
mindazzz's Avatar
Oddometer: 37
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Hey, one more fairing for an auction, get it while it's cheap
mindazzz is offline   Reply With Quote
Old 08-28-2010, 12:58 AM   #1544
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,582
Originally Posted by dirtsurfer
Hi guys
Do you have electrics? will the bike crank?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 08-28-2010, 01:19 AM   #1545
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,970
Yep it cranks ok, I also pulled out the injector to make sure fuel was being delivered into the motor. (it is)
I am pretty sure that the issue is electrical as I stuck a screwdriver into my spark plug cap, ensuring that the metal tip was in contact with the spark plug terminal connector, grasped the metal shaft of the screwdriver, took a breath and hit the starter, turning the motor over a few times and I did not experience any electric shock.
Times are GMT -7.   It's 03:36 PM.
